Question about LG W2243T-PF Monitor
How to remove the single vertical tiny stripe on screen?
    Champion:
  • 331 Answers
By replacing the lcd panel.
Posted on Aug 27, 2010
My screen has a thin, vertical, black stripe about one inch over from the right. It also has a tiny red vertical stripe next to the black one, as well a few blue ones.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 04, 2016 | Insignia Televison & Video
I have a 52 inch Samsung TV, on the screen have solid, color vertical lines on the right, about 1/8 wide, on the same time the half of screen blink on the right too.
not knowing the model... i will try to help with this common samsung issue, if i can. / unplug the tv, and wait a few minutes to avoid shocks. / remove back panel. you will see several ribbon connectors, (about an 1" to 1 1/2" wide) usually near the bottom. / carefully remove the ribbon (ONE AT A TIME) and clean the contacts GENTLY with a pencil eraser. (DO NOT use chemicals) / reinsert the ribbons and try the tv. // vertical stripes are almost always the result of poor contact between ribbon and socket. / NOTE!. you can do a quick test before opening the set by [carefully!!!!] twisting the screen and watch to see if the vertical stripes change or disappear. / if the stripes change, bet on it being the ribbon contact problem.//// hope this helps, it has worked on a number of TVs.------Jay
Oct 26, 2015 | Samsung Televison & Video
Motorola wx445/verizon wont boot white screen w/thin red vertical screen no os
Remove any box being used and unplug it--with no OSD problem is on main signal and digital board.
Jun 14, 2012 | Televison & Video
Vertical stripe on projector screen
If it is a single line, one element burned out on the LCD. If it is a wide band, the LCD or the element driver is defective.
Dec 20, 2011 | NEC Office Equipment & Supplies
I am getting a blue line, vertical, down the right hand side of the screen. It will fade in and go away. Don't tell me my LCD is going out. I've only had it for a year.
Hope you are still in warranty, a single colored line in an LCD or Plasma is usually a screen fault, the only other possibility would be the LCD control board, however it usually generate large stripes or bad image with half the screen, a single line, 99% is a bad screen. Call Sony, screen replacements are not economical to repair.
Crampy
Nov 29, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Green vertical stripes down right hand side of screen, no picture
Unfortunately this means that your TV may be damaged. I would suggest talking to a professional or consider replacing your TV depending on the cost of fixing it.
What it means is that the power to that line of LCDs in your screen is 'stuck' and it is generally not user-serviceable.
Jan 23, 2009 | LG 19LG30 19 in. LCD HDTV
Hitachi 60v500 tv has split screen with white vertical stripe down side
Good Day, poandflo;
After removing the power from TV remove the back of the TV (bottom only): Repair: Re-insert PDM connector on both Main Digital module and Drive PWB.
Good Luck, big IRISH. ps. remove cables one at a time and plug back in ensuring that they are seat properly.
Aug 08, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
IMAC lcd vertical colored stripes
First, plun a external monitor and toggle the screen with ALT+F5. This will determine if you have a hardware or software problem (drivers, configuration, etc).
If the image in the external screen is correct then the problem is in the LCD panel or its cabling.
Here you can get the replacement LCD panel and change it yourself.
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390/Products/%22Pantallas%20portatil%22
May 22, 2008 | Apple iMac Flat Panel Fan (p/n 922-4677)
2-inch picture stripe in middle of screen.
deight, your set is going into total vertical collapse, either the vertical IC is failing or some support component to the vertical circuit is failing, should not be an expensive repair, hope this helps, BMW Rider
Dec 12, 2007 | Sylvania 6419TA 19" TV
LG W2243T-PF Monitor Logo
53 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
