Question about Janome Jem Gold 660 Sewing Machine
Bobbin keeps jaming and knoting - Janome Jem Gold 660 Sewing Machine
    Genius:
  • 1,788 Answers
Go to either Singerco.com website or brother-usa.com
and look for their solutions for free or call Janome, phone number should be in your manual.
Posted on Aug 27, 2010
My machine James now the bobbin keeps falling out
Check the manual to make sure you are putting it in right and also
entire bobbin case that the bobbin fits in might not be in right.
Jan 30, 2015 | Sewing Machines
The thred keeps jaming in the bobben on my 9110
Check to be sure your bobbin is in correctly. so turn clockwise, others counterclockwise.
Jan 07, 2013 | Euro-Pro Shark 9110 Sewing Machine
The bobbin keeps getting jamed
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is not fully wound, usually wind the bobbin
3/4 full, when I was sewing last night & rewound the bobbin & I wound
it to full & it jammed twice on me.
make sure the top thread has not come off the thread take up lever
clean under the needle plate & in the bobbin area
Aug 08, 2012 | Singer Pixie Plus Sewing Machine
The thread is knoting and pulling the fabric threads...What do I need to do?
Make sure it is threaded correctly
Make sure needle is large enough for the thread
Check bobbin tension to make sure it's not too tight
Make sure adjustment of machine (stitch length etc.) is correct for the specific stitch you are using.
This is my best advice with the information that is given.
Aug 22, 2010 | Husqvarna Sewing Machines
Stitching is loose and knoting up on the underside of the material - why?
1.check to make sure it's threaded correctly, sometimes the thread come off the thread take up lever on my mechanical sewing machine.
2.check the needle to see if it's bent
3.check to see if the needle is in backward
4.check the thread tension
5.check the bobbin to see if it's warped-i've gottin ahold of several of them
Jul 29, 2010 | New Home Sewing Machines
Singer simple the machine keeps jaming
I would say that the threading is wrong somewhere, watch your dvd and read the owners manual, also go to Singer.com FAQ for your machine, If the jamming is underneath, it is the top threading problem, on top, it is the bobbin thread either has lint or stray thread or thread not coming out the right direction for your bobbin, I am sure that it is just a simple solution, I also use metal SA 156 bobbins and have no problems,
Apr 05, 2010 | Singer 3116 Simple
The thread after sewing just pulls right out won't sew
the thread hook is not grabbing the thread; it is not turning around and, knoting the needle and, bobbin threads together.
pull the cover off under the bobbin so you can see the hook: it looks like a small disk with a point on it) turn the wheel so that the needle goes down and, see why the hook is missing the thread then: adjust the hook so it just passes through the needle loop when the needle starts back up.
Jan 16, 2010 | Singer Sewing Machines
Bottom tread keeps jamming and getting all knoted up. The display gives me an E6 error code. what can i do
try re-threading your machine. usually when the machine is jammed at the bobbin or when the needle gets stuck to the bobbin thread, it means that there is an error with the thread. make sure that the thread isn't pulled through the wrong side of the needle, wrapped the wrong way around the wheels on the top, and that the bobbin is threaded correctly. if this doesn't work, you may want to contact their hotline.
Sep 23, 2009 | Brother CS-100-T Computerized Sewing...
Thread jams in bobbin area
well i have done the same thing , all u need to do is if you see the screws that hold the bobbin area you un screwq thoes and get you a pair of scisors and cut around the knoted mess and all you do is work with it until it is all out and you dont realy want to pull on it to much you know just work it around so it gets lose so that you can cut it out thin you put it back together and try it out.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Sewing Machines Logo
83 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
