Question about Viking VCSB423 Side by Side Refrigerator
How do i turn on my viking vcsb548ss ice maker
tborn6
  • 700 Answers
SOURCE: Viking Ice Maker Leak
have you cleaned the machine lately? the float may be dirty and getting stuck and not shutting down the water as it should.
Posted on Jan 06, 2009
  • 25 Answers
SOURCE: no ice
put your finger into the mold of the icemaker or get a mirror and see if there is any water in it, if not, pour 5 oz. of water into the mold and wait approx. 2 hours, if ice dumps out then you have a water supply problem. the fill tube line entering the the mold could be iced up, if it is then your water valve maybe leaking and freezing up. also the water valve may not be opening up and may need to be replaced if it still doesn't dump out the water you poured in the you will have a problem with the icemaker itself
Posted on May 08, 2009
  • 582 Answers
SOURCE: ice not releasing from plate on Viking vuim150drss
HOW OLD IS THE UNIT, AFTER A WHILE THE NICKLE PLATING STARTS TO WEAR OFF THE PLATE WHICH WILL CAUSE THIS PROBLEM AND THEY ARE NOT CHEAP, ALSO CHECK ON THE BOTTOM OF THE MACHINE THERE SHOULD BE A CONTRPL THAT WILL INCREASE THE TIME OF THE RELEASE CYCLE
Posted on Sep 28, 2009
SOURCE: how do i turn my ice maker off?
To switch off the ice maker simply pull out the ice bucket and remove and you will see a thin bar under the maker that you can simply push up until it clicks, hey presto its off!
If the leak continues look underneath the right hand door at the bottom and you will see where the waterline is attached, either turn the shut off tap (if one was fitted) or unscrew the pipe after disconnecting the mains water.
Posted on Mar 29, 2010
  • 44 Answers
SOURCE: viking side by side makes very little ice
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Posted on Jun 06, 2010
Viking Frig ice maker
Depends how old the Viking is?
Older Vikings with icemakers with a arm on the side, simply lift
the arm up until locks.
Newer Vikings with Electronic Controls look for a "slide switch"
mounted on the right side of front interior trim. You will see a
red led light usually blinking on and off near the slide.
Feb 19, 2015 | Viking DFSB483 Side by Side Refrigerator
Where is the ice maker control on the Viking 2005 regrigerator
I've maker arm above bucket . 2005, thr bucket can overfill that unless the shelf is in place. There is a new ice maker and arm assy which will help that in the future . Hope this helps
May 24, 2014 | Viking VCSB423 Side by Side Refrigerator
Ice maker makes ice intermittently
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 02, 2010 | Viking Refrigerators
The ice maker doesn't make ice
Here are some basic tips for ice maker troubleshooting2_bing.gif...
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jun 07, 2010 | Viking DTBB363 Bottom Freezer Refrigerator
Ice maker not working
heatman101
jhjf
May 29, 2010 | Viking Professional VCSF036D Side by Side...
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Apr 01, 2010 | Viking DDSB483 Side by Side Refrigerator
Ice maker on a viking side by side not working
heatman101
ghd65
Mar 21, 2010 | Viking VCSB423 Side by Side Refrigerator
How do i turn my ice maker off? i have a viking side by side and the ice maker is just pouring water in my freezer...its a mess!
Turn the water off under the sink where the small line starts that goes to the fridge or there may be a cut off directly behind the fridge in the supply line.
Your water inlet valve may be stuck open. It's where the water supply connects to the fridge.
Dec 11, 2009 | Viking VCSB423 Side by Side Refrigerator
Jan 06, 2009 | Viking Refrigerators
Viking VCSB423 side by side icemaker
You could empty the bucket when full for the days leading up to a party and save the ice somehwere......or buy an Ice machine
Sep 12, 2008 | Viking VGSC306-4B Gas Kitchen Range
Viking VCSB423 Side by Side Refrigerator Logo
145 people viewed this question
Top Viking Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
