Question about Ricoh Aficio 220 Laser Printer
Aficio 220 Copier was working fine until I moved it. Now it has a knocking noise followed by a wrench sign.
  • 52 Answers
Remove the document glass check if the carriage is free, and make sure the place (ground) u kept the machine is balance,oppen the machine remove all the dettacheable unit and fix them back.
Posted on Aug 27, 2010
I have recently move a Ricoh Aficio 250 from 1 location to another. Once I turn the copier on at the new location, a "Clear Misfeed(s)" message appears without giving a zone(s) (usually denoted by a...
If the copier worked fine before you moved it, you may have blown a fuse or damaged a board. Your best bet is to have a service technician take a look at the machine.
Before you call them, however, did you turn the machine off and unplug it, and did you open and close all of the doors and covers? It may just be a door that isn't closed all the way.
Aug 02, 2010 | Ricoh Aficio 250 Copier
My af 220 still got toner sign on after i add new toner
Is the toner cart you put in a third party? If so mite require OEM cart only
Apr 03, 2010 | Ricoh Aficio 250 Copier
Functional problem
Press next buttons by order :
1. press the yellow button [C] (cancel)
2. press the follow number on the number pad 1-0-7
3. press and hold the red key [C] (stop) until on the screen appear service menu.
After the service menu will appear turn off and then after 5 seconds turn on the machine from the main switch which is located down in the left corner under the front door.
Dec 14, 2009 | Ricoh Aficio 450 Copier
I need the service manual for the Aficio 220
hello there here is several links that will help you out ok
best regards michael
  1. RICOH AFICIO 220 Service Manual RICOH AFICIO 220 - It's a complete service manual, and it's in PDF format. ... i got my service manual for philips vr685-02. Thanks a lot for my very clear and ...www.user-manuals.com/service-manual-RICOH-AFICIO220.html - 73k - Cached
  2. Ricoh Service Manuals - Copier Service Manuals Ricoh Service Manual/Parts catalog CD's for FT, NC, Fax, FX, Afico, AP, MLP, SLP, ... Ricoh Service Manual/Parts catalog CD's for FT, NC, Fax, FX, Aficio, AP, MLP, ...www.knowthesource.com/index.php?cPath=26 - 57k - Cached
  3. AFICIO 220 RICOH AFICIO 220 Owner's Manual ... for delivery information. Model: AFICIO 220. Type: Owner's Manual. Delivery: ... Manual received - Many thanks for an excellent service. Alain Fagan - 2006-04-11 ...www.manuals-in-pdf.com/55709-p-11284.html - 65k - Cached
Sep 14, 2009 | Office Equipment & Supplies
Toshiba 2060 wrench call for service error code
thats a problem with the feeder, when you guys moved the copier you may have knocked it slightly out of place, hence the error code to prevent the machine from a miss-feed and jam.
Jul 07, 2009 | Toshiba 2060 Copier
Ricoh Aficio 220 - moved copier to clean behind
Check the power cord, make sure you have not just pulled the copier end out of place. the power cords are often replacable and can pull out of the copier.
Hope this is of some help.
Ed
May 08, 2009 | Ricoh Office Equipment & Supplies
Copies have black streaks now
Dirt on the narrow glass will cause streaks through the Auto feeder, but copies should be clean if using the main contact glass if that's the case. Dirt/toner anywhere else (ie:laser optics) would cause light areas on the copies- not dark. Did this happen the very first time you used it, or shortly after? In other words, could it be coincidental? It sounds more to me, like the PCU (photoconductor/drum unit) needs replacement, or a fuser roller.
If cleaning the glass doesn't help, then one of these 2 things is causing your problem.
Apr 23, 2009 | Ricoh Aficio 450 Copier
Error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 350e copier Multifuntion machine
This blinking wrench red light means that your copier needs to be serviced. How old is your copier or how many copy have you done with it ?
Otherwise, you may need to call a service man for it.
Sep 08, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 copier
Wrench means "call for service" More information may help Ed
Jun 14, 2007 | Ricoh Aficio 450 Copier
81 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
