Question about XM Radio (XMP6000)
My 8 Year Old Sony-DRN-XMO1C, has been cutting out for the last month or so,It even does so in my car,and i drive at least 30 miles from it's stationary place at home. as it is a plug N"Play,I Bought a new one from an online place, and the new one does the same excact thing.skipping the signal, on both of them in 2 different placements.I Talked to the X-M people and They've not been having Sattalite or repeater problems in My Galveston Area? 2 Sony X-M Radios in 2 different places Skipping Signals I love and need My Jams Please Help. Joe T. JosephTea@Aol.Com
My 2007 GMC Yukon has 120,000 miles. Recently, I noticed that when driving the vehicle, the RPM do not drop, or reset, as the car accelerates. Instead, the faster the car goes, the higher the rpm's go,...
You have a failed transmission that will have to be
rebuilt or replaced with Reman
The flair in the rpm & gear change issues, should
have been the clue
How does that happen on a 7 year old vehicle ?
You fail to change your transmission & power steering
fluids every three years & those items that should last
15 years & 150,000 or possibly more, are given a death
sentence.
Trans fluid breaks down from heat in about two years &
like all fluids the additive packages are used up
Brake Fluid --every 2 years
Spark Plugs --every 3 years or they wear & stress the
ignition system
Motor Oil-well-you do as you please
I change mine 3 times a year,which is about 4,000
miles
When we worked-four times a year
I have a 2014 vehicle that I got in march
Changed the oil this Monday at 711 miles
WHY- it has been in there 4 months (remember
3 times a year) BUT --i keep my vehicles 18 years
I have one that I have had 30 years
The trans fluid --I will be doing soon
WHY- because I once owned a trans shop
& know what wears & when
Most wear,you ask-yep-the first thousand miles
& this vehicle has NO Filter,just a screen
Jul 25, 2014 | 2007 GMC Yukon
I have a 2005 Pontiac GP. We had the cat converter replaced a year ago. After they replaced it, the Check engin light came back on a few months later. The code was a bank 1 sensor 1 . We replaced the...
I think there are 2 o2 sensors on that car one in engine compartment an one near the converter.
both will send the same code if you have your old sensor use it on the one in the engine compartment if you can, the plugs and sensors are the same.
Good luck,Gary
Sep 22, 2011 | 2001 Pontiac Grand Prix
I have a 95 Corolla wagon with 117,547 miles on it. I changed the timing belt at 61,577 K. this means I have 4030 miles before I hit the 60K 'scheduled maintenance' of the timing belt again. but I...
some people go thousands of miles over without changing the belt,some dont bother at all,whats the law that says if its gonna go wrong it will ???
Sep 08, 2010 | 2005 Toyota Corolla
How often should I change the Transmission fluid, normal driving ? Thank you Gary
It's listed in your owner's manual. Schedule A is normal driving conditions.
SCHEDULE "A"
7,500 miles (12 000km) or at 6 months
- Change engine oil.
- Replace engine oil filter.
15,000 miles (24 000km) or at 12 months
22,500 miles (36 000km) or at 18 months
- Inspect front wheel bearings.
- Inspect brake linings.
30,000 miles (48 000km) or at 24 months
- Replace engine air cleaner filter.
- Replace spark plugs.
- Drain and refill automatic transmission fluid and filter (4.7L).
37,500 miles (60 000km) or at 30 months
- Drain and refill automatic transmission fluid and filter (5.2L/5.9L).
- Drain and refill transfer case fluid.
45,000 miles (72 000km) or at 36 months
- Flush and replace engine coolant at 36 months, regardless of mileage.
52,500 miles (84 000km) or at 42 months
- Flush and replace engine coolant if not done at 46 months.
60,000 miles (96 000km) or at 48 months
- Replace ignition cables (5.2L/5.9L).
- Inspect PCV valve, replace as necessary.
- Inspect auto tension drive belt and replace as necessary (5.2L/5.9L).
- Drain and refill automatic transmission fluid (4.7L).
67,500 miles (108 000km) or at 54 months
75,000 miles (120 000km) or at 60 months
- Drain and refill transfer case.
- Flush and replace engine coolant if it has been 30,000miles (48 000km) or 24 months since last change.
- Inspect auto tension drive belt and replace if required.
82,500 miles (132 000km) or at 66 months
90,000 miles (144 000km) or at 72 months
- Inspect auto tension drive belt and replace as necessary.
97,500 miles (156 000km) or at 78 months
105,000 miles (168 000km) or at 84 months
- Flush and replace engine coolant if it has been 30,000 miles (48 000km) or 24 months since last change.
112,500 miles (181 000km) or at 90 months
120,000 miles (192 000km) or at 96 months
Thanks for using FixYa -a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 05, 2010 | 2001 Dodge Durango
Engine cuts out
Although your pollen filter will not cause the engine to cut out, a lack of oil pressure will. Check your oil level. Then take your vehicle into a dealer soonest.
Apr 04, 2010 | 1987 Peugeot Liberte
My ps3 will boot up play for about 10 min then freeze. I reboot it. It will not boot up. Screen is black. Then after about and hour of it sitting it will reboot and do the same thing over agn.
everything sucks these days almost everything u buy is a peace of **** what happened to the stuff that last 20 30 years u think these lectronics these days last that long even cars n houses wat is going on in this world **** is more money n the **** craps out on u a year later MY PS3 IS A PEACE OF **** SONY SHOULD BE ASHAMED OF THEM SELFS GO CRALW UNDER YOUR DESK AND HIDE U SHOULD BE FIRED BUT U PROMBLY GOT A $$$$500,000.00 BONUS THIS YEAR WHAT HAPPENED TO THE OLD SCHOOL SONY'S THEY WHERE THE BOMB! IN THE LATE 80S AND 90S OK ILL LET U GO NOW I FEEL BETTER THANK U FOR YOUR TIME MAYBE SONY WOULD BE NICE PEOPLE AND CUT THERE BONUSES THIS YEAR N HOOK US UP WITH A NEW SonyPlayCrapper 3 for free
Feb 25, 2010 | Sony PlayStation® 3 (60 GB) Console
Old cd/dvd rom for new netbook
u may find a dvd drive usb enclosure from ebay and then try ur dvd drive in that
but it is available in desktop dvd drives but laptop i am not sure if it is there on ebay but pls check it out
PLS RATE ME WELL !
Regards
Zohail
May 29, 2009 | LG DRN-8080B DVD Drive
Ets light comes on , and i can`t drive pass 30 miles an hour. what could it be?
For the ETS light, its covered in Volvo's callback guarantee for 2000 models upto 10years / 100000 miles
Dec 18, 2008 | 2000 Volvo S70
After driving for 30 minutes or ? when it shifts into drive; the motor cuts out or will sometime die. I then have to wait for 20-30 minutes before it will start if it'll start then. This is a 75 chevy...
scrappy I hope you fixed your problemssince last post. Sorry to be gone for soooo long. Have you check your fuel tank? I had an old 1963 chevy that over the coarse of years that filled the bottom of the tank with dirt and what have you. It would run for 15-20 minutes and shut off. After it sat for about 10 minutes it would settle back to the bottom and I could drive again for 10=15 minutes. It drove me crazyuntil I had a radiator shop vat the fuel tank. Let me know if you fixed the problem....it has been a month since I last logged on....sorry.
Jul 23, 2008 | Chevrolet Silverado Cars & Trucks
Car Audio & Video Logo
Top XM Radio Car Audio & Video Experts
xxxxxx xxx
Electro Med Services...
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
