Question about JVC AV-35750 35" TV
Where do i get a c926 capacitor and how much is it
Where do i get a c926 capacitor (1000uf 50v
    Scholar:
  • 131 Answers
Here is a place you could order caps and parts for consumers
www.mcmelectronics.com. Believe it or not radio shack has some capacitors in stock. How it works is 1000uf should stay standard but the voltage could be higher.good luck.
Thanks DOCTOR VIDEO
Posted on May 06, 2008
  • 2,326 Answers
You can check Radio Shack stores or you can visit this website.
I have a JVC AV-32850 TV that just stopped working. It was on and then went blank. The red LED ON Timer now flashes on and off, and sometimes there is a clicking sound. I checked the outlet, and it is...
How many times does the light flash or for how long does it flash? Are you trying to service this yourself? or open to the suggestion it may need servicing? How long ago did you purchase the unit?
Thanks,
lee
Jul 01, 2008 | JVC Televison & Video
I have a jvc av 36980, wont turn on, replaced capacitor c926, still nothing, fuse is good
Hi, I have same TV with same problem. I replaced capacitor with 1000uF 50v and it worked. I also saw another posting that replaced the SMPS (switch mode power supply) STRF6626 regulator. Radio Shack does not carry it though. I had to order one from an electronics store.
Good Luck....Kim
May 18, 2010 | JVC Televison & Video
Need to replace capacitor on dvd player
Hi, you should use a capacitor with same capacitance of 1000uF, but you don't have to stick to the original voltage spec. 1000uF 10V means it can withstand 10V load. 1000uF 50V means it can hold 50V for the same capacitance. Today I fixed my friend's and for that I used 1000uF 35V from RadioShack. It perfectly works - and it's better. But you shouldn't use 1000uF 5V - by now you already know that :)
May 03, 2009 | Philips DVP642 DVD Player
When i switch on my P.C. and my FP 5313 screen it flickers
This is a known problem with a series of components inside the monitor. There are about 11 capacitors that if replaced will allow the monitor to function properly.
The best place to go to read more is http://www.badcaps.net/forum/printthread.php?t=2658
The list of the capacitors that are bad are below with possible replacements.
C922, C925: Hermei LE 1000uF 16V, low impedance, general purpose, replacing with 1000uF 16V Samxon GF.
C201: Hermei LZ 150uF 25V, ultra low impedance, high ripple current, replacing with 1000uF 25V Samxon GF.
C924, C926, C929, C930, C932, C933: Hermei LT 470uF 16V, high ripple current, low impedance, replacing with 1000uF 16V Samxon GF.
C207: Unknown CD110 50uF 4.7uF (general purpose), replacing with a 35V 4.7uF tantalum unit (SCP/Short Circuit Protection pin on TL1451 won't get anywhere near 35V).
C907: WC (with stylized Westinghouse W) SM 22uF 50V (general purpose), replacing with 63V 100uF Samxon GF (used for SMPS controller Vcc filtering).
C905: Hermei HT 100uF 400V, standard, general purpose, leaving as is - generally no problem.
Dec 06, 2008 | HP Compaq FP5315 15" LCD Monitor
JVC AV-35750 TV
I changed capacitor C926 (1000Uf 16V) on main board. It solved the problem. I went with 1000uF 63V as it was readily available...it's okay to go with higher voltage. It was hard to fit it on because of the larger size but it worked.
Jul 28, 2008 | JVC AV-35750 35" TV
Power supply problem
My tv did the same thing. Replace the capacitor marked C926 that is marked on the main(big) board. It fixed mine. The lead was broke off inside the capacitor.
Jul 12, 2008 | JVC AV-35750 35" TV
Jvc will not power up
Not, just install soldering stations on the terminal capacitor ( bottom) and pull up slow, clean solder and put it back new one. See position ( -- And + )
C926 and C928 1000uf 35v Common problems.
Some time D905 shorted
Replaced C911 470 uf 35V
Ready!!!
May 10, 2008 | Televison & Video
POWER WON'T TURN ON . YES, POWER SUPPLY OUTLET IS GOOD
Replace capacitor C926 near center of circuit board chassis (label is on the bottom) by a 1000uF 50V. Mind the polarity!
R,
A
Feb 05, 2008 | JVC AV-35750 35" TV
WON'T TURN ON. POWER SUPPLY GOOD
Replace capacitor C926 near center of circuit board chassis (label is on bottom) by a 1000uF 50V one. Mind the polarity!
R,
A
Televison & Video Logo
267 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
