Question about Microsoft Windows XP Professional
Installing windows xp to my computer
When opening my computer to install windows xp it was stated there that boot from cd is failure.but i already insert a cd.and it was stated there that HDD compatibility is disabled.what does it mean?
  • Eivanna May 06, 2008
    hELP mE pleasseeee
  • 10 Answers
Check the BIOS. StartUp from CD should be enabled
Posted on May 06, 2008
How do I install my 22w2 to my Dell Computer with Windows XP 2002
Windows install first Available some points:-
A> Fresh Windows XP CD not damage cd, if cd damage may be some file miss and installation after problem show.
B> DVD Rom Drive.
C> You DELL pc support Windows XP.
Installation Process:-
> Insert CD to DVD ROM driver and boot CD.
> If CD not select first boot then open bios and select CD first boot.
> Then follow instruction step by step like language, which drive install windows (C Drive select), format option (select quick format), new user create etc.
Thanks..
Sep 06, 2013 | Westinghouse Electric LCM-22W2 Monitor
Windows xp cd with sp3 installation
In BIOS change the boot order such that CD/DVD comes first. You will also need to make sure your hard drive runs in IDE mode since Windows XP doesn't support sata drives by default. FYI XP is going end of life early 2014.
May 20, 2013 | Microsoft Windows XP Home Edition
I am unable to install windows XP. is it possible to install windows XP along with the Windows 7 that is already installed........ suggest me asap
If you want to have both windows 7 and windows xp installed on your computer, it is advisable that you first install windows xp. You should allways install the oldest windows version first. To install windows XP on your computer you need the installation cd. Boot your computer with the Windows XP installation cd, maybe you have to enter bios to set cd to boot first. Let me now if you need more information.
Jun 09, 2011 | HP PROMO ELITE 7100 MT WINDOWS 7...
My windows Xp just lost because of power failure.. how i reinstall the windows xp for my laptop of NEC Versa pro NX
have you tried this ......
restart the laptop press F8 it will open to boot the laptop through various process like safe mode , last good known ..... select the last good known option and press enter .... it will boot the laptop with last setting
if this one not working then go for reinstall of xp ...for reinstall xp
  1. Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
    Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
  2. When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
  3. At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
  4. Read the Microsoft Software License Terms, and then press F8.
  5. Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
  6. Follow the instructions on the screen to complete the Windows XP Setup.
Nov 25, 2009 | Office Equipment & Supplies
How to install windows xp
Enter BIOS Set CD rom drive to first bootInsert your CD reboot
folow the on screen instructions be patient, it may take up to an hour,  and then two houers to install drivers,
-> if you want me to find the drivers for you, plz state your computer name and model.
regards /Teis
Jan 11, 2009 | Microsoft Streets and Trips 2008 for PC
Install Xp From Dos
If XP will not install from the CD or if you have a new drive with no operating system onit yet try these:
Install Windows XP from the hard drive with Windows 98 already installed:
Boot Windows 98
Insert the XP CD into your CD reader
Explore Windows XP through My Computer
Copy i386 folder to C:\
Go into C:\i386 folder and double click on winnt32.exe to launch the setup from the hard drive
Install Windows XP from DOS (ie. no OS on a new hard drive):
Boot with a Windows 98 Start Up disk
Insert the Windows 98 CD into the CD reader
Run smartdrv.exe from the Win98 directory on the windows 98 CD (file caching)
Type cd.. to back up to the root directory
Insert Windows XP CD into the CD reader
Copy the i386 folder to C:\
Go into C:\i386 folder on C: and type winnt.exe to launch the setup from the hard drive.
Oct 20, 2008 | Computers & Internet
here are some tips:
please open your BIOS setting for boot sequence and make sure your CD drive is indicated as a boot
BIOS must be set to boot from CD before hard drive.
That is, the CD drive should the be in the 1st boot sequence followed by the hard drive (2nd boot device). Then,try to follow the follwing steps:
1.Formatting an XP System Disk by booting from the XP CD is accomplished by loading the Recovery Console by typing R at the first window.
2. After selecting the Windows installation you want to access and typing in the Admin password [leave blank if no password was created] you will see a command prompt.
3. Type Map and press ENTER
4. Note the letter designation of the drive you want to format. [write it down]
5. type format x: /fs:fat32 then press ENTER, where x is the drive letter you want to format. Substitute NTFS or FAT if desired.
6. Type Y to confirm your selection and then type exit and press ENTER to restart computer.
7. To view other format commands, type format /? and press ENTER at the RC command prompt.
May 06, 2008 | Microsoft Windows XP Professional
Bought a new hard drive today, eide 320GB, and had the geek squad install it at Best Buy. I was led to believe that I could put my Windows XP in the CD Rom and install it but it is not working. Boot...
if you are wanting to install XP onto your new drive from your original XP CD, then you have to make sure you are booting from your CD drive first. If you have not partitioned the drive yet, then it will start installing on it's own. If you have partitioned and formatted already then be sure to press a key when propted to boot from CD. Make sure you are booting from your CD drive first is the most important part. Hope this solves your problem.
Apr 19, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
35 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
