Question about Nokia 6303 Cell Phone
I took backup of micro SD card of size 2 GB. then I updated my Nokia 6303i classic firmware using Nokia software Updater setup. micro SD was not password protected before update of firmware. when update got complete, phone restarted automatically. i tried to access micro SD memory , it prompted me "enter memory card password". i tried 12345, also 0000 but in vain..... plz plz help me immediately.
    Sniper:
  • 66 Answers
Try following 3 passwords:
nokia
12345
0000
Posted on Aug 27, 2010
Can u please help unlock my nokia 6303ic...
You can unlock a Nokia 6303i Classic locked to Vodafone UK using unlock code. You can get the unlock code from http://www.superunlockcodes.com/nokia-6303i-classic/rs12wp9/ at low cost.
Here are the steps for unlocking a Nokia 6303i Classic,
1 - Switch on your Nokia 6303i Classic without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6303i Classic.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6303i Classic would then display the message "SIM Restriction Off" and will be unlocked!
Aug 02, 2012 | Nokia 6303i Cell Phone
Tip
Wii - How to SoftMod, Guide.
This post will explain How to SoftMod Nintendo Wii on any firmware, Region and make its Homebrew enabler for play Wii games, backup, Homebrew applications on your wii, And all without needing a wii modchip!
Requirements: A SD card, (1GB should be enough for Installer and Backup), formatted to FAT32. Some SD card is not compatible to be used to backup the wii nand, but its work for use as boot2 of bootmii, so you might be need 2 different memory, for installation and nand backup.
Download: All files can be found **Here..!
*SD Card Pack
*cIOS38_rev14-Installer
*IOS60 Patched.
*Trucha Bug Restorer
*WAD Manager v1.4
*AnyRegion_Changer_v1_1b
*AnyTitleDeleterDB
*Backup Launcher WBKL
*Firmware Updater v4.1 -299Kb. (Need Wi-Fi connections).
*preloader v0.29 -214Kb. (OPTIONAL).
Installation Procedure:Adding Files.
  1. Extract ‘SD Card Pack’ and copy all contents to the root of SD Card, and copy a second of ‘IOS38-64-v3610.wad’ to ‘wad’ folder - ‘SD:/wad/’.
  2. Extract ‘cIOS38 rev14 Installer’, ‘Trucha Bug Restorer’, ‘WAD Manager’, ‘Any Region Changer’, and ‘Any Title Deleter’, into ‘apps’ folder - ‘SD:/apps/’.
  3. Extract ‘IOS60 Patched’ and ‘Backup Launcher WBKL’ into ‘wad’ folder - ‘SD:/wad/’
  4. Preloader is also an optional install, if you don't want it just skip.. Extract ‘Preloader’ into ‘apps’ folder. ‘SD:/apps/’.
  5. Extract ‘Firmware Updater v4.1’ into ‘apps’ folder. ‘SD:/apps/’. This updater require wi-fi connection, If you want to use offline updater, you will need wad updater (*.wad) and put its into ‘wad’ folder. IMPORTANT!! Make sure you have select the right one for your region..! E=Europe, J=Japan, U=USA, if you use a firmware from a different region, it will BRICK your Wii.!
Install BootMii & Homevrew Channel.Homevrew Channel is a channel on your wii menu that will allow you to put applications (homebrew) on your sd card and put them on your wii, this may include emulators, games, and installers.
Insert the SD card into Wii. then, Go to ‘Wii Options’ > ‘Data Management’ > ‘Channels’ > ‘SD Card’, then you will get a message saying ‘Load boot.elf?’, select ‘Yes’ and the Hackmii installer will run.
Press ‘A’ to continue, Install the ‘Homebrew Channel’ (HBC), and follow the on screen instructions. When done, the HBC will appear on wii channel.. Now go back and install ‘Bootmii’ as ‘boot2’ (recommended), if you can't install it, try different SD card. When it done, reboot your wii with it SD card, and wii will load into BootMii menu..
Backup Wii NandMaking a NAND Backup with Bootmii is highly recommended, it will recover your Wii from bricks. make sure there is at least 530MB free on SD Card.
Boot Wii into BootMii menu, if bootmii is installed as an IOS, go to the Homebrew Channel, press ‘home’ on your Wiimote then select ‘Launch Bootmii’.
Readmore...
on Aug 28, 2009 | Sony PlayStation Portable (PSP) Console
How to update software using pc
Use OVI softwARE or upgraind your phone
Jun 29, 2011 | Nokia 3110 Cellular Phone
My nokia 2700 classic phone gets shut down automatically
It is a problem with the software of your phone.Please reinstall the phone's software or update your firmware using the Nokia software updater which can be downloaded from the following link.(http://betalabs.nokia.com/apps/nokia-software-updater ).Hope you are satisfied with my solution.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Nokia Classic 2700 Cell Phone
How can i formate my cellphone Nokia 2700 classic?
Just go to Settings > Restore Factory Settings then your phone will be formatted.
You may also want to update the software.
Download the Nokia Software Updater on your computer.
Plug the phone. Make sure it is set on General.
Connect using the PC Suite mode.
Run the Nokia Software Updater, select to download the firmware for your phone then just follow the instructions.
Mar 11, 2011 | Nokia Classic 2700 Cell Phone
I forget my 2 gb sd memory card in nokia 6303i . how i unlock?
Pull out the SD card by opening the back cover of your phone, SD card slot is located near phone battery. You'll find a small lock switch on the left side of SD card, Make sure that it is slid UP in unlock position, You would not able to edit or modify if SD card is locked.
Thanks...!!
Nov 18, 2010 | Nokia 6303i Cell Phone
Micro sd card socket is not working
How big is the card. If the phone will not support it Memory card corrupted will be displayed in the memory card menu on the phone. Try checking a small card in it to see if this is the problem.
If this is not the problem, update the firmware using the Nokia Software Updater. If this doesnt solve the problem then it is a hardware problem i'm afraid.
Feb 10, 2009 | Nokia 3250 Cellular Phone
NOKIA 3110C DOES'NT WORK WITH MEMORY CARD
Dear sir,
I have Nokia 3110c mobile.When i was insert memory card(micro sd 1gp),it was continuously restarting.So please give some solution.
Jul 16, 2008 | Nokia 3110 Cellular Phone
Nokia 6303 Cell Phone Logo
174 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
