Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
It gets disconnect after a certain period. - D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
  • 75 Answers
You can fix this and many other router related problems using Router Comamander software. Router Commander prevents router from time out and disconnects, try it out for free.
Posted on Oct 04, 2010
Answering macihne won't answer, disconnects after a few minutes
unplug your unit and allow it a few minutes to reset it's self. than call it using a cell phone and see if it does the same thing. If so check you menu option and make sure that the anserwing machine is not set up to only record for a certain period of time before disconnecting the call.
Aug 03, 2008 | Uniden TRU9485 Cordless Phone
How old do you have to be to use tampons?
In theory you can use tampons if you prefer them to pads as soon as you get your period. But it's recommended to maybe wait a while until girls are more familiar with their periods and their cycle before moving to tampons but it's certainly not unsafe to do so.
Feb 27, 2013 | Health & Beauty
My Daby dehumidifier will sometimes have coade P1 show up on LED readout and also go to high fan. I have it in basement and set at 50% and low fan. What is the problem? I have to disconnect and reconnect...
don't know what the P1 code means, but maybe your demand of 50% and low fan is not able to be achieved so the unit will increase the CFMs (high speed on fan) to try and reach the 50% humidity level you are asking it to do within a certain time period.
Jun 11, 2011 | Danby DDR607EE Dehumidifier
I can't access all the time with always this error" disconnection: you were unexpected disconnection from the server" why.
There are several possible reasons why this is happening:
Many websites have servers which are set to automatically disconnect you if there is no activity for a certain period of time - this time setting could be anywhere from 1 minute to 1 hour or more.
Try visiting a different websites - most of them do not have disconnect timers. If the problem persists with other sites, it may a bad Internet connection to your low speed modem or your high speed DSL/Cable interface, depending on how you connect to the internet. If this is the case you you have to telephone your service provider for assistance.
If you believe that this information was of help to you, please rate me on the FixYa website.
Thanks,
Yavacotech
Dec 01, 2010 | Computers & Internet
I have a 2005 gmc w3500 with a turbo diesel engine. it seems to lose power at certain times and will not go over 30 mph. if you turn the engine off and restart it will run for an indifinate period of...
i had the same problem with my 2002 w3500 and what it ended up being was the butterfly valve for the exhaust brake which is located in the intake just as you take off the turbo line, disconnect the vacuum line on the actuator that goes to that valve and that should tell you if thats your problem
Nov 30, 2010 | GMC W3500 Cars & Trucks
Battery drains if parked for a couple of weeks, sometimes more.Alternator is charging, last time I went away, I disconnected the battery. Thanks, BWD
all vehicles use a certain amount of power nowadays, its the keep alive memories of the computors , radio for channels and clock etc, although this drain is minimum it will drain the battery over a period of time, just like a cell phone even if you are not using it it stays alive , either get a trickle charger of disconnect the batt , hope this helps
Sep 15, 2010 | 2000 Toyota Tundra
ERROR SC 547
Zero cross signals are not detected within a certain period within 500 ms after the main power switch has been turned on.
Possible Causes
• Power supply board defective
• Noise on the ac power line
Try conect the copier in other side.
Disconnect all the household-electric of the place.
Feb 20, 2010 | Ricoh Aficio 450 Copier
Emmisions codepo442,po446,po452,po453
These codes are for the fuel system the system performs a pressure test when the vehicle reaches a certain speed for a certain period of time, predetermined from the factory. The Gas cap is the most likely suspect.  Disconnecting battery will reset (and delete) all error codes and clear the check engine light, VSC, etc. idiot lights on the dash.
Post further comments if further you have the same problem....
Good Luck!!
Thanks
Dec 12, 2009 | 2000 Oldsmobile Bravada
It is sending a text message every time I turn it on.
The problem is that you charge the phone for such a long period time the battery is not working certain problems are starting to fail. What you can do is turn on your phone for 1 hour and then go to your setting a make sure is not in delete mode. For a certain period and it can also be your memory.
Oct 16, 2008 | T-Mobile Wing™ Smartphone
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
143 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
