Question about Kenmore 82822 Electric Dryer
My dryer will not start. Power is fine and the door is closing properly. The options lights are blinking whenever I hit start and the unit does not start
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Posted on Aug 29, 2010
Frigidaire Dryer model # LEQ1442ES0. The lights come on and beep at us like normal when I change settings but when I press start, they just blink and beep but wont turn on.
Thank you for your post, friend!
From my understanding your Frigidaire dryer is not starting and the lights just blink. It sounds like a faulty door switch or control panel. I would check to make sure the latch or door strike is not cracked or broken if the door is not closing properly that could be the cause of your dryer not starting.
You could also perform a reset on your dryer and that could help clear any faulty error codes within your dryer. To reset your dryer you would unplug the power cord for ten minutes. I hope this has been beneficial. -Matt
Oct 17, 2014 | Frigidaire Dryers
All lights are blinking on my fisher and paykl dryer ED56
it shows that machine is defective 1. may be the door lock switch may be defective 2. if the switch is ok means the motherboard of the unit is defective
Dec 25, 2013 | Fisher and Paykel DEGX1 Electric Dryer
The light on the Garage door blinks but doesn't stay on.
Three blinking lights & door won't close by Candi
(Winston-Salem, NC)
Garage door will not open and close with remotes. Three blinking lights occur when we try to close door. What does this mean? It is a Linear unit.
I will assume you mean that your garage door will open with your remote but will not close. It should close if you press and hold the wall control button until the door is fully closed.
If that is the case, the 3 blinking lights indicate that your garage door's infrared safety beams are not properly aligned.
1) Check that the operator has power. The green lights on the sender and receiver should be lit.
2) If the receiver's green light is on, but the red light is off, the receiver has power but is not detecting the infrared beam from the sender. The red light might flash when the beam is partially detected. This can be caused by
mis-alignment or something blocking the beam.
Adjust the safety beam sender and receiver while watching the receiver's red light (stay out of the beam while aligning it). When the red light stays on, the beam is aligned and your garage door should operate normally.
http://www.linearcorp.com/pdf/manuals/LCO75.pdf
NOTE: If the receiver's red light remains off, check for:
1) Dirt on the receiver's lens,
2) Sunlight shining into the receiver's lens,
3) A short in the safety beam wiring (from staples or at the operator terminals).
Dec 02, 2013 | liftmaster Garage Door 1/2 Hp
Whirpool Fronload Dryer has power, timer cycles through, but it is not running. The dryer worked two days ago when I ran a load. I went to dry a load this morning and it turns on, everything lights up...
The reasons can be a fault on the program controller unit but as the door does not close the program also will not move further. This must be the clue to the fault. Remove and check the lock and the settings. manually close the door with force and see if the program cycle starts, if not check the door switch and the control panel. Also check for output when the timer counts down. If not the controller unit must be checked for possible problems.
Nov 14, 2011 | Whirlpool GEW9250 Electric Dryer
Bosch Dryer WTL 5410 UC do nothing after selecting a program and hitting the start button. The only thing that happens is that the Drying light lits and nothing else happens. I have tried to hit start...
Door switch may still be your problem. Mine showed lights as if working when closed but I decided to use a screwdriver and push in switch all the way in. It worked then without door closed. It will stay stuck until you pull it own a bit to release it. Give it a try. The door switch appears to have two switches in it requiring it to be all the way in.
Aug 12, 2011 | Bosch Axxis WTL 5400 Dryer
Dryer won't start; all lights on; minutes just blink
well you may have a couple things wrong with your unit first check the door switch to see if its making contact telling the unit it's closed, if it doesn't read a closed circuit when pressed replace the switch if it does replace the main control board. If you are getting any fault codes you can remove the lower panel on the dryer ( 3 screws at the bottom ) and check the tech manual on what it is ( if someone did not take it ) hope this helps good luck.
Jan 09, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Sears craftsman 1/2 hp garage door troubleshooting
My garage door opener will start to close then stop and go back to the open position. If I put pressure on the door as it is closing sometimes it will close all the way and sometimes it will return to the open position. Can you help me. Thanks pbstation771@verizon.net
Aug 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Filter?
The 'check filter' is just a reminder. It is on when you turn the unit on, and at the end of the cycle.
The blinking lights, every 1/2 second is not, it is an error code. It is telling you that there is a problem with the door switch (light switch). It could be a loose wire or maybe the door is not shutting properly. Unplug the unit, take off the lid and check the connection. Replace if necessary.
Sgt 48
Oct 15, 2007 | LG DLE2512W Electric Dryer
Kenmore 82822 Electric Dryer Logo
51 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
