Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a craftsman 19.5 and the blades will not engage what is the problem?
  • 1,498 Answers
From the description provided any answer is pure conjecture.
If it produces smoke and a burned rubber smell, one or more of the blades is jammed (Could also be bearings on blade shaft)
The drive belt could be broken or loose or off
The clutch to engage blades
If manual may need adjusting
If electric, may be disconnected
Best regards
Mike
Posted on Aug 27, 2010
joboo1
  • 257 Answers
SOURCE: Craftsman 18.5 riding mower when I engage the
Hi Jeff, If you look at the deck, one or more of those pulleys is a tensioner, It pushes against the belt to tighten it, The rest of the pulleys can be identified by the fact that they only have a bolt through the middle, whereas the tensioner is mounted on an adjustable arm with a slot to allow adjustment. It should also be the only one that the belt doesn't go around the pully it just pushes on one side.If the tensioner arm is all the way to the end of the slot, the belt is streched and will need replaced but sounds like it may have come loose. Some of these decks also have a spring on the tensioner arm and those come off from a stick or other debris. Check it out and if you have a problem let me know and I will try to come up with a diagram. If your mower is that new there should be a belt diagram on the deck. i will need a model number of the deck or mower for that. Good luck!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Mar 29, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 77 Answers
SOURCE: Craftsman 18.5 42'' mower, blades won't engage
You deffinately have a loose wire or connection coming off that switch,youll have to investigate to find out where it is.
Posted on Aug 09, 2009
  • 133 Answers
SOURCE: Craftsman riding mower noise when blades engaged
With blades on and engine off reach under and wiggle each blade up and down. If you have excess play you will need bearings.
Posted on Aug 13, 2009
  • 138 Answers
SOURCE: need a blade engagement cable diagram for a 2002 craftsman lt1000
as far as i know, there is no diagram available for the cable replacement. it is covered briefly in the owner's manual, but the best way to do it is to study carefully how the old one is routed, and replace a step at a time
Posted on Aug 25, 2009
Have a craftsman EZ3 917.272121 mower engine e stalls when blade switch is pulled
If you are sitting on the tractor seat and the engine stalls when engaging the PTO mover blades I would check the switch under the seat.
This seat has a saftey switch to assure that the operator is in a safe location before engaging the the blades. Also if the blades are engaged and the operator leaves the seat the blades will stop. If a young rider with insufficient weight the blades will not engage.
26147998-f1dbbl4o5m3nghfc10hihvyr-4-0.jpg Hope this helps?
Mar 31, 2016 | Craftsman Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
Sep 19, 2008
Apr 6, 2008
Sep 25, 2015 | Cub Cadet Garden
I have a 2011 Craftsman LT2000 Model # 247.288851. The blades will only engage when I raise the deck to level 5. Ive replaced the Seat Safety Switch so Ive eliminated that. Help please! Lol
what actually engages the blades an electric clutch or a manual lever both of my craftsman mowers have elec clutch and when you pull the button the blades run deck height has nothing to do with it .
Apr 08, 2015 | Craftsman Garden
Craftsman rideing lawn mower will not go in reverse
check the linkage might be out of adjustment also for the blades check the safety switches
Apr 23, 2012 | Craftsman Garden
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
Aug 12, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Jun 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
98 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
