Question about Singer 3116 Simple
The needle is not moving up and drown when pressing the foot pump
    Genius:
  • 1,788 Answers
Is your bobbin winder lever moved to the right? Have you selected a stitch pattern? Call 1-800-4singer, and talk to customer service. You can also download a free manual from their website, google www.singerco.com
Posted on Aug 27, 2010
Our simple 3116 won't zigzag stitch,the needle is off to the right and will not do any other stitches. Help!!
It won't do straight stitch?
Take the needle out... see if it is moving the fabric when you press on the presser foot. If it is not, then you need to raise the feet (it's under the accessory box/table face. If it does move the fabric. Make sure your machine is set to Zig Zag. again without needle... sew. Does the needle bar move? change to straight stitch, does the needle bar move? If it does I think you have the wrong size needle. If it does not, I'm afraid your plastic machine has broken... take it in for repair.
Oct 04, 2014 | Singer 3116 Simple
Machine is behaving as if not getting any power, but light is on. Press foot pedal and absolutely nothing happens
There is probably a bad connection in your foot pedal. Try moving it around with your hands at the contact points while pressing to activate. If it goes when you are shifting its position then it needs to be fixed or replaced.
May 20, 2014 | Janome Sewing Machines
Needle is not moving
Of course I have to guess here--not seeing the machine, but it appears that your motor is working fine. That would leave two possibilities, I think. The first is a defective foot pedal. The second is, when you push the bobbin winder, it engages a clutch that diverts power from the needle shaft to the winder. It is possible that the clutch is stuck. To find out, disengage the bobbin winder and press the foot pedal, and see if the bobbin winder spindle is still spinning.
Jan 02, 2014 | Singer Inspiration 4206
On brother vx 1500 when press foot needle will not move
It's jammed, take off the face plates and completely unthread it. Take out all the jammed up thread and it should operate freely:) hope this helped
Sep 20, 2012 | Sewing Machines
Why isn't my husqvarna foot press not connecting giving power for my needle to move. Machine does have power but does not run when pressing foot press.
have you checked to make sure the foot pedal is connected correctly to the machine?
if the foot pedal is connected correctly, then the machine needs to be checked to see why it's not responding
Mar 27, 2012 | Sewing Machines
When sewing hems and coming across a thick seam, the pressure foot seems to not allow the material to run through, keeping it stalled while the needle continues to pump into the material eventually...
I don't think you can adjust the feed pressure on this machine. I have the same machine and the same problem and my solution is the same as you've already mentioned - raise the foot and move the fabric by hand. I would do it by turning the wheel by hand until the seam is clear of the foot to prevent breaking a needle or sewing my fingers.
Feb 06, 2011 | Brother XL-2610
The needle is stuck,not moving.its very hard and the motor makes a sound but needle does not move.
Refer to your manual and make sure the bobbin winding feature is disengaged.
Turn off the power and remove the needle and if there is fabric, remove it also.
Open the needle plate look for thread tangles.
After cleaning, turn the hand-wheel by hand to see if it moves the needle up and down.
If it does, press on the foot pedal to see if it is working.
Any of the above could be the problem.
Mar 01, 2010 | Kenmore Sewing Machines
Have Viking Husqvarna #1+ sewing machine that when filling a bobbin caused the bobbin to overfill and break. Now when pressing the foot pedal the needle will not move. I can manually turn and get the...
Make sure that the bobbin winder stop is up. That is the little black post below the bobbin winder. If it is pressed down, the machine will not run.
Feb 02, 2010 | Husqvarna Sewing Machines
Needle won't move
I had that problem too! I usually turn the tension knob and it works,
Aug 07, 2008 | White Sewing 1632 Mechanical Sewing...
Singer 3116 Simple Logo
44 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
