Question about HP G60-235DX Notebook
Can;t remove sd card from laptop - HP G60-235DX Notebook
  • 109 Answers
The memory card has a drive letter associated with it, just like a floppy, CD-ROM drive, or hard drive. Use the memory card as you would use any other drive on the computer. For example, double-click the memory card icon to open a new window showing the files on the CompactFlash card. When you have finished working with the files on a memory card, right-click the memory card icon and select Eject . The light on the memory card reader should not be ON or flashing when the card is removed from its slot.
if that does'nt work first of all .. push the card a little and then release it .. it will come out
Hope it works for you..
Posted on Aug 27, 2010
SD card location for Compaq Presario CQ50
There isn't a sd card slot on the computer the best thing you can do is buy a usb sd card reader
Jul 26, 2014 | HP Compaq Presario CQ50-110US Laptop
My card reader is gone after I remove my sd cards I have used difrent cards and it makes no diference
When you remove your sd cards in the new windows 7 update, the card reader removes itself from the list of connected devices on the computer. I have a windows 7 ;laptop with an sd card reader in it and it does the same thing. if it is still reading the cards with no problem, there is nothing to be worried about. it is like hooking up a flash drive to your computer, then it dissapears after you disconnect it. Still use the safely remove function on the windows pc. It helps keep the cards healthy so to speak.
Nov 10, 2013 | Computers & Internet
My sd port cannot read ma sd card
Remove the SD card, reboot insert the card. Is your Card reader enabled in Device Manager? Have you done any updates? install the Card Reader driver. Toshiba Support : http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Jan 17, 2013 | Toshiba C855s5214 15.6 Inch Laptop
Laptop wont read sd card
You do not say, but before ejecting an SD card you should use the Safely remove hardware feature. If you do not do so you may damage your SD card, and you run into problems such as you describe.
Apr 06, 2012 | Dell Inspiron Computers & Internet
Im not able to view video that i have recorded
This is not my area of expertise, but I have done this a few times. Depending on whether you have a removeable SD card or not, you can remove the SD card from the camera and insert it into a reader slot on your Laptop.
Then you will need to access a Media program on your computer or have the Laptop read the SD card with an Autoread setting preprogrammed in the Laptop. If you use a Media program, you would use an "Import" command to transfer the images.
If you do not have an SD reader, you will need a USB port connector to wire the images from the camera to your Laptop. Also the camera may have recorded the pictures on Internal memory without a removeable SD card. You should get the images out of the camera and onto your Laptop as a permanent location for them.
Even with an SD card in your camera, sometimes you need to set up your camera to use the SD card instead of the internal memory.
Finally, if you do have an SD card and are getting nowhere in trying to do this with your equipment, Walgreens have photo equipment which may help you transfer your movies from one Media to another.
Like people, the equipment and capabilities may vary at different locations. Finally, using a service like Walgreens may help you determine if your problem is camera based or Laptop based.
I hope that in some way my solution has helped you.
Jan 14, 2012 | Nikon Coolpix L110 Digital Camera
How do i safely eject my SD card from my macbook pro laptop ?
To remove the card, drag the SD card icon to the Trash, then remove the card from the slot after the icon disappears from your desktop. Hope this helps.
Sep 27, 2011 | Apple Customized 15" MacBook Pro Laptop...
How do I upload pictures from my Samsung Strive onto my Gateway laptop comuter.
1. Purchase a micro-SD card with an adapter for a normal-sized SD card.2. Plug in the micro-SD card to the back of the phone. Make sure the power is off when you do this, of you could unintentionally harm your phone.3. Power back on, and transfer the pictures to the micro-SD card.4. Shut the phone back off and remove the card again. Place it into the adapter.
If your Gateway laptop has a SD card reader:
5. Put the adapter into there.6. Transfer the pictures to you computer. Done!
If your laptop doesn't have a SD card reader:
5. You'll need to purchase a second adapter that adapts the regular-sized SD card to a USB port.6. Following the manufacturer's instructions, put the SD card into the second adapter.7. Transfer the pictures to your computer. Done!
Best of luck, Juseppi
Jul 09, 2011 | Samsung Strive A687 (88516535667)
I have an acer travel mate laptop and i cannot find where the files on the sd card are when it is inserted in the SD slot.
Good Day Mischa!
It depends on your system as to what drive letter it assigned to your sd card.
Your system drive is C or local drive ( C:)
If it is not partitioned or you do not use additional hard disk, the next letter will be assigned to the DVD/CD drive or CD drive ( D:)
The next letter will be assigned to any removable deviced like usb flash drive or sd card.
Removable drive ( E:) or most of the time removable drive is F:.
The files on your SD card can be explored on the removable drive in your Explorer.
And also remember, there are files that are hidden in SD card when it is infected with virus. I hope this is not your concern. If somehow you can access your SD card and can see from its properties that it used space and yet you do not see any files it is infected. Run antivirus and anti-malware.
Jun 09, 2011 | Computers & Internet
How can i use sd/mmc memory card reader on my laptop? ia am using dell inspiron 1525 model?
The SD/MMC memory slot is already configured to read standard and HDSD cards. Just remove the DELL blank from the slot by pushing it in until it clicks and release it. Then pull it out. Insert the SD/MMC card into the slot and push it in until it clicks. The DELL Blank is shorter than an actual SD/MMC card, so don't try to push the SD/MMC card any further than the 'click'. Remove by pushing in until it clicks, release, remove.
Jan 10, 2009 | Dell Inspiron 1525 Notebook
Laptop
are u sure that the SD card fits in the slot perfectly and doesnt come out?which SD card is it,is it a MINI SD or MICRO SD? because for these two u must use SD CARD ADAPTER.. only then the card will sfit in perfectly. Also when it is inserted properly and it fits in then u will hear a DING sound in ur laptop whether ur running VISTA,XP or ne other OS and also u can see the Memory card as the "name" of the card or as "REMOVABLE DISK" in "MY COMPUTER".Please confirm me with this step and ill help u out furthur.
Oct 04, 2008 | HP Pavilion dv6000z Notebook
HP G60-235DX Notebook Logo
169 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
