Question about Amana ACS3350AS Gas Kitchen Range
Self Clean won't start - Amana ACS3350AS Gas Kitchen Range
I try to start the self clean - set the time for 3 hours, after about 1 minute the oven just beeps and the panel says DOOR. I assume that it thinks that the door is open but it never latches. Auto Latch? The Light switch that turns the light on when the door is opened dosn't always work. The light switch on the panes does turn it on and off. Sometimes it seems to take an extended amount of time for the oven to just heat up.
Same problem at my apartment. When I go to push the cook button it says "door" When you lift the top of the stove off you'll see the door latch. It's just a latch for the automatic clean feature which noone ever uses. The latch gets rusty, and the connections on the two little microswitches get super corroded over time. I tried to wire brush the green scum off of them but the connections fell off. You'll probably have to replace the connections or just cut them off and jump the green and red wire together to bypass the whole thing which is what I did. Really easy fix. you first need a phillips to unscrew the metal things for the burners. Just be carefull taking the top off the stove cause the little wires that go to the gas sparker can get pinched or break.
Posted on Oct 04, 2008
Our door on this oven is coming apart, so the oven door never truly closes.  When you set the self clean cycle, push the door shut until it locks... at least this has worked for me.  But I think all your problems, which are similar to mine, result from the oven door not truly closing... heat escapes, so the temp is not right and takes forever to heat up.  The heat melts the control panel, causing other problems.  In fact, our door is starting to fall open... a bit dangerous.
Posted on May 11, 2008
How do i start self cleaning oven
To Self-Clean:
1. Press SELF CLEAN to set the clean time to HI (4 hours
30 minutes).
2. Press the TEMP/TIME "+" or "-" keypads to cycle between LO
and HI clean time.
3. Press START.
The oven door will automatically lock. The CLEAN indicator
light will be displayed. The time remaining will also be
displayed.
4. When the self-clean cycle is complete and the oven cools, the
CLEAN indicator light will turn off.
5. When the oven is completely cooled, remove ash with a damp cloth
Remove the broiler pan, grid, cookware and bakeware, all
cooking utensils, oven racks and aluminum foil and, on some
models, the temperature probe from the oven
Dec 07, 2012 | Maytag MGR5751AD Gas Kitchen Range
How to self clean hotpoint gas range model number rgb740beh3ct
To self clean that oven REMOVE THE RACKS, slide the door latch from the right to the left,push the self clean button,push the up/down arrows to set the clean time (usual clean time is 4 hours 30 minutes) push start
After the clean is over it may take a additional hour before the door will open if the latch doesn't move back easily to the the right once self clean clean is done do not force it just wait more time
GENE
Oct 10, 2011 | Hotpoint RGB745 Gas Kitchen Range
Lost Manual and would like instruction on how to set for self clean cycle?
Make sure you have everything out of the oven, including the oven racks.
1. Press SELF CLEAN.
2. Press the TEMP/TIME "+" or "-" arrow pads to enter the desired self-clean cycle.
3. Press START.
The oven door will automatically lock. The DOOR LOCKED and CLEAN indicator lights will be
displayed.
4. When the self-clean cycle is complete and the oven cools, the DOOR LOCKED and CLEAN
indicator lights will turn off.
5. When the oven is completely cooled, remove ash with a damp cloth.
Recommended times are 2 hours 30 minutes for light soil and 4 hours 30 minutes for heavy soil.
If your oven has a HI and LO self clean time, HI is 4 hours 30 minutes and LO is 3 hours 30 minutes.
It is also recommended that you remove anything plastic from the top of the stove during cleaning.
Nov 27, 2010 | Whirlpool RF263LXTQ Range
How do I clean my amana gas self cleaning oven
I have an Amana self-cleaning oven, Model AGR5715QDQ. I can't find my manual - how do I start the process of cleaning? Elizabeth
Nov 22, 2009 | Amana AGDS902 Gas Kitchen Range
Self clean oven door wouldn't unlock!
Try a trick that was given by an expert :-
All I needed to do was unscrew the 2 screws holding the lock assembly and it released it!! I screwed it back in and set the oven to self clean and it worked!!
Unless , F9 refers to slave micro not working. A condition in which you might need to replace control board.
Thanks.
Jun 04, 2009 | Amana ACS3350 Gas Kitchen Range
Oven door won't unlock
I asked for help with an Amana F9 code problem earlier today .I had set self clean oven on and then after 2 hours cancelled it. After 1/2 hr it began to beep and displaideda F9 code and I couldn't get it to unlock. Tried manual tip to turn off circuit breaker for 3 minuetes then turn back on. Did this 3 times to no avail.Tried 20 minutes also zip.Contacted Amana and all they would tell was to call a service rep. I gave her apiece of my mind that I wouln't do that because I wasn't going be paying for such an issue.
Your site was my salvation.( STP685) Suggested I push bake and once I did the oven started to heat and unlocked itself.! Thank you,thank you,thank you.
Jul 18, 2008 | Amana ACS3350 Gas Kitchen Range
Whirlpool Flat top Accubake self clean 24 inch
Of course - Empty the oven and clear off around it.
The AUTO-CLEAN cycle time is adjustable, from 2 hours
30 minutes and 4 hours 30 minutes in 15-minute increments.
Suggested clean times are 2 hours 30 minutes for light soil and
4 hours 30 minutes for heavy soil. The last 30 minutes of the
cycle is for cool down.
To Self-Clean Using AUTO-CLEAN
1. Press AUTO-CLEAN.
2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
desired self-clean cycle time.
3. Press START.
The oven door will automatically lock. The “DOOR LOCKED”
and “CLEAN” indicator lights will be displayed. The time
remaining will also be displayed.
the “DOOR LOCKED” and “CLEAN” indicator lights will turn
off.
5. Once the oven is completely cooled, remove ash with a damp
cloth.
To Delay Start Self-Clean Using AUTO-CLEAN
2. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired self-clean cycle time.
3. Press START TIME.
4. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired start time.
5. Press START.
The oven door will automatically lock. “DOOR LOCKED” and
6. When the self-clean cycle is complete and the oven cools,
off.
7. Once the oven is completely cooled, remove ash with a damp
cloth.
Owner, Warranty, Installation and Parts manuals are here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
Sometimes search links don't work when copied.
Here is the direct link to the Use and Care Guide:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
Page 16 has the above instructions.
God Bless!
-Ptochos
Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Amana ACS3350AS Gas Kitchen Range Logo
259 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De GO PATS
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
