Question about Insignia IS-DVD1001 DVD Recorder/VCR
The channel changing buttons do not work - Insignia IS-DVD1001 DVD Recorder/VCR
  • 70 Answers
If other butten works it could be a problem in the butten pls remove from the board and check with thw multimeter
normaly sevaral Mega ohm and it become to below 1k ones you press the butten
Posted on Aug 27, 2010
My Channel Up button is stuck changing the channel. How do I fix it
Is this on the remote? On the TV?
If it is the remote, replace it.
Mar 30, 2014 | Westinghouse Televison & Video
Dish network changed to snow when I tried to change station to channel 13. I pressed "power" for 5 seconds with no change.
Hi, Mary with Dish Network Customer Service here. It sounds like when you try to change channels with your remote, it is changing the channels on your TV and not your Satellite Receiver. In the top left corner of the Dish Network remote is an SAT button. When you try to change channels on the Satellite receiver this button should be lighting up. If the TV button lights up, it means the remote is working the TV. Press and release the "SAT" button after you have the picture back on the TV and it should work normally. I hope this resolves your remote issue!
Jan 12, 2011 | Toshiba Televison & Video
Channel buttons change input
Auto channel search is your friend. Once the tv has been through it and finds active channels, your channel button should work the way you envision.
Jul 06, 2017 | Toshiba 15LV505 LCD TV
Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
Jan 24, 2010 | Televison & Video
Channel button on remote will not change the channel, nor will the buttons for up channel or down channel on the side of the tv work. You can change channels only by pushing the number buttons. My dad has...
go into the menu of tv find the option to auto program- let unit go thru process without interupting it.now chanels up&down should work-the problem was there were no chanels in its memory
Sep 04, 2009 | Televison & Video
I have an shd-3010 with the remote and the channel button doesn't work nor do the buttons to change the station on the remote. Yet the power button works as does the volume buttons
Here is the solution. I have had this problem for 2 or 3 YEARS... (I finally gave up and just changed the channel manually).
The solution is exceedingly simple. You'll want to punch yourself (or at least, I did... :-P )
Press Menu. Press Menu. Press Menu (3 times total)
THEN, scroll down to "Channel Fix"
It will say either "3" or "4." What this does is it makes it so that your HDTV is always on channel 3 (or 4) when you turn on the device... AND it apparently disables the channel functions of the remote control, for some inexplicable reason.
All you have to do is change this setting from "3" or "4" to --> "OFF"
You will now have full channel and button control.
Enjoy! <(^_^<)(^'.'^)(>^_^)>
Jul 17, 2009 | Gateway SHD-3010 30 in. HD-Ready LCD...
I lost the original remote to my 27'' television
very sorry for that but you can be changing channel manually on the tv channel buttons, if you sweep on all channels you can go to AV from RF channels, that is before you buy a remote.
try to buy your remote from
www.ebay.com
Apr 28, 2009 | Televison & Video
Motorola Talkabout Basic
I believe you do not need to hold the monitor button when changing channels
Push the talk button till you have the channel you want then push monitor button to accept
Hope this works
Dec 16, 2008 | Motorola Walkie Talkie 2-Way Radio
CAN'T CHANGE CHANNEL MANUALLY AND REMOTE DOESN'T WORK
Hi again,
Many thanks for the wonderful review and the rating.
Good luck and kind regards.
Thank you again for using FixYa.
Nov 07, 2008 | Sharp LC13B6US 13 in. EDTV-Ready LCD...
RM-AV2100
Either the channel up and down buttons have both broken (unlikely) or everything else is working except the remote is not telling the device you are controlling to change the channel up or down.
Since all the other buttons are working well, that also requires that the receiving end of the pair to be working well, thus ruling out problems on that end.
Solution: Reprogram your remote to support the appropriate channel up/down codes for your TV/Tuner in question.
Dec 14, 2007 | Sony RM-AV2100 LCD Touchscreen Remote...
Insignia IS-DVD1001 DVD Recorder/VCR Logo
12 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
