Question about BenQ PB6100 Multimedia Projector
How to Use remote to forward slides of PP presentation
I need this info ASAP for a work project. I can easily forward the slides if I press enter on my laptop but this limits my ability to move around the room as I talk. I need to access the remote to forward the slides. How can I do this. Thank you. Carolyn
  • Venting May 07, 2008
    Unfortuantely my projector has no USB port to attach a USB cable to??? Can you think of anything else, perhaps how to set up the menu to make it run? Thank you, Carolyn
  • 563 Answers
Hi Carolyn
You'll see that the Projector came with a USB cable. The USB cable should be connected from your PC to your Projector and this will enable you to flick through your slides with the normal BenQ remote control.
Thanks for using Fixya !
Posted on May 06, 2008
  • Marnus Jacobs
    Marnus Jacobs May 08, 2008
    Carolyn
    I'm a BenQ ASP Technician , take my word for it that your Projector does have a USB Port.
    If you look at the back you'll see a small USB port on the right hand side. The cable has one end normal 2.0 USB and the other end has a smaller USB end on it.
Mitsubishi wd 65734
make sure the slide switch on the remote is in the TV position.
you can check to see if the remote is putting out a signal by using the camera in your wireless phone. While viewing camera point remote in to camera lens and push button on remote, you should see flashing light on camera display.
you could try resetting remote,
(1) Set the slide switch to TV position.
(2) Press and hold the POWER button
(2) until it flashes twice then release
(2) the button.
(3) Enter the code 0 0 9 3 5.
If remote still doesn't work you will need repair shop to look at it again, it's possible there is a plug inside that is not connected.
Mar 15, 2014 | Televison & Video
How do I forward the slides of a powerpoint presentation using the remote?
Make sure that you connect a cable (usually the USB cable is supplied with the projector ) from the computer to the projector. Once communication is established, normal PPT slide advancing is done by pressing the up/down arrow keys (depending on the remote control layout)
Dec 18, 2013 | Epson Projector Remote Controller...
How do I remove the video banner on the wega kdf-42we655 screen
The info banner of your HDTV is turned on. To remove or turn it off, just simply follow these steps.
1. Press Menu (on remote commander)
2. Press UP or DOWN arrow button to highlight the SETUP icon and press ENTER
3. Use Down arrow button to scroll down through the Info Banner.
4.Press Enter to select this feature.
5.Use arrow buttons to scroll through options on or off .
6.Select off and press enter button to disable the info banner.
7.Press menu to exit.
Oct 25, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
How do you get into the service menu on Samsung hcp4752w
I dont remember it exactly but ..if your TV is on then Press Standby and then press Info + Enter + Menu + Standby to turn on..you will get the service menu on screen.
Just alter the sequence of info + enter + menu to info + menu + enter or something.
hope it works
regards
bhavin
Apr 06, 2009 | Samsung HC-P4752W 47" Rear Projection...
Need code to program remote to work with Direct TV brand box.
I have the codes you need to set direct handunit for your TV.11145-10145-11960-11904-11445-11345-11045-10797-10583-10577-10413-10409-10279-10227-10173-10151-10097-10095-10056 10038-10032-10016-10105 Switch slide mode to TV make sure tv is on now press and hol MUTE&Select together untill it flashes green now enter code then press power if set turns off that will be your code if not repeat steps untill TV powers OFF.
Jan 10, 2009 | Hitachi 51UWX20B 51" Rear Projection...
Wharfedale tv key code
First try just 0000. That is the default codes for most TVs. If the box is from a cable or satellite company try the last four of your social security number or account number.
Jul 11, 2008 | Televison & Video
Kenwood kdc-mp528
You must have the remote to clear the security code. It will not work by using the keys on the display. here is the method of clearing the code.
1. When you are requested to enter the security code, while
pressing down on [AUTO] key, use a long-press on "track forward >>I" key
for 3 seconds. (----disappears.)
2. Using the remote controller, input “KCAR.”
Press remote controller [5] key 2 times and then press "track forward >>I" key. (Input for “K.”)
Press remote controller [2] key 3 times and then press "track forward >>I" key. (Input for “C.”)
Press remote controller [2] key once and then press "track forward >>I" key. (Input for “A.”)
Press remote controller [7] key 2 times and then press "track forward >>I" key. (Input for “R.”)
3. The security is released and the unit enters the STANDBY
sourcing mode.
4. If a wrong code is input, the unit goes into the Code Request
mode.
If you do not have a remote, you can take it to an authorized kenwood service center and they can do it for a small fee. My shop charges $25. Or you can order a remote from them and do it yourself, or borrow a remote from a friend who has a recent Kenwood model radio, they all work with it if the radio is new in the last 5 years or so.
Since this will clear the code if done properly, a rating of "FixYa" would be appreciated.
Thanks and let me know if you need any more help.
Dave
Jul 04, 2008 | Kenwood KDC-MP528 CD Player
Reset lamp meter on Panasonic PT-43LC14 television
While TV is on, simultaneously press and hold both the TV's Volume Down button and the remote's PP/Play button for 7 seconds.
Jun 03, 2008 | Panasonic PT-40LC12 40" Rear Projection...
TV KEY CODE
i just pressed the pp button on remote (3) times and lo and behold it worked happy days
JOHN
Feb 20, 2008 | Televison & Video
BenQ PB6100 Multimedia Projector Logo
322 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
