Question about Euro-Pro UV209 Upright Vacuum
How do I fix the overheating problem with my shark upright vacuum the website said someone has fixed it and i was wondering how?
SOURCE: no suction with Eureka Boss Pro Lightweight Bagless Upright, 411A
I checked the vacuum hose to see if there was a clog. 1st, disconnect the hose from the unit so you have access to both ends. Now, place a marble or other ball in one of the hose and see if it will make it all the way through. I found a major "hairball" about 8-10 in down from the vacuum end. I took a metal cloths hanger and bent it in half and did a "roto-rooter operation. It took about 30 minutes, but now it runs like new. I hope this works for you.
Posted on Nov 17, 2008
SOURCE: Shark Pursuit Euro-pro X vacuum cleaner, 12 amp, upright model
This vacum cleaner is equipped for auto shut off when it gets hot , It gets hot when it gets clogged either the little sponge filter is to dirty or the the round white filter in the dust collecting container.
But if they are both clean then it is clogged in the line probably with lot of carpet fiber, in that case you ned to take the dust container out and possibly the assembly from bottom like when you change the belt, then take of the Handle where the flex hose is attached, then you gonna need a wire hanger bend a long shape close to the shape of the hose line from handle to where it curved around in the bottom opening where it collects the dust behind the spin brush the just stick the hanger from the handle side cause the clog is probably in the lower side then just push the clogs out . Be care full not to puncture the flex hose with hanger. Its probably a good idea to bent the tip of the hanger so that it wont poke hole in the flex hose.
That's what happened with mine I spend hours and hours and days to figure it out. I could have just through it away, but it just kind a pissed me off and the War was on as stubborn as i am, but finally I won and I got the satisfaction of the sweet victory.
Waste lot of time though but it just one of those things. It never messed with me again.
But that is what's wrong with it. Good luck it a good vacum though very power full.
Posted on Apr 17, 2011
reddevil6
  • 1673 Answers
SOURCE: Shark Euro Pro upright vacuum V1310RS
Most vacuums you either remove the bottom plate, or the top cover comes off. If no screws on the top cover, then turn vac. over and remove the screws on the bottom. Then you should be able to get to the brush roll and belt.
Posted on Feb 17, 2008
reddevil6
  • 1673 Answers
SOURCE: Sebo X1 vacuum not working
The X1 has a servo motor with gear box, this is what adjusts for height. Either something has jammed it, or
it has gone bad. You would probably be looking at a $80 to $100 repair, that is if the servo is bad. There also is a computer controller circuit board which could be the problem.
Posted on Mar 13, 2008
dodge_is
  • 42 Answers
SOURCE: Shark euro-pro x upright vacuum that shuts down every 15 minutes
These are prone to overheating. The manufacturer put a foam 'filter' wrap around the electric motor. This filter wrap insulates the motor, trapping heat inside, which causes overheating. The motor is very similar in form and function to the one in the Hoover Windtunnel, but the Windtunnel has no filter wrap. It doesn't overheat, and functions fine without it. There is a filter on the intake anyway. It's a redundant filter, and I have removed mine. It works fine now.
If you take the filter out yourself, you will need a special screwdriver for one of the motor cover screws. I guess they don't want the consumers opening it up.
I suggest taking it to a vacuum repair shop and explaining to them the problem, and asking them to remove the filter wrap from the motor.
Posted on Feb 23, 2010
Shark rocket is blowing not sucking
Hello, this is Ava with Think Crucial.
You would need to clean the tubes and every hose from any clogged particles or blockage and it will fix the problem. You can also check this video tutorial on how you can fix the issue by clicking the video link below:
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Aug 17, 2016 | Shark Rocket Ultra-Light Upright Vacuum...
I have a shark navigator upright and the clips on the sides of the tank won't stay clipped is there anyway I can fix this.
Make sure that all the seals are clean and there is no obstructions. Thank you Sally and have a fruitful day. Please leave feedback for I am a newbie!
Jul 13, 2016 | Shark Navigator Bagless Upright Vacuum
Shark loss of suction hole on side
throw it away. It cannot be fixed. Shark does not make repair parts.
Sep 02, 2014 | Euro-Pro NV22 Shark Navigator Bagless...
Any idea where to find a replacement roller brush for the shark navigator motor head?
Did you try the Shark website?
http://www.sharkclean.com/support/parts-accessories/11/vacuums/
May 27, 2014 | Shark Helmet NV22L Shark Navigator Upright...
My shark navigater lift away hose came off. How can I fix this?
it should just snap right back into place if not you need to get a hole new hose
Mar 18, 2014 | Shark Navigator Bagless Upright Vacuum
I just bought a shark navigator and when i turn it on it shocks me. any quick fixes or do i need to take it back?
Take it back. Getting shocked is a serious problem that can cause fire and can possibly be fatal.
Mar 01, 2014 | Shark Navigator Bagless Upright Vacuum
Shark navigator power button is stuck
Go to Shark's website. You may get it fixed under warranty.
Feb 13, 2014 | Shark Navigator gray canister bagless pet...
Beater bar is not working
Shark Rotator Troubleshooting - YouTube
? 10:35
www.youtube.com/watch?v=H_dovG2javs
Oct 23, 2012 - Uploaded by VacBin
I show you how to fix common problems with the Shark Rotator..... I have Shark Rotator Prof Liftaway and ...
Feb 01, 2014 | Shark Rotator Professional Bagless Upright...
I need a new roller bar or beater brush for infinity vacuum
Hi There,
Here's a link to that part on our website if you haven't found it already:
Euro-Pro Shark Infinity NV30, NV31 Bagless Upright Roller Brush Assembly
Also if you need belts for this machine, here's another link to the belts on our website:
Euro-Pro Shark Replacement Belt Set For Shark Infinity Upright Models, Part 1085F
I hope that this information helped you. If it did, please be sure to rate the repair helpful by clicking the thumbs up icon in the top right hand corner of the repair.
Thanks again,
Chris J.
GoVacuum.com
Apr 14, 2010 | Euro-Pro NV31 Infinity Vacuum
Jan 11, 2010 | Euro-Pro UV209 Upright Vacuum
Euro-Pro UV209 Upright Vacuum Logo
6,623 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
