Question about Whirlpool Duet GHW9150P Front Load Washer
The drum on my front loader is dragging and wearing against the plastic which is shreading off
    President:
  • 670 Answers
Sounds like one of the support arms holding the inner drum has failed. It is very expensive to repair, most of the time a new washer would be the cheaper than the repair. Sorry
Posted on Aug 27, 2010
During spin cycle the washer makes a loud thumping noise. Not a clanging/sharp noise. When I manually turn drum it sounds like something is loose inside. Like a ball may sound inside drum as it turns.
Is it a front loader? You may have something stuck between the tubs or it may be a broken "paddle" One of the plastic baffles that move the clothes around in the tub. they should all be tightly against the tub.
May 26, 2015 | Washing Machines
Kenmore elite washer troubleshooting
Sounds like your bearings are worn and need replacing... a horrible job. The frayed plastic may mean a new drum. To replace the bearings you must remove and separate the drum which requires removing the top, front, and back panels. Lots of clips, screws, hoses, wires.... I'd take it on if this were my unit; but for a client, I'd say get a new one. This is not uncommon for these units. Sorry.
Feb 16, 2014 | Washing Machines
Whirpool 9400 Nylon ring shreading on drum
is the drum loose can you feel movement and is it getting noisy
Dec 05, 2011 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Bosch WFMC 4300UC Front Loader ,something dragging on the drum.
sounds like the bogie wheels on the drum are wearing out or the main bearing in the rear of the drum expensive to replace bearing if that is the problem i would call manufacturer and explain the problem they should be able to help you
Dec 22, 2009 | Washing Machines
LG front Loader Intellowasher 7kg WD-8015c has been on a quick 30 mins cyle and is still going after 1 hours just keeps spinning and won't turn off
I have the EXACT same problem wit the LG 8015C. After numerous attempts, I finally found the problem. A set of wires attached to the drum body vibrates against th erear panel, wears off the plastic insulation, shorts and blows the circuit board. All because of sloppy workmanship ! It took 4 years of easy work for this to occur. Will NEVER buy an LG or Front Loader again
Sep 18, 2009 | Washing Machines
The drum bangs against the washer during the fast spin. Pieces of plastic broke off. What could be the problem.
If your drum is belt driven, it may need adjustment. It should run straight from the motor wheel, directly around the barrel circumference. Chec for excessive wear. GOOD LUCK.....ABORN
Aug 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Plastic part that the drum rolls on next to the door is broken
Yes that is a very common problem and they are available through G.E or your local appliance parts house...they are fairly easy to change........Be sure not to overload your machine excesive drum weight will cause them to wear out alot faster
Jun 28, 2009 | GE DWSR483EBWW Electric Dryer
I am considering purchasing a front load GE washing machine. I am curious if the inner drum and the outer drum are both metal? I am comparing the advantages of the GE front load with the Miele and the...
I can't speak for all, but my GE front loader has a stainless inner and a plastic outer tub. I don't know what the benefit of a all metal would be. The plastic outer tub seems to hold up fine, The only problems I have expereinced with the washer tubs were the bearing going bad after the seal failed, but its 10 years old. I consider that normal wear.
Jan 08, 2009 | Washing Machines
A hard plastic liner from my front loader dryer has broken off and now the dryer makes a loud noise when drying.
This sounds like one of the drum front plastic bearings has come out or broken, there can be as many as 4 or more of these bearings depending on make, you would need to replace all bearings regardless off wear.
Again, depending on make, this can be quite a job to do ,and on some makes it involves a strip down.Plz rate my solution.
Thanks.
Dec 29, 2008 | Dryers
Front loader washing machine - noisy spin cycle
A service engineer told me he thought there was a piece of wire caught behind drum and to see if it worked its way out. It hasn't because I don't think he's right. On spin the noise is sometimes so loud it sounds like the bearings have gone. Today I removed the fluff filter and discovered what appears to be shreaded grey plastic. If I can get a copy of the machine spec I might be able to discover where this has come from. Sorry this is not a solution. But as your symptoms are so similar check your filter and see if its full of shreaded plastic.
Sep 23, 2007 | Electrolux EW1000i Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
53 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
