Question about Lincoln Welding Tools
I HAVE A LINCOLN WELD -PAK HD MODEL# K-21881 AND THE PROBLEM THAT I'M HAVE IS, WHEN PRESSING THE TRIGER IT DONT WANT TO FEED THE WIRE IT SEEMS TO CLICK IN SIDE THE WELDER. NOTHING SEEMS TO WORK!!! CAN YOU HELP?
5 Suggested Answers
97F350diesel
  • 1326 Answers
SOURCE: My lincoln welder lost its heat penetration
It only produces 100amps. You can only weld thinner metal 3/16" comfortably. Any thicker will resuld in less/no penetration.
Posted on Sep 22, 2009
KrisJohn1
  • 7 Answers
SOURCE: Lincoln Weld Pak 100 arc welder troubleshooting
There can be a switch that makes the wire electrically "dead" so it can be fed through the liner. Also suitcase style welders have a sensor wire with a clamp that must be connected for the arc to be able to be struck.
Posted on Nov 24, 2009
  • 60 Answers
SOURCE: my lincoln wire feed welder while welding,the weld
try changing the tip and make sure your ground connection is good on the steel and in the machine sometimes the ground wire in the machine comes loose
Posted on Nov 20, 2010
Testimonial: "thanks so much."
luis_david
  • 407 Answers
SOURCE: Where can I get a gas diffuser for a Lincoln
Gas diffusers are sold at any welding store, look up praxair site for your nearest location. The part number you are looking for is: TWE-35-50 about 6.00 bucks or less.
Posted on Jun 14, 2011
I have no gasflow it sounds as if the gas is leaking at the feed rolls
there is no seal at the feed rollers around the wire as it requires the correct gauge wire and feed hole to slow down the loss of gas at that point ( easier for the gas to escape up the wire housing and out the welding end )
the gas is allowed to flow when the welding trigger is operated as that opens a gas solenoid that allows gas to the welding wire tube to exit past the shroud around the welding point
read you user manual well to be acquainted with the machines operation, and if there is a persisting problem talk with your supplier and consider a warranty service check
Sep 15, 2016 | Lincoln Electric Weld Pak 140 HD Wire Feed...
Weld-pak 100 Hd Problem
There is a reset button located in the wire feed spool compartment,
check to see it stays in when pushed. It is a safety when the machine
overheats, it normally resets when machine cools off. If it is working properly I suggest contacting Lincoln Electric Dealer for service.
Mar 03, 2012 | Lincoln Welding Tools
Where can I get a gas diffuser for a Lincoln Electric Weld Pak HD wire feed welder?
Jun 13, 2011 | Lincoln Electric Welding Tools
I have a lincoln weld pack 100 hd, and i want to weld aluminum but i dont know how to start. i buy a 4043 fil d aluminium mig and i dont know if my welder it ill be fine to weld,
you can weld aluminum with the lincoln but you will need to change the liner in the wand to a nylon one and swich the gas to 100% argon and of course change the wire to an aluminum roll. and practice-practice-practice it is much more difficult to weld aluminum then steel and requires much more control.
Feb 03, 2011 | Lincoln Welding Tools
My weld pak 100 will not feed the wire
you Ned to check if the voltage selector is in good condition if not replaced.
Jan 03, 2011 | Lincoln Electric Century Portable Plasma...
I have a Lincoln Weld Pak 100 that was working fine. I shut down the machine though and when I came back to it about 5 hours later the wire feed motor wouldn't turn anymore. Has anybody else had the same...
Check the voltage at the wire feed motor when the trigger is pulled.
I had a Weld Pak 100 that with 0 volts at the wire feed motor, and the problem wound up being that 2 of the big power (stud) diodes were shorted.
Feb 26, 2010 | Welding Tools
Lincoln weld pak 100. The wire jams in the hose. it is feeding pro... the wire jams in the hose. it is feeding properly but the wire gets hung up a foot or 2 before the nozzle. More the wire jams in the...
In your other post I had mentioned installing a Teflon liner that would help with the wire.It narrows the gap in the hose and gives it a more easier feed.
Jan 10, 2010 | Saws
Lincoln SP-135T Does nothing Please HELP
a mig welder must have a good ground to work, also dont try using rusty wire it will jam in the liner, have you checked you are getting wire feed from the neck? just pull the tright and with the welder on it should feed out, if you can stop it its to loos tighten up the pinch roller, is there power on this wire feed? i have often seen new welders strick up the weld with to slow a wire feed and to many amps running, what happens then is it burns the wire away in one flash, right up inside the welding tip and every thing comes to a grinding holt then???? it can and often will just weld the wire into the tip,, witch may mean a new tip is needed, take off the shroud and try to unscrewing the tip if no wire comes out when you pull the triger
as the wire is stuck or welded to it you may be able to get it out still??? but its best to fit a new one in, go one size bigger than the wire your using at first as you are sure to get it very hot??? untill you get the hang of welding,,, use a good gas mix like argon light it will weld stanless steel as well?? but co2 works well on miled steel only, the problem with co2 is its a cold gas and you need a lot more amps to weld the same thickness of steel use it at about 2 to 4 psi only indoors, out doors use it at 4 - 6 psi and if out doors keep out of the wind as much as you can or it will only blow the gas away from your weld if that happens you cant weld without gas being there as a sheeld, dont try using a no gas welder they are like the devel having a bad hair day to use,
even a good welder wont like one? there c*ap!!!!
only try welding clean steel not rusty steel or it will spit like mad at you and you wont get a good weld,
if at all,,one of the most common fults that is
but i bet you have weded the wire to your tip?
its so easy to do at first,,only two word of warning
keep well raped up, sparks well fly and were gloves',,,
and keep your head sheeld on well over your eyes dont ever ever look at the welder when welding it will burn your eyes realy bad and you will wake up in the night feling like some git has just pored sand into your eyes and its going to hert like hell for day's,,,
i find the solor head sheel is far better, its nearly clear when not welding and go's dark in milliseconds you will like them as you can see what you are doing right up till you strick up the ark then it go's dark,,
most welders last for years iv had mine for the last 35 years it a clark 150 turbo mig, and iv doged it to death too,,,
the only thing that could realy go wrong inside them is the rectifier, mains coil or a relay,, not much left in it to go wrong ,
and now iv bored to death good luck with your welding ,,i hope this has helped you out
Oct 26, 2009 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Welding Tools Logo
48 people viewed this question
Top Lincoln Welding Tools Experts
joe2639
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
