Question about HTC Hero Smartphone
Have the htc hero 200. power button does not work at all. anyway to turn the phone on without the power button?
  • 13 more comments
  • Anonymous Mar 11, 2014
    remove cmos battery toshiba satellite p20
    problema en la caja detergente
    i need to replace the regulator on my 1950's 6 burner commercial wolf range, where do i find a part?
    2008 seabring convertible hardtop was stopped prior to completeing the cycle
    Discovery has an incorrect e-mail address for me and has requested that I change this to the correct address . How do I do this as I have no phone ?
    P.M.van Schalkwyk
    what more do you require?
    membership no. 271596721
    ID 3104030046087
    previous Addresses:
    PO Box 67323 Bryanston 2021
    Johannesburg SA
    Res. 23 Saddlebrook Place
    Meadowbrook Lane Epsom Downs
    brother pe 770 machine is sewing with the bobbing has anyone had this problem? I am thinking my machine may need a new tension spring
    We do not want the spray faucet on a moen dual handel faucet. Hod do we do it
    soft brake pedal
    my keurig says "brewing" but does not brew the coffee
  • Anonymous Mar 12, 2014
    water doesn't stop filling in kenmore 80 series washing machine
    the spinner on the bottom of the clock is suppose to spin, how do i get it to work
    are mp4 players the same as a mp3 player
    how to make an owl box
    water light stays on machine wont do anything else
    oven door won't shut properly at the top of door, a gap lets all the heat out
  • 944 Answers
No,there is now way you can turn the phone without power button.
This is hardware related.
If you take a look at the inside of the power button, there are 2 points making contact when you press the button.
If you press it, the software will recognize this and the screen will turn off.
If you press it long enough you'll get the "Do you want to turn off your device" message.
But, if water gets underneath the button, the 2 points may be making contact, because water/alcohol conducts.
if the button is very weak. Due to this, it may not properly work if you have used it for a long time.
Just open the HTC hero and clean the contacts and try again.If not working water may be poured on it.Check for the water marks on the boards.Then you have to replace the board or solder or re-hot it accordingly.
If you don't have hand on in it.Please take it to nearest service centre.
post a comment for further assistance.
thank you for using fixya have a nice day:-)
Posted on Aug 27, 2010
How to reset htc hero with no email or pssword from sprint
With the phone turned off, press and hold the HOME and BACK buttons, and then briefly press the POWER button. After the phone is restored to its factory default settings, press MENU to reset it.
Mar 01, 2013 | HTC Hero Smartphone
Forgot my password
Have you selected the forgot password button?
Jun 18, 2012 | HTC Hero 200 - Silver sprint Smartphone...
I forgot my drawin pattern on my htc hero how can i unlock it
Factory Reset the phone but it will erase everything from your phone.
To reset the phone using phone buttons
  1. With the phone turned off, press and hold the HOME and BACK buttons, and then briefly press the END CALL/POWER button. The reset process will start after a few seconds.
  2. Wait for the phone to finish the reset process and then press MENU.
Oct 23, 2011 | HTC Hero Smartphone
I NEED THE UNLOCK CODE FOR A SPRINT HTC HERO 200
you can Unlock your HTC HERO 200 with imei unlock code. it is very simple and eaisiat way to unlock your HTC HERO 200 . get your HTC HERO 200 Imei Unlock Code . and use any gsm sim card.
i hope this will help you .
Oct 05, 2011 | HTC Hero Smartphone
I connect the charger of my htc hero. at first it was charging. after an hour i noticed that it stopped from charging. when i turned on my phone it didn,t open.
Open the back cover , take the battery out . Press and hold the power button without the battery . Put the battery back in . Try to power it on .
If that doesnt work try below steps , ( note : you will loose your data )
Power the device OFF. Press and hold the HOME and Back Arrow buttons. While holding these buttons, press the End Call button once. Release the Home and Back Arrow buttons and press the Trackball to execute the Hard Reset. The device will reboot once the process is complete.
Thumps for my solution if it works .
Aug 15, 2011 | HTC Hero Smartphone
My power button doesnt work anymore
Mine turns on when I plug the charger into it. Have you tried that?
Jul 04, 2010 | HTC Hero Smartphone
HTC HERO SMART PHONE
To turn the phone off, you need to first get past the screen lock and get to the phone. Then you need to hold down the red end call button. Hold it down long enough to get a popup menu. The top option is "Power off". Select this and it will ask for a confirmation to shut off the phone.
Good luck.
Jan 18, 2010 | HTC Hero Smartphone
Flash player not working on my hero.
The Flash support for the Hero is still very limited. I think they advertise it as Flash Lite, so you will not get full Flash content loading properly on your phone.
The other issue you may be experiencing is that you have plug-ins disabled from your Browser settings. Flash is a plug-in that needs to be turned on. With your Browser up, go to Menu > More > Settings > Enable plugins.
Good luck.
Jan 08, 2010 | HTC Hero Smartphone
HTC Hero will not turn on. Phone shut itself off
I have a Droid Eris by HTC, on start up it freezes at the first screen showing the three Android men. I have let the bat. run down, taken it out and it still stays the same. I followed the instructions on the Verison site showing you how to hard reboot, but still nothing. The only change was I came to a screen with a red triangle with a exclamation mark in it with a phone in the back ground. Please help.
Dec 02, 2009 | HTC Hero Smartphone
HTC Hero Smartphone Logo
581 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
