Question about Cub Cadet Garden
Cub cadet 1405, has new battery & starter. cranks over great with plug removed , won' t crank at all with spark plug in. any ideas?
  • 183 Answers
You didn't indicate which engine we are working on, but here are a couple of ideas.
It is possible that the starter is weak. If this is the problem, replace the starter.
It is also possible that the compression release is not working. Try adjusting the valves back to factory specs.
Good Luck!
Posted on Aug 27, 2010
  • mcfaddin_m Sep 07, 2010
    thanks, guess i better get a service manual or a big hammer! ill get back later with more details, thanks agin M.
I have a cub cadet GT 2550. Has new battery cranks but will not start. Thinking it's not getting fuel. Checked fuel filter and fuel flows through.
If spraying starter fluid in the intake causes it to run for a few seconds, then you have a fuel problem. That starter fluid is the fuel. If it didn't have spark, it still wouldn't run. I would start checking the carb and make sure nothing is stuck or plugged.
Apr 18, 2017 | Motorcycles
Hi I did a tune up ,changed and checked every thing I done ..too I changed the oil ,oil filter ,gas filter air filter ,got a new battery changed the plugs there new too...even a new belt new key ...but...
Spark and gas??? Must have both. Pull spark plug wire and check for spark. If you have spark, check gap on spark plug. Check the bowl on carburetor. loosen bowl screw to see if gas is coming out. If you have gas coming out, carb needs to be taken off and cleaned or rebuilt.
Oct 11, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
My cub cadet 221 cranks won't start
Clean your carb, if you have not stored it correctly you have a dirty carb now. Carb could be gummed up.
Feb 17, 2013 | Cub Cadet Snow Blowers. 21 in....
Won't turn over
you probably have a bad starter solenoid. You can check it by jumping across the two terminals. If it cranks over then it is bad, if it doesn't then you have another problem and need to check the battery cable connections and/or starter, but I would look at the solenoid first
Jan 15, 2013 | Cub Cadet Garden
CUB CADET RZT 50 VT WILL NOT CRANK. TAKE OUT ONE SPARK PLUG WILL CRANK. PUT PLUG BACK IN AND WILL CRANK AND START. WONDERING WHY?
It may have just been a bad connection to the spark plug. By taking the wire on and off you may have cleaned it enough to work. Also the cable may have some trouble and removing and reinstalling put it in a different position.
Apr 21, 2012 | Garden
My cub cadet model lt 1018 crank but will not start. battery fully charged . fresh fuel . new carb . new started motor
Hi pepeq5314, has it ever run with the new carbuerator? For now lets assume its fine. Time to check for spark. Remove the spark plug, once it is out reconnect plug wire, ground the plug to engine block by holding the base of the plug to block. Now crank it over and see if it is sparking. If no spark you have ignition problem. If it does have spark, back to the carbuerator. You can put a little fuel directy into cylnder through the spark plug hole and crank it and see if it pops. If it does, you have a fuel problem. Remove the line into carbuerator and make sure you have fuel flowing to it. If you do have fuel flow check adjustments. Hope these tips help.
Jan 04, 2011 | Garden
I have a Cub Cadet that wont start.
Easy check is your cable connections and condition. Next would be to remove the starter and test it. Then check the solenoid.
Apr 27, 2010 | Garden
Cutting grass.heard loud Pop tractor shut Cub Cadet 1210 Hydro
just trace the spark plug wire to the coil but you can check the spark by putting a new plug in the wire and make sure it is grounded and turn the engine over if you have spark then you have to pull the fly wheel off and check the fly wheel key
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
254 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
