Question about Sirius Satellite Radio Receiver
Antenna Wire Cut
Is it possible to splice together the antenna wire? If so, can you give me some guidance? Or is it possible to put a new plug a cut antenna wire?
Thanks, Ray rmcgrew@olneydailymail.com
    Problem Solver:
  • 35 Answers
I would not advise this...just go get a new one at radio shack or circuit city, some times this splicing is ok, but then again...it may not work...I am for getting anew one.
Posted on May 10, 2008
Can the antenna wire be soldered back together after being cut?
yes / or taped together ( just make sure outa wire is not touching inside wire ) it will cause bad reception
Apr 23, 2015 | Cars & Trucks
Sirius radio antenna cut, can I splice it?
Buy a new one on eBay....they're about 15 bucks.
Aug 29, 2012 | Sirius Satellite Radio Receiver
My antenna wire was cut at the antenna on my 1991 corvette. Is there an other plug in comewhere along the body
Hi this is Bishop.The easyest way is to find the spliced wire and tye a string to it TIGHT take the radio out and pull the antenna wire slowley untill the string comes.
Jul 06, 2012 | 1991 Chevrolet Corvette
Can sirius antennas be cut and spliced back together
If your antenna cable has been cut or severed, it can be repaired without the need for a replacement.
You will need the following things:
Small 600 degree soldering iron and solder.
Liquid flux for soldering the braid.
Small sizes of heat shrink tubing.
Small heat gun.
Small pliers, cutter, and Xacto knife.
1) The first step is to use the Xacto knife to cut both ends of the antenna cable so you have a clean end.
2) Using the Xacto knife roll the cable on a board and gently cut all around the cable to cut the outer insulation. Remove about 1/2 inch of the insulation from each end.
3) Push the braid back to expose the center wire and gently roll the cable and cut the center insulation to expose about 1/10 inch of the center wire. With your small long nose pliers, bend the center wire into a small hook shape.
4) Repeat all the above steps on the other end of the wire.
5) Put a 1 inch piece of heat shrink tubing on one end ( the black piece), and a 1/4 inch piece of heat shrink (the white piece) on the center conductor. Look at the picture to see this.
5) Hook the two ends together. Gently squeeze the hooks closed and solder them together. Be very careful when soldering this. Be quick so you do not apply to much heat and cause the heat shrink tubing to shrink on the side where you do not want it to be.
6) Slide the small white heat shrink to cover the cooled solder joint you just made and use the heat gun to shrink the tubing in place.
7) Now push the braids back together to cover over the connection you just made. Try make the braid smooth together by GENTLY rolling the cable between your fingers. Carefully solder the braid. A little liquid flux on the braid prior to soldering helps the solder flow and makes it look better.
8) Slide the final piece of heat shrink tubing over the braid and shrink it with the heat gun.
Jun 12, 2009 | Sirius Satellite Radio Receiver
My computer speaker wire has a short.
The audio cables normally have only two wires in them, one being shielded the other not. You should be able to splice the two together to fix the problem, if there is no colour coding you wont cause any damage to anything if you get them back to front the first time round guessing.
Mar 16, 2009 | Dell Computers & Internet
Does antennas disconnect from back of radio or further down?
Yes it does but in most cases, you need to at least partially remove radio to do it. Booster probably came with instructions. Read & follow them. Unless your'e experienced in this stuff, do NOT cut antenna wire & attempt a splice.
Dec 28, 2008 | 2006 Chevrolet Silverado 1500HD
2004 power antenna
You dont actually have to take the antenna out of the car fender or where it sits, if you can remove the radio out of its deck and locate the power antenna wire just unplug it or cut it and tape it up and u should be ok. In most cases the color is blue, but if possible you want to test it to make sure. Also if u can get to the power antenna cables in the antenna location itself you can also cut or unplug the Antenna remote turn on wire, which should be blue as well. If u have any more questions just email me.
Good luck.
Jun 12, 2008 | 2004 Mitsubishi Montero
Extending the Antenna wire to reach new deck
If it is a Chevy then the antenna wire will not fit in the first place. best buy sells an adapter that ill extend that wire and make it the right size. The wire is like 7 to 10 dollars.
Apr 14, 2008 | Kenwood KDC-MP235 CD Player
Deck
connect all of the speaker wires and remote antenna and amp turn on leads first. connect the antenna coax and ground wire. then apply the memory and hot wires. if you experience ignition noise at low volumes cut the ground wire and let the headunit ground through the antenna jack (providing you don't have a floating ground system (i.e., if all speaker grounds are tied together)).
Jan 01, 2008 | Car Audio & Video
Its a sharp bookshelf system model xl ???
take a piece of tv twin line antenna wire. cut a length about three feet long. strip both ends and twist the two wires together and solder. in the middle of one side, cut the conductor and bring out the two leads. now cut another piece of twin lead about six feet long and strip both ends.splice one end. one conductor each into the midpoint cut. what you have formed is loop antenna commonly called a YAGI. connect the other two wires to your receiver and try it.
Sep 07, 2007 | Teac SR-L35 Clock Radio
Sirius Satellite Radio Receiver Logo
422 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
