Question about Brother LS-2125 Mechanical Sewing Machine
My foot part wont work - Brother LS-2125 Mechanical Sewing Machine
    Genius:
  • 1,788 Answers
Call Brother at 1-877-276-8437. You really have to be more specific about your problem.
Posted on Aug 27, 2010
Why wont the pedal control work?
It might be busted, bring the machine and foot control to a Brother repair shop so they can try your foot control on another machine, and so they can try another foot control on your machine.
It may be the controller, or the wiring, of the plug or the....
Oct 17, 2014 | Brother Sewing Machines
I have error C7 on singer one plus and it wont sew at all?
I was getting a C7 error on my Singer Heritage sewing machine every time I pushed the pressure foot. I decided to see if the reverse sewing button would work and it did. Then I pushed the pressure foot to sew again and it worked. Hope this helps someone else.
Jan 27, 2013 | Singer Sewing Machines
My presser foot lever wont move
it sounds like the machine needs to be serviced
May 28, 2012 | Sewing Machines
Took my foot pedal apart, now it wont work at all, just makes a clicking sound when trying to put my foot down on it..
Hello
Unplug the machine plug and wall plug on the sewing machine.
Check the power cord for cracks, burns, or faulty contacts as this could be a possible reason for the foot control not working.
Open the foot control by using a knife or flat surface tool, such as a flathead screwdriver, to pry open the corner of the foot control.
Check the wires to see if they are disconnected; this can happen if the foot control drops to the ground. To check wires, remove the circuit board using a flat knife. Inspect the wires inside the foot control. You will see some wires that are soldered together. Check to see if there are any broken wires, as this could be the problem. If the wire is broken, clean the area to remove any debris or dirt. Remove a small amount of the insulation before soldering. Solder wires together.
When you are done, reassemble the foot control and make sure it's working again.
Jul 12, 2011 | PfaFF Creative 7570
Presser foot stopped working I turned
Did you connect your machine then press the foot control before you lowered you presser foot? I have a CS6000 and that is what E1 means on my machine. You did not put your model number in so I don't know. You can look in your manual or go online to www.brother-usa.com and look it up for your machine. Try unplugging and plugging it in again, but put your presser foot down then step on your foot pedal.
Oct 04, 2010 | Brother Sewing Machines
Machine wont stop once started.
your foot pedal is just like an accelerator , lifting and pressing the foot increases and decreases the speed ,but if this does not happen ,,change your foot pedal
Mar 18, 2010 | Singer Sewing Machines
Kenmore foot peddle going too fast to sew
The problem is either in the foot control or there is a short in your wiring. You can replace the foot control and hope that's where the problem is or Take it to a technician to be sure..The foot control will probably cost around $30-$50.
sewman7
Jun 30, 2008 | Kenmore 15208 Mechanical Sewing Machine
Presser foot wont raise and lower
Does the presser foot move at all when the machine is first turned on?
Do the needle and feed teeth calibrate when the machine is first turned on?
You probably need to locate your nearest authorized repair center.
May 05, 2008 | Husqvarna Designer I
Brother LS-2125 Mechanical Sewing Machine Logo
13 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
