Question about Canon imageRUNNER C3200 Copier
Re: canon ir3100cn E000020-0081
Hi
We bought a used ir3100cn from the UK and shipped it to our home country. before shipping it we have tested the copier by making around 1000 colour copies (total copies+print counr 67k). However after the shippemnt, copier glass was broken and then we got a E000225-0001 code. then we replaced the glass error code gone but we got another one.
now we getting E000020-0081. we cleaned the toner area, but still we getting it. i would be greatful if you give some assistant to solve this problem as in our country not easy to find a expert on these copiers.
Thanks
Eeel
  • jeff heightchew
    jeff heightchew May 11, 2010
    Hello Eeel,
    I heve been a field engineer working on Canon copiers for over 20 years. But there was a gap in my exposure to Canon equipment while I helped roll out our company's newly aquired RICOH product line. The ir3100 fell in this gap area. I went to the Canon technical support site and despite the fact I am not trained on that device, apparently my previous training and new training since that machine provides me with the credentials to view the technical information for this machine. Canon is extremely anal when it comes to allowing their tecnical information to be viewed. I was trained on their newest 105 copy a minute machine and denied access to human support or documentation on a 16 copy a minute machine recently. Anyway,I am no expert on the 3100 but I can explain and describe the meaning of the error codes The E225 meant that the scanner (the system that illuminates and moves (scans) across the document ) was moving at uneven or varying speeds. This could have been caused by shards of the broken glass interfering with the smooth and constant operation of this assembly. The manual says to loosen the scan motor and re-tension it as the assumed normal wear problem is that the belt that provides drive between the motor and the scanning assembly may have stretched. It fact they suggest replacing the belt (XF24606740). But I would assume it was a function of the the platen glass being broken and debris causing uneven speed. Next the E20-81. Since you probably don't get toner in your ears as often as I do this may be a challenge. There is a sensor that emits light to generate a reflection from the drum in order to measure the drums sensitivity and test patches of color as the machine calibrates itself to determine the optimum copy quality. It looks at the drum when its completely image free (blank area of document to minimize background) and each color to determine what adjustments need to be made for optimum density and clarity. If the light emitting diode has a haze of dust(toner) over it then the values it reads will be skewed and in your case out of range for adjustment(E20-81) This typically happens if machine has not been vacuumed/cleaned in a long time or if it is moved which tends to dislodge any garbage that had been innocently lying around until it was josteled loose. I dont have a manual for this machine that will tell me precisely when this sensor is located and the procedure to optimally access it. I can only say that a good vacuuming of the core of the machine would be the firtst step. To what degree you can access this sensor (which is called PS23 .part # FH77629000) without disassembly of some or the core of the machine I cannot tell you intelligently. I am sorry I could not be of more help. I hope I helped a little .Good luck
  • 47 Answers
I just spent 20 min typing a detailed post why the e225 is already fixed and the e020-0081 is common and means the drumm patch sensor is dirty and then the web site erased it. Grr.
The drum patch sensor shines down at about the 11 o'clock position halfway down the drum. Remove the drum taking care not to scratch it or the transfer belt and clean the sensor window.
If the problem re-occurs then you may need new developer units.
Posted on May 30, 2008
    Problem Solver:
  • 3 Answers
How do i change the language to english canon ir3100cn
Posted on May 01, 2011
    Problem Solver:
  • 16 Answers
1) Kindly remove the replaced glass, try to remove any pieces of the glass around the moving objects and then fix the glass back.
2) Try to On the machine when you remove the glass to see if it will return back to the former code, then if it returns to the former code without the glass you bought new. You need to pass an order for new class from the manufactured company either in UK or in your country.
Posted on May 08, 2008
    Problem Solver:
  • 8 Answers
E020-081...
Dirty Drum patch sensor OR the drum has reached 100% of it's life.
iRC3100 drums NEVER go past 100%...once they reach that magic figure in the counters then it's time for a drum replacement.
If you know how to access service mode then check under:
COPIER>DENS>P-SENS-P and make sure that the figure is around the 500 mark...if it's below say,250 then that indicates that the drum patch sensor is having trouble reading correctly and may either need cleaning or a new drum unit.
Posted on Jul 22, 2008
  • Canon Expert
  • 287 Answers
Hello Eeel,
I would have sworn I had already made a post to help you out. I must have messed up and I am sorry. The E-225 was indeed a result of the broken glass. The error means that the speed of the C.I.S. (contact imaging sensor) was unstable. The broken glass would account for the scanner speed instability. I am sure you have carefully cleaned the rails the scanner rides on and made sure that there is no debri that might impair the drive system( drive belt,motor etc...). Then you got the E 20-81 code. I have to go by a 3200/3220 manual and the common denominator is that the inside of the machine is dirty and the copier cant properly calibrate the colors. Here is the wierd part. The last 4 digits of the erreor code are critical. The first two digits, of the four, tell which drum/developer unit has failed and the last two digits further describe the failure. The manual starts with 01 as yellow,02 is magenta,03 is cyan,04 is black. You have indicated 00, as in 0081. "81" is an abnomal reading of one of the drums, but the 00 does not make sense .I wish I could be of more help. Take care. >>>>>SPINAL>>>>
Posted on May 20, 2008
Ryobi 40 volt Expand-It locking collar.
I replied to your comment in your previous question. If you search eBay in you home country for the words 'Stihl Tommy 5crew' (I have to use a 5 as it finds the word offensive and blocks it out..!) You will find the parts in your country without the shipping costs of the UK.
May 24, 2016 | Ryobi Garden
How do I trace a package bought on e bay
You may have received tracking information in an email. You can use this information to check the shipping status of your item on the shipping company's website.
You can also check the shipping status of your item from My eBay.
To check the shipping status of your item from My eBay:
  1. Click My eBay at the top of most eBay pages. You may need to sign in.
  2. Click the Purchase History link on the left side of the page.
  3. Locate the item in the list. If the seller printed the shipping label using eBay or PayPal, or entered a tracking number for an item, you'll see the tracking number under the item title. Click the tracking number to see the package's shipping status.
Sep 29, 2014 | Office Equipment & Supplies
Hi I bought the freezer from the UK and it was fully working. I shipped it to my home country and tried to stsrt it but it was not working
DURING THE TRANSPORTATION IT MUST HAVE BEEN LAYED ON ITS SIDE, NOW YOU NEED A QUALIFIED SERVICE TECH COME AND CHECK YOUR FREEZER SORRY
Sep 13, 2011 | AEG Freezers
My canon ir3100cn displays "finisher
My canon ir3100cn displays "finisher can not be used" with on screen. i'm using saddle Q2 finisher. it doesn't move at all.
Sep 03, 2011 | Office Equipment & Supplies
Hi. my A80 screan shows a blurred mess, and takes wiered pictures, when on camera mode,yet shows a good picture when playing back older stuff stored on the card. Help please!
This sounds like it might be a defective CCD imager, and is a known defect for your particular model camera.. If so, Canon should fix this for you for free if you live in the US, Canada, and a select few other countries. If you live outside the US, contact Canon support for your country to see if they'll still honor the advisory (some still will, especially if you stress you knowledge that this is a known defect of the camera). They may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please see this link for more info.
Mar 03, 2011 | Canon PowerShot A80 Digital Camera
Re: POWERSHOT A75 BOUGHT CAMERA IN 2004 BUT RECENTLY HAVE LOST USE OF LCD AFTER START UP AND PRIOR TO SHOOTING PHOTO. HAVE TRIED TO RESET SETTINGS TO DEFAULT BUT LCD SCREEN JUST FLASHES (PIXILATING ?)...
As aseletroniqu stated, this sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Feb 27, 2010 | Canon PowerShot A75 Digital Camera
Purple pictures
If the rest of the camera, the menus are okay, then you have a ccd problem. Canon will fix this for free and pay shipping both ways in the USA.
Call the 800 number for support/repair at the following Internet page:
Canon support and repairs.
Oct 25, 2009 | Canon PowerShot A75 Digital Camera
Canon ir3100cn
check your itb home position, are you sure for that error # e0072? maybe e0070
May 21, 2009 | Canon imageRUNNER C3200 Copier
Blurred pictures on canon powershot S1IS
I don't know if Canon is offering out of warranty repairs in any country. You should contact Canon in your country to request a repair if it's under warranty, or ask about the fault if it's a recognised common fault
Cananda, look here:
https://orderdesk.canon.ca/RepairOnline/bookOrTrack.do?method=languageSelection&lang=en
UK, look here:
http://www.canon.co.uk/Support/Consumer_Products/services_locator/index.aspx
**.The best way to acknowledge contribution is to rate it's relevance.**
Jan 10, 2009 | Canon PowerShot S51S Digital Camera
Canon imageRUNNER C3200 Copier Logo
5,838 people viewed this question
old marine
old marine
