Question about Craftsman 22 in Precision Cut Lawn Mower Blade
The blade on my mower gets "eaten up"on the backside, the side opposite of the blade. cain't figger why this happens. thanks for your help . jpf
  • 2,019 Answers
Well the most obvious possibility is that you put the blade on backwards.
But assuming you did not, I would guess it is the mulching feature of this blade, that pulls sand or small gravel out of the soil, and it impacts the blade I suppose?
Posted on Aug 27, 2010
The rider mowers does not get in gear forward or reverse. The blade does engage. In neutral I tried to push the mower and it will not move because the rear tires roll in opposite direction.
Firts check your gear lever if is out of engaichmend,located on right hand rear side close to wheel shaft 2 check your belts 3 check your transmission fluits.
Jul 09, 2017 | Garden
2 black blades turn in wrong direction
Reroute the belts on the pulleys to the opposite side of those pulleys to reverse direction. But first, are you sure you put the blades on in the right direction.
Dec 27, 2015 | Garden
Simplicity 44" mower blades
Thank you for the great picture. You should be able to wrap each blade with a towel or large rag and grip it with your hand whilst you put a box end wrench or a socket & rachet on the bolt and turn it to the left ( counter-clockwise) and loosten the bolt and remove both blade and bolt. Put them back on the opposite way. Do not use an open end wrench, pliers, vice-grips, or chanel-locks as you can round the corners of the bolts. Be certain the box-end wrench or socket fits the bolt exactly.Tighten the bolt back on with the same tightness as you removed it. A tiny bit of oil or grease on the bolt's threads will help it go smoothly next time.
Be blessed.
Jun 16, 2013 | Garden
Which way do you turn the bolt on the blades of an ariens riding mower
You turn the bolt in the opposite direction on the the way the blades spin.
Jan 26, 2013 | Ariens 42" Riding Lawn Mower Blade ...
I have a black and decker lawn hog mower with a 19 inch cut that i am trying to change out the blade. My problem is i cant get the mounting nut off becausethe shaft keeps turning. I have tried everything,...
are you turning nut the right way ! on a lot of mowers, the nut turns off the opposite way the blade turns, to keep it tight. good-day ! Loosen the nut in the center of the blade with a wrench by turning the nut counterclockwise.
Jul 14, 2011 | Black & Decker 19" Electric Lawnhog...
Husky yth1542xp. I've changed the blades, leveled
When levelling the deck, rotate the blades so that the right blade has one of its cutting edges at or near the right side center of the deck. Do the opposite with the left. Measure to the blades from the level ground, not to the deck. Try leveling that way.
Gary
Jul 03, 2011 | Husqvarna Garden
Blades disengage when they are suppose to engage
Sounds like a faulty switch? This scenario doesnt really make sense. Sorry. Please explain more clearly. Thanks, Mike. Rate 100% please.
Jul 04, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Very little grass is shooting into the bag to fill it
Hello monica_skinn:
If the Underside of the Deck is Clean and the Blades are Tightened Properly, then the Problem is Caused by the Blade Lifts being Worn or the Blades are Not a High Lift (Bagger Blade) Blades.
A Bagger Blade has a Very High Lift Ear on the Backside of the Blade Across from the Cutting Edge. This Extra Lift is What Gives the Extra Lift and Throw (by increasing air Flow under the Mower) the Grass gets to be Bagged.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 11, 2009 | Toro Lawn Mower With Toro Power Tools
ROPE ON MOWER WON'T PULL OUT
I agree, it sounds like the mower is fouled with foliage at the blade. Pull off the spark plug wire and tilt the mower on its side opposite of the carburetor, check the underside of the mower for impacted grass clippings.
Apr 30, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Craftsman 22 in Precision Cut Lawn Mower Blade Logo
27 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
