Question about Kitchen Ranges
If my houses electrical panel is a fuse box can i install a sub panel that is breakered or do i have to stay with fuses?
  • 139 Answers
Yes you can install sub panel off of the fuse box /jump off main comming into fuse box.too new breaker box..good luck /PS..you may have to pull the meter to do this safly so be safe .../joe/
Posted on Aug 27, 2010
Testimonial: "jharper501 i really appreciate your help @ the sub panel.i'll b safe thanx!"
I can't find the where the fuse is at
    Your owner's manual will tell you where your vehicle's fuse panel is. Most models situate the fuse panel on the driver's side of the dashboard and under the steering wheel, or in the engine compartment, but location varies from vehicle to vehicle. Other are found in the front dash door jambs or in the glove box.
Changing a Fuse ' DMV.org
    www.dmv.org/how-to-guides/fuse.php
How to Find the Fuse Box or Circuit Breaker Box: 12 Steps
www.wikihow.com > ... > Electrical Maintenance
wikiHowCall an electrician if you can't find your circuit breaker or fuse box. Some boxes can be hard to find depending on additions or remodels made to the house.
Dec 16, 2015 | Cars & Trucks
Just got electric dryer #FAQE7011LW0 dryer will not heat manual says check fuses but does not say where they are located
The fuse they are refering to is the fuse/circuit breaker for your house wiring in your house fuse box/breaker panel
Sep 18, 2011 | Frigidaire Dryers
How do I run from a 100 amp main panel to a 60 amp subpanel, 125 from my house to the garage
See 60 Amp sub-panel image
Above image shows drawing of 60Amp sub-panel located next to main panel. Drawing shows #6 wire... 125' distance to garage calls for #4 wire. I ran #4 to my barn and have no problems.
Give thought to how many new breakers you want at garage.
See photo of subpanel that holds three 240V breakers
Using drawing as a guide. Replace existing 240Volt breaker with new 60 Amp breaker. Two hot wires connect to new 60 Amp breaker. Neutral connects to neutral busbar.
More space: You can free up space in main breaker box using a tandem breaker. Or by doubling up 2 lightly used 120V circuits onto one breaker. Do not double-up on 240 Breakers
Conduit: You want PVC conduit large enough to fit three #4 wires. Bigger conduit is easier to pull wires ... and maybe later ethernet wire, or alarm wire etc.
Ground wire: You can put a ground rod at garage and run #6 bare copper between sub-panel neutral-busbar and ground rod. Attach ground wire firmly with grounding clamp.
I want you to check with local electrical supply for exact code in your area concerning conduit requirements, grounding, and wire size. Tighten all lugs very tight against wire.
Oct 03, 2010 | Siemens 100 Amp Main Breaker Renovation...
Renting old house with old power box uses 'plug in fuses' , doesnt have cut off safety switch ,i heard that i can by circut breakers to stop any surges and plug them into fuse box ,does that sound right ?...
Wow, all due respect, but someone would really be negligent to offer you a solution to this problem. An electrical panel isn't something to mess with, especially if you're asking these type of questions. Contact a professional electrician in your area or run the risk of electrocuting (that's DEAD by electricity) yourself. Good luck, and please be safe.
Aug 10, 2010 | Eaton ARC FAULT CIRC BREAKER
I need a fuse block (it's the part that holds the fuse and is inserted into the fuse box). This fuse block holds 2-50 amp fuses and is mounted to the electrical pole outside of my house. Then the...
What you are wanting is an Outdoor Disconnect Switch- 100 AMP, but this panel is an example of what to look for,
http://electrical.hardwarestore.com/14-51-breaker-box-100-amp/100-amp-mobile-homeline-panels--642643.aspx
Jul 26, 2009 | Electrical Supplies
Could it be the heating element/coils?
From the info you've given, I'd suggest confirming whether the electrical circuit breaker arrangement for the dryer is single-pole (one wire and handle, 120V) or two-pole (2 wires and handles, 240V).  The heating element requires 240V.  Also, you mentioned a "fuse box". Hopefully you meant circuit breaker panel.  The wiring in any house old enough to have fuses instead of breakers would be a major concern unless you're into indoor barbeques in the middle of the night.
Jan 31, 2009 | GE DBXR463EBWW Electric Dryer
F2e0 error on stove
"cycle the circuit breakers" is to turn the switch for the stove at the electric switch box at the main feed of the house electric panel. This is equivalent to unplugging the stove and plugging it back in.
In the old days, a circuit breaker was a "fuse" in the "fuse box"...
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Jenn-Air Electric stovetop / oven range SCE4340B - Fuse blown ? ? ?
Andy, sounds like you lost a leg of power. Check the breaker box first. Maybe the contractors tapped an existing breaker instead of adding one for the burner/broiler. You would have to check the terminal block on the range. Should read 120V from each end to center and 220V across the two outer terminals. If you don't have this, something got messed up with the contractors. Catriver..post back
Mar 04, 2007 | Jenn-Air JED8430 Electric Cooktop
Kitchen Ranges Logo
37 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
