Question about Kodak EasyShare V603 Digital Camera
My lens of my camara kodak easy share v603 are out and do not close back and the camara does not work. What should i do?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 27, 2010
When i turn on my camera the lens goes out, makes a noise, zooms in, makes another noise, then goes off. the number of the camera is kodak easy share m883
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 02, 2009 | Kodak EasyShare V603 Digital Camera
My camera won't turn on.(Kodak Easy Share V603)
The problem is battery related recharge the battery for about 4 hrs and then try
Aug 16, 2009 | Kodak EasyShare V603 Digital Camera
THE LENS COMES OUT BUT GOES RIGHT BACK IN AND
I had the same problem. All I did was hold the lens out when it tun so that when it shuts off, the lens is still out. Then I moved it around a bit. Something was stuck in the lens and when I moved the lens around, it came out. So now it functions normally :] I hope I helped!
Jul 07, 2009 | Kodak EASYSHARE M1063 Digital Camera
Lens won't retract
if the camera is still under warrenty bring it back. If not the best thing to do would be to try forcing the lense back in by hand i know this sounds distrucive but if theres no warrenty left it will not make a difference.
May 04, 2009 | Cameras
I have Kodak Easy Share CX7430. I have put in new
Enilra, sounds to me like you might have the button that takes the photo stuck in the down position. Without turning on the power, put you finger on the button and press down on it while you move wiggle your finger around. Get a good look at the button and see if You Can See If The Button is returning to the UP Position. Withour seeing your camera in person this would be my guess.
Feb 19, 2009 | Kodak EasyShare One Digital Camera
Camera V603
the camera should be brought to a repair shop since it might be a mechanical problem or parts may need to be replaced already.
Aug 25, 2008 | Kodak EasyShare V603 Digital Camera
Error E45
Turn your camera on and smack the camera against your hand. The E45 error means your lens is stuck. The lens on my V603 was stuck open, when I smacked it against my hand it closed and now works fine. Give that a shot.
Jun 23, 2008 | Kodak EasyShare V603 Digital Camera
Camera will not turn on...
Does it do this when hooked up to the charger? It might be the battery.
Jun 20, 2008 | Kodak EasyShare V603 Digital Camera
Cannot Start Up
Go to Kodak Technical Support- There may be an issue here that they will deal with free of charge.
Jul 07, 2007 | Kodak EasyShare V603 Digital Camera
Kodak EasyShare V603 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
