Question about Philips TP2784C TV
I have a Sanyo ds20424 the breaker in my house tripped and now the tv won't power on. It happened before and I took tv apart and got it to work again. Is there an internal reset switch? What could be the problem?
  • 70 Answers
I don't think there is no reset switch inside the TV but may be FUSE blown deu to power intruption pls check the fuse and if it gone peplace the fuse with same rating
Posted on Aug 27, 2010
  • jeremymorris Aug 27, 2010
    Yeah I checked the fuse was not the problem. Thanks for the help though.
My tv works at my friend house, but doesn't work in my apartment. However all other electrical devices work at my apartment, model is (SLED5000)
Sounds strange indeed. All other devices; except the TV works fine with all power sockets at your house!! Just replace the power pin, at the end of the TV power cord and check. There is nothing more to check for you. It it too do not help you, contact any service technician. Electro help
Dec 01, 2014 | Sansui 50IN E-LED TV 1080P SLED5000
Apex ld3249 shot sparks out and tripped the breaker
A nasty short somewhere or wrong voltage to set---do not keep plugging it in and tripping the breaker--in fact do not plug in at all until a technician examines it(tell him/her what the issue is).
To answer the question here: Dead short on or across the AC voltage line inside the set most likely of primary side of power supply.
Nov 04, 2012 | Apex Digital LD3249 LCD TV
My sanyo modle DS20424 has sound but not picture. We have DISH and their info shows up on the tv when the satelite is on, just no picture. Help??
I would first see if set works with a DVD etc directly hooked to one of the rear audio/video inputs.
If so I would next unplug the dish box and wait and then power it up again to see if it will reboot and cure this issue--you can also contact them....
If getting the on screen Menu but nothing else it is either a signal issue or a problem in the set---If using a receiver also reboot it as well.
May 21, 2012 | Sanyo Televison & Video
The power in our bar went off last nite and now one of the tvs won't cut back on. No power at all. Any ideas? Thanks
COULD BE ON SPERATE BREAKER. BREAKER COULD HV TRIPPED FROM A POWERS SURGE WHEN POWEER WENT OFF OR CAME ON. CHECK BREAKERS IN PANEL
Dec 04, 2011 | Sanyo Televison & Video
I have a brand new lincoln 180 mig welder when i hooked it up to 240 volt power it was feeding the wire just fine but when i tried to weld the wire would just stick , so i checked the power and found i was...
Have you tried it on another outlet, say at a friends' house, etc?
Reset button on the welder tripped? Double check the breakers and all connections. If it was working before, it should work now. Try some different breakers to check for good juice. Good luck!
Feb 16, 2010 | Lincoln Welding Tools
We had a near lightning strike and now my tv (sanyo model ht27744)doesn't want to come on.
Lightening may have caused a surge on your power lines to the house and to the outlet the TV was on.
Do other things work on that outlet? If not you tripped a power breaker.If they do work check this.
Unplug the TV for 2 min or more and plug back in.
Try bypassing your surge protector you had it plugged into. It could have died when the lightening struck.
(no surge protector?) Bet you'll buy one for your next TV.
Look for 3000 joules and up rating for a surge protector and insure it has protection for a cable/antenna input too.
If this doesn't work the TV may be fried or internal fuse blown.
Time to take it to a repair shop or depending on it's age (5 years+) it may be time to buy a new TV and surge protector.
Near Lightening strikes can effect appliances from several inputs that could be affected from outside like Power, Cable, Antennas, Phone Lines that come into your house.
Jul 06, 2009 | Sanyo Televison & Video
Lcd television trips circuit breaker when plugged in to wall outlet. Problem started yesterday after wall mounting the unit.. Removed wall mount and it still happens (worked fine before wall mounting...
I would check 2 things. If the TV trips another breaker in the house of the same rating, you probably have a short in your TV and will need to have it serviced.(You didn't drop it did you? :-) ) The short may also occur by too much stress on the power cord where it enters the TV, common to need to cram the cord into small spaces when wall mounting. If the TV only trips that particular breaker, I would try replacing the breaker. Replacing the breaker costs very little and will only take you a few minutes. You can buy a replacement breaker at most hardware stores. Just make sure to disconnect the main supply first! Also, make sure the breaker is rated correctly, using a higher amperage breaker will increase your chances of starting a fire.
May 05, 2008 | Televison & Video
Needto know if my tv is digital or not the models are DS20424 and DS13310
Model # DS20424 is digital capable at 480i resolution with the use of the component video input jacks but model # DS13310 is not. I've also attached links to both units user manuals. Hope this helps.
DS20424 - http://www.instruccionesweb.com/u2/pdf/television/Sanyo-DS20424-fr.pdf
DS13310 -
http://www.sanyoservice.com/pdf/images/DS13310_&_DS19310(OM).pdf
Apr 24, 2008 | Televison & Video
Breaker tripping
Make sure it is plugged into a 20 amp circuit. If it is in a kitchen it should be a 20amp breaker if it trips a 20 amp breaker it needs to be replaced. If it is a new house and you plug it in in the kitchen and it trips a 15 amp breaker then the house does not meet code. ref Article 210.52(B)(1) NEC
Jan 18, 2008 | Emerson MW8107WA Microwave Oven
My Sanyo DS20424 does not turn on any more
CHECK COOL SOLDER IN POWER SUPPLY AND 2 RESISTEN. IN HORIZONTAL SECTION CHECK ALL COOL SOLDERING
Sep 13, 2007 | Philips TP2784C TV
Philips TP2784C TV Logo
96 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
