We need to set the default resoultion on our Canon IR 3170C printer as it is set at the highest setting which creates massive file sizes. We can set it up at each individual scan to a lower resolution but would like to set it as a low default resolution. How do we do it?
  • Anonymous Jul 28, 2008
    I am getting the following when I try to open: Scan a Picture.
    "CONFIGURATION ERROR, SIZES FILE, UNABLE TO CONTINUE"
    CAN ANYONE HELP
  • 655 Answers
Try to set from Start-> Control Panel-> Scanners -> Properties.
Then set the values and select ok/Apply to save the value.
  • Pleae close if any window open for scan before making the above changes.
Post your feed-back.
Thanks
Iqbal
Posted on May 06, 2008
Can somebody help My canon ir 2016 is showing change paper size while all setting are correct
dear >>> every region have its default paper size, for example in the middle east we are using A4 as a default size while the majority devices that come from USA are using the letter size, as a result you have to change the paper default size to match your needs .you can simply do that by right click on your printer go to printer proprieties .
Mar 12, 2016 | Canon Office Equipment & Supplies
Need a default password
There is not password set by default on Canon IR, you can login with empty credentials.
May 22, 2014 | Canon iR 2022 Printer
ERROR E00227-0001 When I star my canon ir 3170C this problem occure when I was working with the generator. I need your help please.
this error code stands for fault in power supply pcb. The reader unit doesn't get 24V when you start the machine.
As possible solution, you can try to reconnect all connectors on power supply and on dc controller. But, I think that you will need to change the power supply...
Hope that helps!
Jul 09, 2011 | Canon imageRUNNER C3170U Color Copier
Canon LASER SHOT LBP-1210 Printer how to set legal page
For printing the Legal Size (8.5′x14′) in cannon LBP-1210, follow the instruction:
Step 1- Go to start
Step 2-printer and faxs
Step 3-select printer(Canon LASER SHOT LBP-1210)
Step 4-go to file
Step 5-select Server properties
Step 6-select creat new form (for legal page)
Step 7-give form name legal 1
Step 8-give paper size width 8.50in, hight 14.00
Step 9-give paper margin top 0.30in, left 0.30in, right 0.30in, bottom 0.30in
Step 10-select save form Step 11-then select advanced
Step 12-select informational notifications for local printers
Step 13-select apply
Step 14-then close
Step 15-select Canon Laser Shot LBP-1210
Step 16-select printer
Step 17-select properties
Step 18-select-select forms
Step 19-select change forms
Step 20-select legal 1
Step 21-select OK
Step 22-select apply
Step 23-select OK
Remember: 1 U need to set paper size (8.5′ x 14′) manually in the word documents and befor printing you need to set in printer properties "Legal 1′ for printing. Print preview may not show the whole page but the printer will print the whole page.
All the best.
Apr 24, 2010 | Canon LASER SHOT LBP-3000 Printer
I have proplem in canon ir 2020
Under service mode *28* find the clear all and OK, after that you shouldnt have any pass required, but you need to set the IPadress, and your preferd sets.
Apr 05, 2009 | Canon iR 2020i Laser Printer
I have bizhub c350, everytime i scan to email i get multiple emails each with 1 page. how do i fix this?
If you go into the admin setting when using the web browser you can enter the email setting one of the options is binary, if you turn off or on depending on the setting it should stop this fault.
Mar 02, 2009 | Minolta C350 Color Printer/Scanner/Copier
How do i set paper sizes on my canon ir2016i printer
Open the paper drawer
Remove the paper
There is a blue paper size plate,that keep the paper in the correct posision,Push it to the front and downwarts.The paper plate should come loose from the tray.Put it back in the openning for the A4.The openning for the A4 papersize is mark inside the paper tray.
Now set the blue papersize dail to A4 paper .
Then you are ready to copy with A4 paper.
Feb 19, 2009 | Canon iR 2016i Black and White Copier
How to set
Find your printer on the Canon website and download a manual for instructions.
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
Feb 15, 2009 | Canon iR 1600 Laser Photo Printer
Canon imagerunner Ir c3200 total reset
Ok. Press the additional functions key - that is they key with the star inside it - then select 'system settings' then 'network settings' then select 'ip setting'. Once you've got into the ip settings you can enter all your own network settings. All you need to enter is IP address, subnet mask and default gateway but you'll know all that.
Nov 12, 2008 | Canon imageRUNNER C3200 Color Printer
Canon ScanGear Ir - how to set defaults?
ScanGear won't run under Vista. The scanner works with other programs. (Twain works) ScanGear fails and Vista closes it.
Don
quantm@localnet.com
Sep 21, 2007 | Canon imageRUNNER 1023N Black and White...
85 people viewed this question
jasbo
jasbo
