How do I set up a Ringgrip compact 24 hour timer for use?
  • 4 Answers
SOURCE: Timex 250 Vac 25 Amp 24 Hour Timer Switch Won't Keep Time
Can the clock be repair or replace, my will not keep time.
Posted on May 23, 2009
SOURCE: general electric 24 hour timer ge5101n can it be
ge5101 can be used with cfl
The timer turns the circuit on-and-off like a light switch.
Anything a light switch can turn on, a timer can turn on.
Posted on Oct 09, 2010
SOURCE: I need instructions for how
GE 15075 manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Plug-In-15075-Manual-eng.pdf
GE 15075 is a plug-in timer.
Before you plug it in, set the timer so you're not bent over at the receptacle.
Rotate dial until current time lines up with triangle located on inner dial.
There are movable pins located around the dial.
These pins cause the timer to turn on and off.
Pins out = timer on
Pins in = timer off
plug in your lamp and the timer turns on and off.
After power outage, set current time again.
Posted on Oct 26, 2010
SOURCE: On Intermatic HB65R Timer, how do I set AM/PM or
HB65 manual is not available.
Intermatic has pared-down it's timer line recently.
Some old manuals still show, but those are disappearing because timers don't last forever.
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers.aspx
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
HB61 manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb61rc%20-%20english.ashx
HB61 timer has a photo-cell switch and automatically turns ON at dusk, and then you set timer for how many hours it will operate before turning off.
Posted on Nov 23, 2010
heatman101
  • 43501 Answers
SOURCE: BRINKS MODEL 42-1020 A 24-HOUR TIMER WITH 15-
Not sure what your problem is exactly....is it not working? You don't know how to set it???
Here is a tip that will help you to get better results from your question on Fixya.
How to ask a question on FixYa
heatman101
Posted on Nov 27, 2010
How to set the clock using 24 hr and 12 hr clock
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#oval
Add comment and describe timer in detail.
Usually if a timer offers choice between 24-hour clock with 1-thru-24 displaying for current time, vrs 12 hour am- 12 hour pm, then the choice is first thing you set before programming. The choice is made before setting current time, and usually this is accomplished with single button push that toggles between 12 and 24 on the display.
The product manual has specific steps.
Not every timer offers 12-24 choice.
Again, add comment and describe timer in detail, or attach photo for best available resources.
Gene
h
Aug 08, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
How to get this RINGGRIP timer to work?
Do you have a manual?
First set the current time and after the on and off time
Mar 16, 2013 | Hardware & Accessories
I need to know how to set the time on my model RETP RINGGRIP TIMER
To set the time;
Press and hold the TIME button during the time setting procedure. While holding the time button press DAY to set the correct day and HR to set the correct hour (make sure the am/pm is correct) and then MIN to set the correct minutes. (If you hold down the Day/Hr/Min button for more than 2 seconds it will give a fast run-through)
Dec 13, 2012 | Hardware & Accessories
I need a night light timer that I can set to be on for 50 minutes and off for 10 minutes and repeat this every hour for 24 hours.
1) If you have programmable timer, then it would require 24 ON and 24 OFF settings, with down-to-the minute programming.
1 ON for each hour.
1 OFF for each hour.
Following link shows Grasslin 50-60 Hz 230Volt din rail timer with 50 memory slots. 16 amp at 230 volts
http://waterheatertimer.org/pdf/talento_371_372_371_mini_plus_data.pdf
2) If you have 24 hour mechanical timer with dial, it would need 24 ON trippers and 24 off trippers with down-to-the minute schedule.
No timer has that capability.
3) There is C8800 series cycle timer. 120-240Volt 60Hz for US market. 20 amp at 120volts, or 20 amp at 240Volt. Chose 1 hour cycle, then insert 100 trippers and leave 20 blank spaces.
http://waterheatertimer.org/pdf/027-C8800-sprinkler-cycle-timer.pdf
4) There are percentage cycle timers.
For example CT2000. Rated 120Volts 60 Hz for US market.
http://waterheatertimer.org/pdf/CT2000_sell-sheet-with-wiring.pdf
Select 1 hour cycle, and 16% or 84% percentage to choose ON or OFF
Nov 28, 2012 | Woods Indoor 24 Hour Night Light Timer...
Ringgrip timer retp timer manual
1) Send a photo so I can see it.
2) Raindrip makes water timers.
http://raindrip.com/products/timers?vmcchk=1
3) Otherwise the only reference on worldwide web for ringgrip is Fixya, which shows links to answers that cannot show a product either.
4) And if all the links to your product show Fixya as first page google search, then there is likely no information available.
Nov 27, 2012 | Hardware & Accessories
What is a minimum timer setup
Question is not clear, timer is not identified.
Add a comment with in-focus photo of timer posted on flickr.
Minimum on-off time for digital timers is usually 1 minute.
Minimum on-off time for plug-in-type 24-hour analog timers is 1/4 hour or 1/2 hour depending on width of tripper-pin-segment.
Minimum on-off time for plug-in-type 7-day analog timer is usually 3 hours.
Plug-in vacation timers are set for random on-off and cannot be set.
Minimum on-off time for box timers with 24 hour dial and wide tripper is 1 to 1-1/2 hours
Minimum on-off time for box timers with 24 hour dial and narrow tripper is 1/4 hour.
Minimum on-off time for box timers with 7-day dial is usually 3 hours
Open following link for information how to set analog timers
http://waterheatertimer.org/How-to-set-timers.html
Jun 12, 2011 | Intermatic 10 Amp Mechanical Indoor Timer
Need instruction for setting time of day
You posted under Paragon 1015 timer.
Open following link to identify timer and download manual.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#1015
Timers are 24 hour, but some have 7-day capability:
Manual says: to set 7-day grasp large 24 hour dial and rotate either direction until correct day of the week appears below Day Set red dot and 12 noon on large 24 hour dial is below red pointer.
To set 24 hour, grasp large 24 hour dial and rotate either direction until correct time appears below red pointer.
Red pointer is stationary at 6:00 position.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 14, 2011 | Paragon 1015-00RS Indoor Multi Operation...
Wondering how to use a 24 hour compact pin timer to automaticlly turn on my lamps ?? bought 1 yesterday but no clue of how to work it !
Pins are usually up for on and down for off, so put them to on for the times you want the lamps on and vice versa, obviously you can check firstly to be sure which way is on and which way is off.
Jan 07, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
General electric 24 hour timer ge5101n can it be used uith cfl (compact Floricent Lighting)
Oct 08, 2010 | Solar Ge 24 Hour Timer 2 Pk (ge24t)
205 people viewed this question
jasbo
jasbo
