Question about Polaris Ranger RZR Ride on Toy
My nieces have the Polaris ranger. Battery is good but I think there is a loose connection somewhere. it will start out fine and then after a few minutes of riding, it will quit. But then if you wait a few minutes, it will go again.
    Genius:
  • Polaris Master
  • 1,508 Answers
Known issue you need to upgrade the motors and thermal swithes, let me know if you need me to order you the upgrade kit
Posted on May 14, 2012
4 Suggested Answers
  • 156 Answers
SOURCE: Peg Perego 800 Twin ATV - Only runs for 10 - 15 minutes at a time
Go ahead and charge it for 24 hrs. If it still does not run contact the repair department at http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.htmlthese guys (and gals) help me out all the time.
Posted on Jun 03, 2009
reyjoshua07
  • 1157 Answers
SOURCE: I bought a new Polaris
Hi alvinr123,
Please check and make sure that the wiring on the foot pedal is on. Sometimes the Peg Perego Polaris models will get corrosion on the red wire. After checking the wire, go ahead and charge the batteries for 24 hrs. If that doesn't work then you need to replace the batteries. I recommend to contact repair department at http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html.
Additional contact information:
Phone: 1.801.655.0800
Email: help@shopJandL.com
Hope it helps.
Thank you for using FixYa.
Posted on Apr 13, 2011
alpug
  • 1961 Answers
SOURCE: My Perego Polaris 800 twin
Have you not overload the car?
Circuit breaker will automatically disconnect the power when operating in an overload condition. However, circuit breaker usually reset itself after 10 or more seconds.
In your case this will be your first target, check the circuit breaker
Then check if the battery connector is properly fix.
The last to check is the thermo protector.
I'll be attaching the pdf manual for this model. This include the parts description and the circuit diagram so it will be easy for your trouble shooting.
http://www.pdfstock.com/viewer.php?file=http://peg-peregoparts.com/manuals/IGOD0510.pdf
Posted on Apr 21, 2011
I have a 2004 Ford Ranger and when I try to remote start it, it starts but it sounds like its trying to start it again and then shuts off
If the truck starts fine with turn of the key in the ignition,look into finding the problem with the remote starter system.
Components maybe faulty or not proper.
Module.( Hidden underneath, usually somewhere under steering column area)
Receiver/Transmitter.( Mounted inside vehicle windshield )
Switch.( Under Hood,usually on the top radiator support bar )
Wiring.( all connected to the Module )
Fuse / Relay.
Remote / programming/ remote battery.
Connections that maybe loose,corroded, loose or wrongly connected.
Its also possible your vehicle might need a by pass module to connect with the remote starter module, to enable vehicle starting by remote.
Have a nice day.
Apr 17, 2016 | Vehicle Parts & Accessories
Polaris Ranger 700 Xp 4x4 EFI...Battery light started flashing And I check for loose connections.... Shuts down if you remove the positive cable
You have lost your charging circuit. Check the Stator. You can go to YouTube and watch how to do this.
Feb 15, 2016 | ATVs
I have a 2006 polaris ranger 500 that runs and starts fine when it is cold. After riding for a while and I stop the engine and try to restart a few minutes later, the engine cranks very slowly like it is...
It certainly could be. Polaris did have this problem in the 500 Sportsman in earlier years. Unfortunately, the decompressor can't be repaired on it's own, you'll have to buy the entire cam with the decompressor. The good news is Polaris reduced the price of the cams to make them more affordable to the individuals that missed the factory recall. Good Luck!
Jun 10, 2011 | 2007 Rhino Hunter R
2007 Polaris Ranger 500 EFI will not start, new battery, starter solenoid. Tested battery, is good. When key is turned to on and light is suppose to work, all it does is flicker faintly. When turnd to...
If your battery is good then you have dirty or loose connections at the battery or the starter. Quite often this will be on the ground side.
Nov 05, 2010 | Polaris ATV
1993 Ford Ranger Headlights won't stay on
you will probably find the problem stated with a poor connection in the headlight switch plug and is now heating up and looseing conection in a short time.remove the headlight switch and you will see what i mean.
Jul 29, 2009 | 1993 Ford Ranger SuperCab
Electric start clicking
Check the battery with a VOM while pressing the start button. If you have good voltage check the voltage on the positive cable on the starter. If you have good voltage there you have a bad starter, considering your cable connections are clean and tight. If no voltage at the starter the solenoid is no good. Usually the click is the solenoid closing and if the connections are not clean or tight the current will not make it to the starter.
Mar 23, 2009 | Polaris ATV
2003 ford ranger battery light comes on
i think it is the alternator because the idiot light is connected to your regulator of your alternator. it is an indication that your alternator is not charging anymore.
tnx 4 using fixya,
drcool
Nov 08, 2008 | 2003 Ford Ranger Regular Cab
Polaris Ranger RZR Ride on Toy Logo
115 people viewed this question
Top Polaris Toys Experts
Adam Fjeld
Adam Fjeld
cwradio73
D. E. Hev
Are you a Polaris Toy Expert? Answer questions, earn points and help others
