My laptop DELL inspiron 5160 is not turning on.
On plugging the charger, green and amber lights blink continously.
I removed battery and tried but didn't work..(with AC power supply)... Then I tried with battery and no power supply... no luck....
Is this a laptop or charger problem???
I don't know your computer, have you read the Trouble Shooting chapter in its manual? You could try plugging the computer in and leaving it to charge for several hours; my notepad will not display if the battery is flat. Good luck!
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
It is the battery Status indicator and flasing orange light indicates that battery is low. After connecting the charger it should turn solid green, which indicates that the battery is charging and it turns off when battery is charged completely. If it continously blinks, check out the charger and battery.
Dell 5610 owner's manual can be downloaded from: http://support.dell.com/support/edocs/systems/ins5160/en/OM/G74822LRs.pdf Check out Page-15
I have the dell inspiron 5160 works great a little slow but no big deal. The problem I have as of Monday the power cord will not stay in and now will not charge. Is it the power port? Can this be fixed?
I recommend purchasing a new Dell Inspiron battery.
The code 4 blinking orange or amber and one green, means a defective battery. Thank You,Raphael
I am facing a similar problem with 5160 and my power button will not power up the laptop. I presses the shift key, it got powered up (offcourse only fan started but the screen is black)
Try pressing shift key to power up.
Hello Maciekpl,
This is Romeet,i would like to try and help you solve this, please let me know if you have a replacement motherboard for your laptop ready? also let me know how comfortable would you be with opening up the thing and replacing it?
B.Regds
Romeet
