Question about Ricoh Aficio 2015 Copier
When copier turn on and taking copies first 6 copies are printing with some scartches and it comes to paper jam in every. Please reply me with a best solution?
    President:
  • 2,072 Answers
If the paper is not getting out of the tray, the rollers need cleaned.
The scratches. If the paper jams in the hot area. You will need a new hot roller.
Also the scratches may be coming from the drum. Sometimes it is hard to determine between the drum and fuser hot roll.
Posted on Aug 27, 2010
Samsung scx-4521f "paer jam 2"_ i've checked paper inside but i can't see any thing is jammed. if i turn off and on that time 1 paper will be printer ofter one same problem is repete. any advice sir
Sanjay,
I think you should take all unused papers out, close tray and predd print button. If there is paper in the system, it may come out. A red light may also flash asking you to load papers. Now lod the papers and the red light will go off. Put a printed paper and try copying. If it copies, you are ok. Now print from your cpmputer command. If it prints you are ok. If it does not and you get paper jam warning, there may be a small piece of paper stuck in the system. You have to open each feeder and see if you find anything. Good luck.
Jun 02, 2014 | Samsung SCX 4521F All-In-One Laser Printer
How to avoid paper jams?
hi,the best way to avoid paper jam is cleaning.clean
first paper transportation area,second paper feed rolls in trays.send me result
May 31, 2009 | Canon PC-921 Black and White Copier
Copys fine but it takes the paper crooked
Please follow these steps :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Mar 24, 2009 | Lexmark X4530 InkJet Printer
LIGHT IS BLINKING AND NOT PRINTING
dear sir,
dis is the situation when ur printer is not ready.
it means either a paper is jammed inside or the gear has been jammed or the cartirage is not installed properly or the head of printer is damaged.
do reply
Abhinav
Jan 10, 2009 | Lexmark X1270 All-In-One InkJet Printer
No paper pickup
Hi damodarbk:
it sounds like you need to replace the paper feed rollers.
pdouglasss
Jan 03, 2009 | HP LaserJet 3050 All-In-One Printer
Paper jam epson stylus 5400
Dec 08, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Paper jam with 4 x 6 paper
I would tell you how I solved the problem, but it will cost ya !
Dec 07, 2008 | Brother MFC 420CN All-In-One InkJet...
I replaced ink and paper..paper keeps jamming when printing and copying. after the replaced inl and paper, i was able to print with no problem however without warning iunable to print or copy without...
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Oct 20, 2008 | Lexmark Office Equipment & Supplies
How to fix paper jam Epson CX3650?
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
CREDITS: nanicool
IF YOU DONT GET FIXED WITH THIS THEN PLEASE REPLY BACK.
I SHALL BE GLAD TO HELP YOU WITH YOUR PROBLEMS.
THANK YOU
REGARDS
SWEET RASCAL
Jun 28, 2008 | Epson AcuLaser C3000 Printer
Canon ImageClass MP730 - Clear paper jam
Were you doing duplex? take out the duplex and look in side and UNDER it
Nov 18, 2007 | Office Equipment & Supplies
Ricoh Aficio 2015 Copier Logo
47 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
