Question about Whirlpool LER4634J Electric Dryer
A sock got inside the lint trap of my whirlpool gas dryer. how do i get it out?
  • Whirlpool Master
  • 43,501 Answers
Shop vac and that long skinny crevice tool.......yeah, that will pull that sock right outta there...
heatman101
Posted on Aug 29, 2010
How do I remove a sock that fell through the lint trap?
How To Fix Dryer Lint Trap Problems (Removing Items That ...
? 5:32
https://www.youtube.com/watch?v=Fcw1aPqGiSI
Feb 4, 2015 - Uploaded by UKaToNeN
Have you ever had something fall down into the lint trap on your dryer? It`s happened to more folks than you ...
how do I get sock out of lint filter shoot of electric dryer ...
www.shopyourway.com > Manage My Life > Questions
I'm sorry to hear that a sock fell into your lint screen chute and I would like to assist you. Be sure to unplug the dryer prior to servicing it! Do not run the dryer until you are able to remove the sock! There are two ways to do this.
Nov 29, 2015 | Electrolux Dryers
My Whirlpool gas dryer is not working
Instructions
Check that the dryer door is closing completely. Remove anything that blocks the dryer door from closing.
Ensure the "Start" button is pressed firmly to start the dryer cycle, the dryer is not overloaded and the clothing is not balled up. Any of these things can prevent the dryer from operating and/or drying the clothes.
Use a level to confirm your Whirlpool dryer is sitting flatly and evenly on the ground. Adjust the dryer as necessary for it to be level as the dryer will vibrate and make unnecessary noise when sitting unevenly.
Examine the inside of the Whirlpool dryer drum and in the space around the drum for loose change, pens, hair ties and other items that could have been left in the pockets of clothing. These items will cause noise and potentially cause the dryer to become inoperable.
5
Examine the Whirlpool dryer's lint trap for excess lint. Remove any lint from the trap and place it back into position. Always clean the lint trap between dryer cycles. Inspect the area around the dryer and in the ventilation and exhaust systems. Remove any built up lint and clean the area thoroughly. Built up lint is a fire hazard and can cause operating issues.
6
Check the gas shutoff valve if your Whirlpool dryer is gas powered. Ensure the shutoff valve is turned all the way to the "On" position.
7Check the electric plug and ensure it fits securely in the outlet.
8
inspect both the fuse box and circuit breaker for any electrical problems. Replace any blown fuses, if necessary, and reset the circuit breaker if it has been tripp
Jan 09, 2013 | Whirlpool Dryers
Dryer runs but no heat this is a gas dryer
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Jan 25, 2011 | Whirlpool LGR3624JQ Gas Dryer
Gas dryer not heating all the time
Good Luck!!
Jan 27, 2010 | Whirlpool LGR5636PQ Gas Dryer
I smell a burning smell from the dryer. I was running dryer a lot today and tonight I smelt something burning when I opened the door. I noticed my light catcher was full, could this be the problem?
Yes it could have been the lint igniting in the bottom of your dryer in future clean lint trap after every load and take trap door out and vacumn inside trap at least once a month If you ignore the lint trap you could end up with a serious fire so take care of it when you remove screen a certain amnt of the lint falls down into the bottom of dryer and after time a buildup can ignite.. more serious with a gas dryer as the igniter and burner is at the bottom of most gas dryers
Dec 17, 2009 | Whirlpool GEW9200L Electric Dryer
Gas dryer quit heating
Good Luck!!
Nov 01, 2009 | Whirlpool GGQ8831L Gas Dryer
TRYING TO REMOVE FRONT Drum won't turn swallowed sock thru lint trap
The sock is binding in the blower wheel which in turn stops the motor.
Unplug the dryer and turn off the gas supply. Look down at the very bottom of the front panel to find and remove the 2/3 screws across the bottom. Pull the bottom of the front panel out then down to release the clips holding it to the top cover. This will give to access to the other parts to retrieve your sock.
Oct 31, 2009 | Amana ALE443RAW Gas Dryer
A sock fell in the vent of my whirlpool dryer
If you mean the lint trap, try this: Unplug the dryer. With a dryer brush (~$10.00 @ Lowe's/similar), bend to approximate the curvature of your cavity and try to retrieve. If this doesn't work, slide/scoot the dryer out and remove the venting duct. Carry outside and dump. If no sock there, look into the dryer exhaust (where the duct connects). Use the brush again to retrieve said sock (and generally clean as you go, as it never hurts). Also look at your vent where your dryer exhaust passes through the wall, clean as you go..... This should get you back up and running.
Regards, --W/D--
Jul 17, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Roper dryer by whirlpool- gas dryer
You have a severly blocked vent, its not removing the moisture to the outide but instead getting trapped in vent.reccomned reventing unit with solid duct pipe, not the vynyl flex tubing and mke sure the outside exhaust port is totally free of obstruction a well
Feb 24, 2008 | Dryers
Whirlpool LER4634J Electric Dryer Logo
65 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
