Question about Beeman 1024 Takedown Rifle, Scope, Rings & Case air rifle
Its a Brand new gun and when I **** it the trigger will not set so the gun will not fire
    President:
  • 2,702 Answers
The fault is the triger return spring,,,,,,,get it looked at,,,,,
by a gun smith,,,faulty triger are dangerous,,and killers too?
Posted on Aug 28, 2010
New nailer double firing and jaming
Some trigger valves (tva6) are sensitive (defective?) however there are some things you can try to change how the gun acts. I have noticed that the brand of oil has an effect on the orings. Some brands will swell the orings, I like Paslode nail gun oil. Do not wash the gun with gasoline or wd40. Use diesel. Change the nail depth setting one position. Lowering the air pressure will make a difference. I find that most operators use too much pressure. A stronger safety spring under the trigger will separate the trigger and firing pin quicker. Finally you could use single fire trigger. Good luck
Jan 16, 2014 | Stanley Bostitch Rn461 Gun Coil Roofing...
Keeps repeating itself
Most nailers have a two position setting on the trigger to allow for single fire or bump fire. If set on bump fire, the gun will work better when you bump fire the gun instead of placing the gun on the work then depress trigger. Bump fire works best when safety spring has good tension. Easy test. Make sure that the safety spring is in place (with air hose removed, contact foot should spring back quickly when pushed against work). With air connected, hold trigger and quickly bounce the gun against the work. If the gun does not fire when you bump, the trigger is most likely set to single fire. With trigger set to single fire, you must place the gun against the work, then depress trigger. If the gun shoots two nails while set to single fire, most likely worn trigger or worn out trigger valve. These parts are not expensive and are easy to replace. Good luck
Apr 12, 2013 | Dewalt D51321 3/4" 1 3/4" Heavy Duty Coil...
My new porter cable RN175B nail gun won't discharge a nail
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
Nov 21, 2012 | Air Tools & Compressors
Gun is full of nails, but acts like it is empty (the plunger won't advance). You go to tap it with the trigger pulled, and it just does nothing. Seems like firing pin is not getting air or somet
If no air is leaking from the gun, take out the nails, remove trigger by removing 3mm hex head bolt to expose the trigger pin. With air connected and side door open so that you can see the feeder, quickly depress the trigger pin with finger. Gun should fire. If gun does not fire (only makes air sound at trigger) dissconnect airline, remove head and lube headvalve with white grease and reinstall. Test again. If ok replace trigger. If still no joy, replace trigger valve with new factory or generic (part # TVA6). If gun fires but does not activate the feeder claw, remove two 6mm hex bolts from front of gun and split apart upper and lower body and check white oring (part # 149885) Good luck
Oct 16, 2012 | Stanley Bostitch Rn461 Gun Coil Roofing...
Nail gun problem
This is a bottom fire tool. (NV83A2) You need to hold the trigger down and then as you place the nailer to the wood the safety will depress and it will fire once. This is usually done in one, swift action. If you do this in the opposite way by placing the tool to the wood and then pulling the trigger they often will double fire.
Jul 05, 2012 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
Hitachi NR83AA shoots two nails on one pull of the trigger?
Best practice is to bump fire the gun to prevent double fire. Do not place the gun on the work and pull the trigger. This takes practice while using at an angle. Works better if the nose piece has rather sharp points to help nose to stay in postion while you bump. With trigger depressed, practice without nails bumping/hitting wood at different angles untill you can bump hit at the spot that you need the fastener. If the gun double fires while bump-firing, most likely all the safety/trip parts are worn/loose. Not expensive to replace. Good luck.
Jul 05, 2012 | Air Tools & Compressors
NR90AE Nails jammed how to remove
New user will jam the gun/ nails because gun was most likely not bump fired. Placing the gun then depressing trigger will usually cause double fire in the hands of new user. New user should practice on scrap lumber bump firing at many angles till they get the idea; or give them a training period with a nailer that has a single shot trigger (they may develop bad habits with single shot however).
Nov 14, 2011 | Hitachi NR90AE Full Round Head Framing...
Pull the trigger, no nail, only continuos air until I release tyhe trigger. not jammed, gun is clean, very new. acted that way right out of the box then it worked and then not and so on, worked...
Safety foot and lever inside of trigger are not pushing the trigger pin all the way in. To verifty that the gun will fire, remove the nails to allow for dry fire. Remove the trigger to reveal the trigger valve. Hold the gun against old coiled rubber hose or soft wood. Very quickly depress the trigger pin all the way in. If the gun fires, adjust safety foot and trigger so that the trigger pin is fully depressed when your bump fire. If the gun will not fire after adjustment, remove the head and lube headvalve/orings with silicone paste lube.
Sep 03, 2011 | Stanley Bostitch Mcn150 Strapshot Metal...
Nail Gun Problem
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
Sep 01, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Beeman 1024 Takedown Rifle, Scope, Rings & Case air rifle Logo
322 people viewed this question
Top Beeman Optics Experts
D. E. Hev
NOEL
NOEL
Are you a Beeman Optic Expert? Answer questions, earn points and help others
