Question about Necchi 3101 Mechanical Sewing Machine
Is this machine sutable for upholstry work - Necchi 3101 Mechanical Sewing Machine
    Genius:
  • 1,788 Answers
Make sure you use a heavy duty needle, maybe a #16 or #18 and you should be fine
Posted on Aug 27, 2010
Do the omega 420 handle upholstry thread
Most domestic machines would have difficulty using upholstery thread. Upholstery thread is generally very heavy so the tension settings would need to be adjusted on the machines. Evenso, the tension mechanisms adjustments still may not be enough to accommodate heavy upholstery thread.
Even if your machine can accommodate the thread, your machine's motor could be compromised trying to sew upholstery fabric.
Oct 19, 2017 | Omega Sewing Machines
While working, the embroidery machine stopped with this message on screen.I stopped it and worked a few stitches and the stopped again with the same message. The next day I started the machine again a
Please you ask your machine service provider or embroidery Machine service mechanic. My suggestion Normally every year machine service and over oil the machine is safest way.
Feb 06, 2014 | Sewing Machines
Automatic thread cutter not working on Brother super galaxy 2 embroidery machine
you may have to take the machine in to a sewing machine shop to find out why the cutter is not working
Apr 25, 2012 | Sewing Machines
Touch pad on front frozen up
The machine is a "computer" and needs to be repaired by the dealer.
Mar 14, 2010 | Husqvarna Designer I
I am sewing upholstry fabric together in a pillow with piping and heavy zipper. Thread will not go through fabric correctly and there are no stitches.
Hi. Unthread and rethread everything, clean out any lint, and oil the machine. This, plus using the right size needle (size 16 or higher) and thread (heavy duty), should do the trick.
Let me know if this solves the problem, ok?
Jan 19, 2010 | Singer 7442 Mechanical Sewing Machine
Feed dog lever not working on my Kenmore 385 24 stitch machine
I surfed around this site for various suggestions, finally took the bottom plate off and cleaned and oiled all the parts along that rod that goes right across (think it's a drive bar that rotates). Ran the machine without thread in for a few minutes to let the oil soak in. Machine now works fine.
Oct 06, 2009 | Kenmore 16622 Mechanical Sewing Machine
The foot control for our 1214 pfaff sewing machine burne out (quit working) we took the machine to a repair shop and they replaced the foot control with a "Supreme" electronic foot control. The machine has...
if the first guy did not replace it with a pfaff foot it will not work right the pfaff machines will work backwards of normal power feet and they have to be replaced with pfaff feet
Aug 03, 2009 | Sewing Machines
My machine is locking and apparently tangling up inside of the bobin case
You also need to adjust the pressure foot on the top of the machine. This regulates how much pressure is put on the fabric and the feed. Sounds like it is wrong somehow-maybe you need more pressure. Check the pressure adjustment is screwed in properly if it is this type which unscrews.The pressure adjuster Im reffering to is generally a silver colour and looks a bit like a basic tyre pressure guage or pressure cooker valve-it just got a cuple of lines on it and sits on the top left of the machine above the needle bar. The other thing which could cause problems is the bobbin tension-make sure it is running thru smoothly but not too loose.
Sep 06, 2006 | Singer 3343 Mechanical Sewing Machine
Necchi 3101 Mechanical Sewing Machine Logo
14 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
