Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Water will not run into the icemaker , stop making ice
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Aug 28, 2010
Uline under the counter icemaker not making ice. Fed from RO water and had filters replaced to help but didnt. All is running fine, but not making ice. Dups one tray every 12 hours then stops
Is the condenser fan running? Is the condenser clean? (condenser is the "radiator like" coil outside of the ice box. It cools the hot refrigerant.
Sep 07, 2012 | U-Line Icemaker
I have a GE profile TFX26PPdaWW refrigertor which has stopped making ice. The bar is down, so the icemaker is on. Every once in a while the interior arm will turn to force ice out, but nothing comes...
The place to start is at the fill tube going into icemaker...look into that and make sure its not frozen up with an ice plug. if it is, the inlet valve is bad..defrost the tube and this will give you temp service while looking for new valve..
if no ice plug , then the fill valve is bad or your icemaker. if you have water and ice..its a dual valve..One side does water and the other does ice..the ice side could be bad, but you have to replace the whole assembly...I would take a ohm meter and ohm out the coil,or run a cheater cord to it and see if it opens.(this means run 110 volts directly to coil) if you get water inside to icemaker, more than likely the icemaker module is bad, but ,I would replace complete icemaker assembly
Jan 23, 2011 | GE Refrigerators
Ice maker stopped making ice
Pour about 1/2 cup of water into icemaker . If it dumps , replace the water valve . If doesn't dump , replace the icemaker . Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | Refrigerators
GE Icemaker stopped making ice. everything else
Try these steps
  1. Check the shutoff arm
  2. Check the supply valve
  3. Inspect the water supply line
  4. Test the shutoff switch
  5. Check the freezer temperature
  6. Inspect the ejector gear
  7. Test the ejector motor
  8. Test the ice mold heater
  9. Test the holding switch
  10. Test the water inlet switch
  11. Test the thermostat
  12. Test the water inlet valve
pls rate my suggestion.......
Jul 25, 2009 | GE Monogram ZDI15C Automatic Icemaker
Icemaker quit making ice; water works
is there ice in the maker but will not droup out?
Jul 23, 2009 | Whirlpool GS6NBEXR Side by Side...
Icemaker not producing ice
you need to troubleshoot the problem, if the wire arm that tells the ice maker to stop making ice when full is in the upright position the ice maker will not make ice. the problem has to be either the switch on this arm malfunction. but probably in MOST cases it is your electronic water valve which has gone out. this is located on the water supply line on the back of the fridge at the bottom probably behind some cardboard or plastic. it is the same kind of water valve as a dishwasher uses, if it malfunctions it will not deliver water to your tray, manually fill the tray and put the arm down, if the maker dispenses the ice out of the tray, chances are your electronic valve is broken.
Apr 07, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker not making any ice
check water valve or it is the icemaker water valve have two side one side icemaker other side water
Jan 19, 2009 | Kenmore 53082 / 53084 Side by Side...
The icemaker in my Bauknecht KGN 7010 F/F has stopped making ice
First you need to find out if the lie is blocked. Disconnected water feed and try to run water through it into a bucket or sink. If you get water it is a valving problem. Also make sure the filter is clear.
Dec 29, 2008 | Freezers
Kenmore koldspot model 106.56532400
Oviously you need water first. You'll have to check that the fill valve is opening and that the water is making it to the icemaker. Make sure the fill tube that feeds the water from the back of the frige to the icemaker is not frozen. Be aware, just because you get water at the dispenser doesn't mean the valve to the icemaker is ok. If you are getting water, you need to check that the icemaker is not jammed, sometimes ice can fall back into the icemaker, or get caught in the ejector. You may need to remove the icemaker and run the mold under hot water to melt the ice. If it was jammed, you'll need to check that the fill level is correct to prevent it from happening again, both too much water and too little water can cause problems. There is a heater that helps loosen the ice from the mold, because of that there is a thermal fuse to prevent it from over heating. It will be molded into the wiring harness supplying power to the icemaker. If you have continuity through the fuse it's ok. If you don't the heater shorted and you will need both a new icemaker and that wiring harness.
Jul 19, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
13 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
