Hi
Thanks for using FixYa. From what you have described it seems to be the Thermal fuse that has gone bad. The thermal fuse is mounted to the exhaust duct inside the back cover panel. When this fuse goes bad it should be replaced as it cannot be repaired. You can test it for continuity between its two pins, no continuity means bad fuse. If this is fine then you’ll need to check the thermostat, igniter and coils. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
