Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My garage door will not open. LED blinks 5 times, This happened this morning and still not opening. Lights will not turn on either. One of the sensors stays on all the time even when I took of from its position, the other sensor light will go on and off if it is not aligned.
    President:
  • 3,197 Answers
Sensors are working properly. That is not your problem. The light blinking 5 times is sending the code for RPM sensor or motor overload. Most likely if it is doing this with the door closed it is a bad RPM sensor which is a small printed circuit board just in front of the motor.
Posted on Aug 27, 2010
The unit is displaying a sequence of 5 flashes with the amber light. When I try to open the door, it will only go forward and backward aprrox. 1 ft. Any suggestions on what I should do?
Craftsmsman 1/2 HP opener indicator light blinks five times ...
? 0:29
https://www.youtube.com/watch?v=AvXJd-tYCJ0
Apr 28, 2012 - Uploaded by bship452
Then showing the amber indicator light blinking 5 five times, stops ... push remote to operate opener, you hear a clicking sound from the unit. ... Show more .... blink 5 times (looks almost alike) If I forced the garage door closed, ...Missing: sequence
Sears Garage door opener problem - Home Forums
ths.gardenweb.com > Home Forums > Garages/Workshops
Jun 27, 2006 - Now, I cannot get the light in the sensor at the door to come on. ... the green LED went OUT about 1/2 way up the door opening sequence. .... other is working (I don't recall if it's green or amber, but know that it is lit.) ... Their is also a green LEDflashing 2 times every 5 seconds or so at control center of unit.
Craftsman Garage Door Opener Problem - Home Forums
Jan 05, 2016 | Building Materials
Automatic door lock 1999 toyota prerunner
hi jerome
I have the procedure for Toyota auto lock, is worth to try it
AUTOMATIC LOCK SETTING
1) Step in the vehicle and make sure that all doors are closed completely
2) Insert the key into the ignition key cylinder.
3) Wait for more than 5 seconds.
4) After turning the key to the ACC position, turn the key from the ACC to the
ON position 5 times within 10 seconds (Last position : ON).
? Status Monitor LED will illuminate for 30 seconds.
Note : In case you implement 6 times or more by mistake,
action steps 6)-8) you made will be canceled.
Please retry from step 2).
5) While the LED is illuminated :
• Open and close the driver's door 2 times.
• Turn the key to the ACC position.
? LED will continue illuminating.
? Indicator lights will flash 2 times.
Ignition controlled door lock ON :
6) While the LED is illuminated:
• Open and close the driver's door 1 time.
• Turn the key ACC-ON-ACC 1 time (Last position : ACC).
? Indicator lights will flash 1 time.
? LED will extinguish.
Ignition controlled door lock OFF :
6) While the LED is illuminated :
Jan 28, 2014 | Toyota Camry Cars & Trucks
Liftmaster 1245 led blinks five time but door will not open
5 flashes of the LED is the code for "RPM sensor or motor overload." You can try unplugging the opener for about 15 minutes to see if it resets itself. Normally if it is the RPM sensor the motor will run for a few seconds and then turn off. Is the door not opening or not closing? Just checking to make sure.
Nov 09, 2011 | Sears Craftsman LiftMaster Chamberlain...
Learn light is blinking in a serise of 4 times.
The light is sending the code for:
Safety reversing sensors slightly misaligned (dim or flashing LED).
Tweak the sensors to make sure they are pointed at one another and both lights are lit and not flickering. If your opener is working okay then you may just need to unplug it for about 5 minutes and it should reset so the blinking light quits.
Oct 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman garage door opener model 139.53674SRT2. It was working fine and we opened it and closed it twice today with no problem. The third time we opened it, it would not close. Both led...
The led blinking 5 times is the code for "RPM sensor or motor overload." The motor has an thermal switch which opens when the motor get hot from running too much. This automatically resets itself after about 15 minutes. This problem can also be caused when the door opens too far and the trolley jams against the bolt just in front of the motor unit. To correct this you need to loosen the chain enough to eliminate the tension against the trolley and then run the motor until the door closes. While the door is closed locate the 'up limit' control on the side of the motor unit. Turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Jul 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftman garage opener
The blinking LED is sending the code for "RPM sensor or motor overload. It isn't the motor or it wouldn't run at all. The RPM sensor is a small printed circuit board near the front of the motor. It will be available at Sears or any good door opener service company.
Jun 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
L.E.D lights at back constantly blinking, garage door won't open
If the LED is blinking randomly it is normal. If it is blinking rapidly you have interference from somewhere. To eliminate any interference start unplugging anything electrical and watch the LED. Some things will interfere that you wouldn't even think of like a heater in an aquarium. Check everything especially in the garage.
Jun 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door indicator light blinks 5 times
this probably means you have a bad photo eye if you happen to have to doors side by side may be picking up on other sides photo eye just switch sides from left to right, however if the lights are coming on but does not mean that photo eye is not bad it has a small circuit board inside of it...
Apr 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener Clicks only and LED blinking 5 times
Just fixed this problem tonight. Had the 5 blink/flash thing. Opened it up and saw that the motor wasn't spinning so it wasn't a bad rpm sensor. Jumped the red to black and then the blue to black to verify motor worked. At that point assumed it was the logic board not telling the motor to start, but I could hear the click of the relay. Pulled the logic board out and noticed a solder joint that had failed directly behind one of the relays. Resoldered that joint and the garage door opener worked again like a dream. Hope that helps someone else.
Feb 28, 2009 | Building Materials
first off, hitting extra button on remote would not do anything. Is door up or down/ where is trolley that attaches to chain, by door or motor. Is is jamned against a bolt. Try a paper clip and jump from white to read terminal. Does it work. Does light bulb blink 10 times. I ignore the diagnostic lights and go by symptons. Give more info.
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
319 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
