Question about Cell Phones
I tried using 3 AA NiMH batteries (total DC V=4.2, 1600mA) as a backup/charger for my HP Ipaq 612c battery. I inserted a resistor (4.7 ohms) in the circuit to reduce the current. The red light charging indicator of Ipaq blinks intermittently when I attached it using the usb cable. Is there really a problem/error in doing this? thanks.
  • 905 Answers
You built one of these too, eh?
Yes, there can be a problem doing this. First off, 3 AA batteries does not equal 4.2 volts, they are 1.2volt nominal so 3 * 1.2 = 3.6volts. When they are just off the charger, terminal voltage will be closer to 1.5v, so 1.5*3 = 4.5 volts.
Using ohms law, E=I * R, we can find your current as I = E / R or I = 4.5v / 4r7 as .95Amps (almost a full amp) that you would see worst case. The resistor is doing nothing for you.
The reason that the charge light blinks intermittently is because the charge controller (lithium battery, right?) is pulsing due to low voltage.
Try this: Take *6*, yes, 6, AA batteries, your choice of chemistry, and put them in series. That will give you a nominal (alkaline) voltage of 9v. Connect a low dropout 5v regulator such as an LT1117-5. Then you will be able to use your battery backup much more effectively.
On a different note, I used 4xAA (NiMH) and powered my ipaq 3650 directly. Worked great. Your mileage may vary though.
Posted on Aug 27, 2010
Testimonial: "Thank you so much krbjmpr. BTW, am suing NiMH too and the Ipaq battery is rated 3.7VDC 1590mAh. Will surely try your suggestion. Thanks again."
Why doesn't it charge batteries?
Some nickel Clyde batteries have different impedance and need a certain charger to charge that battery.
If you read this web page you can see what the differences are between certain nickel batteries.
http://www.powerstream.com/NiMH.htm
They have to be from the same company that made the charger to be exactly sure that they will charge and they have to be NiMH to charge is that charger. Any lithium polymer battery will not charge in that charger as far as I can understand it.
Dec 28, 2015 | Vivitar V-Power 2 Hour Ac/Dc Charger With...
Which AA battery shall I buy for my digital camera? 1500? 1000? 2500?
Although you could use these, do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights. The lower capacities suggest NiCd batterie. Also don't use these.
A set of new NiMH batteries, from 2000 to 2600 mAh with a good charger, will be fine.
Two things.
There are very fast chargers around. Don't invest in them. I payed 80 euro for a quick charger. Could charge 2700 mAh batteries in 15 minutes. The charger killed all my NiMH batteries I had (more than 40) It took me till the fifth or so died, before I realised it could be the charger. Since I stopped all my batteries one by one died and I had to replace them all
I now have some "fast" chargers that take 2 to 3 hours and the new batteries Can handle that.
Better buy a slower charger and some good batteries, than the other way around.
Second. Test the 2600 mAh batteries, if they fit.
To put more capacity in the "same" AA battery some brands made them slightly thicker. So it could be you can't get the largest ones in your camera.
Mar 21, 2015 | Cameras
I have a Panasonic ES8023 rechargeable razor and I want to replace the batteries in it. Where can I find replacement batteries?
When my ES8023 razor quit working, I decided to buy and try a Braun Series 3 razor that ultimately I was dissatisfied with. I favor the Panasonic's narrower head. Deciding to replace the Panasonic's batteries, they were very easily removed. Noting they seemed barely larger than AA batteries, I decided to try replacing the OEM Ni-Cd batteries with some NiMH batteries I had. My only real concern was whether the NiMH batteries would charge adequately from the ES8023 charger....they did, which was great news since Ni-Cd batteries are inferior to NiMH.
Adapting the shorter AA NiMH batteries to the shaver was as simple as laying a small hex nut (#10-32 size I think) upon the negative (upper) terminal in the shaver and then inserting the battery. This makes for a tight fit and provides contact for teh negative end of the battery. The positive nub of the battery makes contact to the shaver's positive terminal with no issues.
The original battery has a long pin extending from the positive tip that I think may be to provide a pin that extends through the shaver body for a charging cord to connect to. However, for the induction charger of the ES8023, I didn't think the pin would be needed, and it wasn't. With two NiMH batteries inserted as described and the shaver reassembled, I successfully charged the shaver overnight in the original charger. I believe NiMH batteries typically charge at a higher current draw than NiCd batteries do, so I do expect a longer charging cycle to be required, but I don't anticipate any issues.
Mar 07, 2011 | Panasonic Linear ES 8003 W Electric Shaver
What charger should I get for my Evader EXB
I show your car uses 8 “AA” batteries, 6- or 7-cell NiCd or NiMH battery.
Radio Shack or The Shack will have a replacement and the store people should be able to guide you to the correct plug and polarity. NiCD and NiMH batteries are easy to work with, buy, replace and charge. If you use 8 AA batteries, that is 8 X 1.5 (volts) = 12 Volts DC. NiCD and NiMH style batteries should deliver about the same but dont expect to get performance from a NiCad battery as they dont offer enough power.
Apr 09, 2010 | DURATRAX Evader Exb 1/10 Electric Buggy...
I need a charger for my hp ipaq but i don't know what series
In general, there's three types of charger you might need. Really ancient iPAqs used a round DC jack type charger, then there was a long time where all iPaqs used the same flat 22-pin connector. More recently, HP has moved to the same mini-USB plug used for a lot of mobile devices.
If you're really stuck, try http://www.ipaqrepair.co.uk/store.php?cat_id=25 and match your iPaq to the pictures.
Jan 12, 2010 | HP iPAQ 612C Smartphone
When I insert some batteries the red light begins blinking. I also have some Duracells that appear to be charging but when I place them in the appliance they are dead.
All chargers cannot charge all types of batteries. Are your Duracell batteries NiMH or Alkaline? These indications generally happen when you insert a battery type that is not rechargeable.
Dec 13, 2009 | Duracell AA/AAA NiMH Battery Charger with...
Battery backup related
Most of your data (phone directory, calendar etc) is stored your pda's ram. If your LiON battery runs flat , the pda wont start up, your backup battery kicks in to preserve the data. If your NiMH battery runs flat, you will loose all data in the phone or the equivalent of a hard reset.
Nov 29, 2007 | HP iPAQ h6315/h6365 Pocket PC
Back up battery
 recharge the battery by connecting the HP iPAQ to AC power using the cradle or the AC adapter or insert a fully charged battery into the HP iPAQ.
Oct 07, 2007 | HP iPAQ hw6515 Pocket PC
Replacing Nimh battery in iPaq h1945
check http://www.ipaqrepair.co.uk - they've got a pdf you can download and print. It shows 11 steps needed to replace the battery - comes with well written descriptions of each step and illustrative pictures - and its free
Sep 07, 2005 | HP iPAQ H1945 Pocket PC
Cell Phones Logo
70 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
