Question about West Bend (58036) 36-Cup Coffee Maker
My Heating element circuit is open... Where can I purchase a replacement??? Thanks in Advance!!!
  • West Bend Master
  • 43,501 Answers
<a rel='nofollow' href="http://abtecparts.com/westbend.htm">http://abtecparts.com/westbend.htm</a>
Posted on Aug 27, 2010
Dishwasher not finishing cycle
A10 4 + 6 Heating circuit Heating element, connections, module,
relay, pressure switch
A10 Open circuit in heating circuit.
• Check the circuit of the heating element (26 ohms).
• Check for an open circuit heater cut-out.
• Check pressure switch open circuit (connections 11-14).
• Check wiring and connections between module card, pressure switch and heater.
• If all above is OK, replace module card.
Sep 18, 2014 | Hotpoint 24 in. FDW60 Free-standing...
Kenmore dryer bought in 2004 stops heating
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Thank You
Nov 01, 2008 | Kenmore 64852 Electric Dryer
Hello. My dishwasher is ARISTON HOTPOINT LI 480 A, built in. While washing, something cracked inside, and a white smoke appeared in the upper right of the machine. Can you help me with this ? Thanks in...
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 06, 2011 | Dishwashers
Coffee pot will turn on but nothing else happens.
If you feel capable of safely opening your device (disconnected from the mains) check the continuity between the thermal overheat device and the heating element.
If it is open circuit, replace the thermal cutout like-for-like. If it is closed circuit, check continuity on the heating element.
If the heating element is open circuit then it will require replacement.
Mar 25, 2010 | Black & Decker Coffee Makers & Espresso...
Replacing a heating element on Maytag Electric Dryer
Hank,
if you have all those parts , i would indeed replace them all. it will allow your entire heating circuit to strat fresh
just ensure all your paddle connections are tight
but check your heater for continuity too
Oct 21, 2009 | Dryers
Heating element has stopped working just 2 days
use a multimeter to check the continuity of the heating elements. if there is an open, replacing it will solve the problem.
Aug 04, 2009 | Dryers
Frigidaire FEX831CS, dryer not heating...
That could be your high limit switch. Unplug dryer and gently pry on tops left and right corners, Try not to scratch your paint on corners. You lift top up and lean and lay it back so its against the wall behind it. Near back you will see the high limit on the right side rear. Need to check continuity by taking one of the wires off and use a multimeter to see if circuit is open, if so it will need replaced. I have the repair manual if I can help you, Thanks Sea Breeze High Limit here
d6ca979.jpg Heating element in this pic
0538436.jpg seabreezehvac@yahoo.com
Apr 21, 2009 | Dryers
Replaced oven heating element, now trips electric
Disconnect the new heater and try it again , if it still trips then your problem is elsewhere, if it does not trip, then it points to the new element being faulty.
If it is fan assisted make sure the fan is running o/k.
Hope this helps.
Please leave feedback.
Thanks.
Dec 08, 2008 | Ovens
West Bend (58036) 36-Cup Coffee Maker Logo
26 people viewed this question
Top West Bend Coffee Makers & Espresso Machines Experts
Douglas Dinnebeil
Douglas Dinnebeil
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
