Question about Craftsman Garden
I HAVE A 18.5 HP. 42 IN. CRAFTSMAN RIDING MOWER WITH A BRIGGS ENGINE. I HAVE REPLACED FUEL FILTER, FUEL LINES CHECKED CARB (LOOKS LIKE NEW), CHANGED PLUG, NEW FUEL, CHANGED AIR FILTERS, CHANGED OIL AND FILTER , AND CLEANED COOLING FINS, AND IT RUNS GREAT FOR ABOUT 15 OR 20 MINS. AND DIES. LET IT SIT FOR A WHILE AND IT DOES THE SAME THING. NOONE SEEMS TO KNOW WHAT THE PROBLEM IS. COULD IT BE A SWITCH ?
  • 905 Answers
Definitely sounds like a thermal issue, likely with the ignition module.
Try this: Wait for it to cool, then start it up again. Run it as you normally would, and wait for it to die. When it does die, pull the spark plug boot off the plug, use a spark gap tester, and see if you still have spark. If you don't, then suspect the ignition coil, perhaps the disable wire might be grounding out as it snakes around and eventually to the off switch.
If you still have spark, then check the fuel shutoff / anti-diesel valve (if equipped) on the bottom of the carburetor bowl. Look for damaged wiring. When you turn the ignition on, and try to start, this valve should have 12 volts going to it to allow fuel to flow. Otherwise, look for problem between valve and on switch.
Another area to check, especially if it tends to backfire, is that the woodruff key (shear pin) on the flywheel isn't damaged (partially sheared).
Posted on Aug 27, 2010
18.5 hp 42 inch cut, craftsman riding mower loses power after 10 min.
Us start here, remove fuel line from carb. Hope fuel runs out.
Check the direction of fuel filter. There arrows on it. Arrow toward
carb.
Aug 09, 2012 | Craftsman Garden
Craftsman 917.270514 not starting?
check to see if your getting power to the solenoid on the bottom of the carb a bad safety switch will shut it off they also stick closed from old fuel
Jun 04, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have A craftsman riding mower 18 1/2 hp 42 inch deck have changed spark plugfuel filter took off tank and blowed it out but the mower still cute off after about 10 minutes like it has no gas what else...
Do you have a Briggs or kohler engine.I am having the same problem.I have changed the fuel filte, fuel pump, and cleaned the carb.Sears has been no help at all.The reason I ask about the engine you have is that people are having the same problem no matter what engine they have.So therefore it probably is not the engine so it is something else on the mower.My mower runs fine for about 10-15 then starts to stutter and backfire.I am continuing to pursue this problem and I will post back here if I come up with anything.
Jul 06, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cleaned gas and changed fuel filter. Mower only
There are a number of things that can cause this, depending on the engine fitted. Assuming a Briggs & Stratton V-twin...
Check that the carb solenoid under the float bowl is connected, has battery voltage when the ignition switch is at 'RUN', and is functional.
As a quick check, with the engne OFF, turn key to 'RUN' there should be an audiable 'click' from the carb if the solenoid is working.
After that, check that the fuel pump is delivering fuel (disconnect output, and crank engine). SHould be a good flow.
Oct 01, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My craftsman riding lawn mower conks out even after we have changed the air filter, deck belt and fuel filter -
clean the carb and make sure the fuel filter is not got something in it...or the fuel lines before it.
Aug 14, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman lt1000 18 hp briggs keeps wanting to die
could be a dirty carb. Did you use stabil over the winter. Also could be a govener problem.
Jun 23, 2009 | Garden
Weird under load symptom briggs 17.5
a couple other checks would be to dump the carb resevoir where the float is, water under the float could be accumulated and closing the fuel off, due to density. out here on the farm we never use the gas to the last drop from the can. also the linkage between the motor fan blade, (govenor) might have been connected to the carb incorrectly. or a bad switch interlock on the mower blade.
some briggs motors are hooked wrong straight from the factory, where the throttle linkage is concerned. ( and the little spring is pretty hokey too)
May 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
175 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
