Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
My Kohler CH20 Command Engine has begun to dilute the engine oil with gasoline...it runs fine then puffs out some black smoke and acts as though it is flooding out. When I first checked it there was a good bit of engine oil on top of the engine. What's up with this?
Bad flot/needle and set gass fill the carb gets on top of the pisten gos passt the rings filling crank with gass. very comin good luck. !! MooseMan
Posted on Aug 29, 2010
My toyota d4d hilux double cab is emitting black smoke
Black smoke is usually excess fuel, that can be caused by things such as leaky fuel injectors, bad coolant temp sensor, weak spark (bad coil?). You don't say what year or engine. If a carburetor, it may need overhaul. If excess fuel gets really bad, it can wash the oil off the piston rings and cause rings to wear, plus dilute engine oil causing bearing failure.
Oct 09, 2016 | Toyota Cars & Trucks
Oil is pumping into the carb adn air filter of my kohler 2 cylinder workman engine
Make sure you have good compression. Sounds like you have blow-by. Crankcase vents into the air box.
Aug 21, 2014 | Kohler CH25 PA-CH730-0040 Command Gasoline...
What would be the cause of a Kohler 25hp twin, backfiring through carb from one cylinder
Bad plug, ignition wire, valve clearance, or valve damage, vacuum leak at manifold. Timing cam off / damaged
Jun 16, 2014 | Kohler CH25 PA-CH730-0040 Command Gasoline...
KOHLER SMOKES STARTS UP ONLY HOT OR COLD,NO SMOKE WHEN RUNING
look down inside air cleaner before starting next time , if theres more than a finger full of motor oil in there then your head gaskets are going
May 20, 2014 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler 18 hp command engine, 2 lbs. oil pressure how do I solve problem
Check oil type and viscosity, check oil filter for correct OEM type and make sure it is new. Then re-check, then check the oil pump.
Sep 19, 2013 | Kohler CH25 PA-CH730-0040 Command Gasoline...
I have a 2010 koler comand 25 hp that blowes blue smoke when starting but dosent due it all the time its on a 2010 lazer with 150 hrs thank you
The valve guides are bad and oil is running down into the cylinder when the engine is off...when you start it the oil burns off making the blue smoke...the only way to fix it is to rebuild the motor...
heatman101
Aug 30, 2011 | Kohler CH25 PA-CH730-0040 Command Gasoline...
CH670-0011 22hp in cub cadet 115 Hours smoking replaced head gasket but observed that ring job was needed Is this a normal problem with the Kohler V twins?
no it is not common long period's of sitting the lube will wash off the rings and a squirt of oil will help prolong life of the rings that's if the engine was sitting for a wile hope this helps
Aug 23, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Oil leak on riding Craftsman LT2000 (Kohler)
Fortunately, the engine oil doesn't go through any rubber hoses, so they are mouse-proof. The oil probably leaked out through an engine seal. Oil on the engine surfaces would smoke when it gets hot. Check your oil level and top it up if necessary, before you run the engine again. The engine can run fine even with a slow oil leak; you just have to watch the oil level from time to time. The leak could be easy to fix - by tightening up a few bolts -- or expensive.
The gas runs through rubber hoses, though. If mice ate through that, I think you would have smelled the gasoline, and the engine wouldn't run for more than a few seconds. But if you see a severed hose, you should replace it. Take it off and bring it to a mower shop or auto supply shop, and buy something the same diameter. Inexpensive.
Hope this helped! If so, please rate my answer, thanks!
Jun 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Kohler CH20S losing power, blowing black smoke and oil
Sounds like engine is flodding. Have carb float checked, make sure it is at the correct height
Feb 04, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler k582 runs poorly at operating speed. ok at idle. ambient temperature is 30 degrees.carb main fuel needle adjustment is ineffective. backfires with occasional black smoke. condition started as...
ALWAYS CHECK THE POINTS!!! 20 years operating this engine and you'd think I would know better. The points were severely pitted. Spec said .020 but actual is .013. The cold weather had me suspecting a carb problem. DOH!
Jan 13, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
577 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
