Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Water is forzen in cube despenser but does not dump out
  • KitchenAid Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Aug 28, 2010
My ice maker isn't despensing enough ice fast enough to fill the ice bucket up
Ice makers spray cold water upward into cube shaped trays that freeze the water almost instantly upon contact . Then when you press the ice dispenser a heater comes on that releases the ice cubes from the metal trays. If it is very old replacement probably a good option.
Nov 27, 2017 | Refrigerators
Ice maker don't make ice
Pour about 2/3 cup of water into the ice maker . If it dumps the cubes but doesn't refill with water , replace the water inlet valve , behind refrig , where the water line connects to on the refrig .
If it does not dump the cubes , and the cubes stay in the ice maker , replace the icemaker .
Oct 13, 2009 | GE Refrigerators
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
Icemaker makes ice but wan't despense, also water wan't despense
i have model mfi2067aeb . the ice maker won't dump the ice. the arm is up that tells when the tray is full. can't get it down.
Jul 16, 2009 | Maytag MFI2067AES Stainless Steel Bottom...
The water despenser works but the icemaker doesn't
The most popular problem area is the fill tube by the icemaker. Check for an ice build up inside of the tube. If that isn't the problem, you must ck the coils on the filter valve and the coils on the supply valve with an ohm meter. Check for kinked water lines, leaky water lines etc. An after thought, make sure that the icemaker itself hasn't got a huge bunch of ice it built up and can't dump out.
May 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
Crushed Ice only
I have a similiar problem. I have dumped the ice and started ice maker again. It make ice but will not despense ice cubes.
Apr 27, 2009 | Refrigerators
Icemake rarely dumps ice and when it does they are small cubes
There has to be a restriction in the water supply line from your saddle valve, ( shut off valve on the cold water line ) to the water valve. It can be in the category of, the hole in the water supply line is getting calcium build up or to small of piercing, or it can be a kink in the water line, or even the white fill tube at the icemaker is closing up with ice. 99% sure you will find the problem in one of those areas.
Apr 23, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Ice despenser not working
use a hair dryer, it will thaw the ice and not damage the plastic
Apr 26, 2008 | Kenmore 50522 / 50524 Side by Side...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
