The drive was making noise kinda like an alarm. will not boot bios says no hard detected, cant even get to the bios only a boot menu. (from where to boot). Its in a toshiba sattleite
    Sergeant:
  • 223 Answers
Sounds like your hard disk is toast. sorry. I have fought this battle many times.... in fact, i am dealing with the same problem today, they make the drives so cheaply now they fault too early. replace internal hard disk and reload your software. Plus i have three more on the bench with the same problem.
Posted on Aug 27, 2010
  • Trevor Groves
    Trevor Groves Aug 28, 2010
    Does my response answer your question? do you need further clarification or help? Please use the solution rating if your problem has been solved, or make a note if your still having trouble.
    Thanks! Gurvy
If you starts it, there is black screen with the message: media test failure
Go into the BIOS settings at boot up. Disable the option to boot from network, that must solve it :)
May 27, 2014 | Acer Aspire 5100 Notebook
Toshiba laptop makes a lound alarm at startup
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Next - to check if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an USB mass storage device and you cannot open the various folders and files on this drive, then this confirms the hard drive is faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Jan 28, 2013 | Toshiba Satellite Computers & Internet
How do i fix my laptop when it says no hard disc is found
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jul 02, 2012 | Toshiba Computers & Internet
Acer 5733z-4633 is stuck in a sort of boot loop. Won't enter bois setup or boot device options screen. Is this a hard drive issue?(it kinda makes a funny clicking noise then starts all over to try
Yes! it does sound like the hard drive is bad, remove hardware to see if you can enter bios and boot device, if yes the hard drive needs to be replaced, if no change there is a secondary problem.
Jun 11, 2012 | Acer Computers & Internet
Boot failure asus a7v 133 motherboard installed a pci sata raid
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mike
Mar 25, 2009 | ASUS A7V133 Motherboard
Can't start windows: Hard Drive - No drive detected
The laptop cannot see/detect the hard drive. This means the hard drive is faulty or it needs reaeating.
Remove the hard drive and inserting again, then reboot the laptop, if it still cannot detect the hard drive then it is faulty.
You need to purchase a new one and install Windows on the new hard drive.
Mar 14, 2009 | Dell Inspiron B120 Notebook
Emachine
F10 should get you into BIOS.
Jul 27, 2008 | HP Pavilion dv9000z Notebook
Hard drive does not boot up, green light flashing on back, seems no power getting to hard drive?
first u check wether ur hdd detect or not.u can check it from bios while booting press dell or f2 key (u can see on the screen which key have to use)to enter the bios and select stadard bios setup or disk drive specification on menu,if it detected u will see on the menu, again this problem remains may be the os prob.
Jul 02, 2008 | HP Computers & Internet
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
