Our Brother Fax Machine MFC 8500 is giving us a large black bar on the right side of the page, about 2" x 6". I have cleaned it, front and back, top to bottom and have not had any large amounts of toner in the machine, only traces of toner. We replaced the drum, because it was telling us we needed to. I got the bar to go away for a few days, but it came back again. We had someone tell us it might be the fuser?!
5 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: brother 4750 fuser replacement
The entire front, sides, and rear cover is all one piece. Take the screws out and lift straight up.
Posted on Oct 26, 2008
Jimsta01
  • 405 Answers
SOURCE: I have a Brother fax
Please follow the link below, it will show you step by step how to replace the toner cartridge.
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000000/000065/faq000065_029.html?reg=us&c=ca&lang=en&prod=mfc8460n_all
Posted on Apr 11, 2010
  • 17 Answers
SOURCE: I replaced already new toner cartridge for my
The machine will only work with genuine ccartridgeses and not refilled or reconditioned cartridges the cartrage you are trying to install is either a refilled unit or the cartridges is faulty.
Posted on Apr 13, 2010
sayer268
  • 147 Answers
SOURCE: We have a Brother MFC -8500 fax machine. Every day
The Drum unit is a consumable.
Buy a new Drum from Staples , Office Max etc and replace it soon.
It will stop and refuse to print when a certain page count is reached.
Posted on Jan 07, 2011
My brother MFC 8500 is receiving alright but everything I send out has a big black streak going down the right side of the page. Confirmation page also has big black streak.
Let me see if I got this right.
The received fax is clean but when you send one out it has a black streak on it.
Cool! So far so good.
Makes sense because for sending, the fax scans the original document and parts of the scanning area could be dirty and so on. Therefore a black streak may appear.
The same black streak would also appear when you make a copy, because the original document must also be scanned.
Logical!
However for receiving faxes, the machine uses the internal memory and the print engine only, and the same applies to printing the transaction report, which comes from inside via the print engine.
The scanner has no rol in either situation.
Now I'm lost!
May 31, 2011 | Brother Office Equipment & Supplies
Jan 07, 2011 | Brother IntelliFAX 2800 Laser Fax
3 black smudge horizontal lines on prints
Your brother can send faxes without printing the pages try your computer just you should download the driver.
You can download the driver from this link: " http://download.cnet.com/Brother-MFC-8220-USB/3000-2118_4-65318.html ".
About the lines which appear on the print, you will have to buy a Drum unit for your Brother 575, because the drum cleaning blade has quit working and there is no other way to fix this only by putting a new drum unit.
note:
the drum unit is different from the toner cartridge, but if you search good you can find them together for lower price.
Please rate me
Jul 15, 2009 | Brother MFC-8220 Fax
The Black line on the paper when I scan and fax
try cleaning the grid on the drum unit and you might replace the drum
Dec 22, 2008 | Brother MFC-8220 Fax
Black line down right margin
Have you tried a new toner and drum unit? if not please do so. If that doesn't work then it is a scanner lamp failure and will need replacing.
You can fix it but trying to obtain this part for such an old machine will be hard. Don't know the part number sorry.
Thanks J
Jan 30, 2008 | Brother MFC 8500 All-In-One Laser Printer
Brother MFC 8500 Fax machine error "offline"
is your fax machine connected to the phone line? this usually indicates the connection status, thus, if your phone line is in...you wont have the "offline message".
hope this helps.
Jan 23, 2008 | Brother MFC 8500 All-In-One Laser Printer
Brother MFC 8500
Hi, Make sure the rear cover is closed. 2. Usually when you get misc symbols on the printed page the machine couldn't recognize the print job. I would try printing something from another file and see if the problem occurs.
Dec 01, 2007 | Brother MFC 8500 All-In-One Laser Printer
Brother mfc 8500 clicking noises
If you open the cover and remove the toner/drum unit, you will see (on the left side as you remove) a small hole with two triangle teeth.
on either side of this hole are two small phillips head screws. this is the problem we had with our clicking noise. As the machine tries to turn the toner/drum, the innards of the toner are becoming harder to turn. So the part of the fax machine that fits in the hole end up stripping the teeth in that hole. If you have an old toner cartridge, you can remove the gearing from it (where the small phillips head screws are) and use it to replace the gearing on the newer cartridge. Or go buy a new toner cartridge.
Jul 24, 2006 | Brother MFC 8500 All-In-One Laser Printer
42 people viewed this question
jasbo
jasbo
