Question about Samsung 204T 20" LCD Monitor
I turned off my pc, with no problems, and when I turned it back on again, the monitor is displaying improperly. The blacks no longer exist, and the colors are washed out,slightly staticky, and mildly inverted. I didn't drop it or spill water on it or anything. The only thing I did was move my pc to the other side of the room. I've tried rebooting, fiddling with the color options, and unplugging and plugging back in.. Please help!
  • 131 Answers
Check that the video cables are connected properly and secured with the screws.
Posted on Aug 27, 2010
  • illinois68
    illinois68 Aug 28, 2010
    Check that the display properties setting has the appropriate refresh rate setting for your flat panel's requirements.
I have a compaq cq1-1020 the computer turns on but not the monitor. I shined a flashlight on it and all I have is a black screen.
This is a common problem with Monitors usualy caused by flactuation of power supplied to the monitor or sometimes improper shutdown. The problem with your monitor is the capacitor(s) that are responsible for recieving and holding down electric charge for proper display on your monitor are damaged (burned out). The solution and probably the best, is to get a computer technician who can open up your monitor, identify the damaged capacitor(s) and replace them. Make sure to note polarity (-) and ( ) before removing the damaged capacitors. (damaged capacitors have a burged head or there's some liquid around it)
Dec 11, 2011 | Compaq Presario Cq11020 AllInOne Desktop...
Hi guys! Im having problem with my Dell monitor. When i turn on my computer it will load but my monitor just display 2-3 seconds and it will turn black again..the power light is working when i turn off and...
This is a problem with the CCFL bulb (the back light) or the inverter that powers it. This bulb is inside the lcd pannle and requires great care to replace. Some local PC Repair shops will be able to fix it however most will not. The inverter which is (most likely) the problem can be found on ebay for $20-30 USD and is easily replaceable it is general a small curcit board below the lcd pannle hidden in the bevel. However same times the board is merged into a much larger board which will be tricky to replace as it is specific to the monitor.
Don't forget to rate below.
May 10, 2011 | Computers & Internet
Hello Sir, I am using DELL E173FP LCD monitor. My CPU absolutely fine I see initially booting thing on my monitor display then it gets black. I can hear starting sound of Windows XP, that too is fine. When...
You might need to change the screen refresh rate. Go do Control Panel> Display> Setting> Advance, choose 60 Hz. In order to make your Monitor able to display, restart the PC, press F8 on the keyboard frequently upon splashing ( 1 or 2 seconds after PC restarts). Select enable VGA mode by pressing up arrow of the keyboard> press enter. The display should look bigger, then you can start adjusting the screen refresh rate to 60 Hz
Apr 09, 2010 | Dell E173FP 17" LCD Monitor
Monitor displays the PC screen but switches off within 10 second
Unfortunatley your monitor is going out. I just had that problem. My sceen would come on, but after about 10min. it would blink off and turn black. I would have to hit the off button on the monitor, then turn it back on. It would work fine for a few minutes then black out again. I got a new/used monitor where I no longer have that problem.
I did check to make sure my hybernate was not activated, it wasn't, I had it set to never turn off.
Good luck.
Sep 02, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Monitor keeps turning off
my first two ideas are....
1. Power setting/screen saver - this could be build into the monitor or a setting in the power options in the control panel.
2. improper setting for the monitor....this could be the refresh rate most likely.....right-click in a blank area of the desktop, go to properties, settings tab, advanced.....there should be an option in one of the tabs that has an option for refreash rate...make sure it is set to 60.....
If not one of these two things, than it is a faulty monitor......probably not worth getting fixed....hopefully still under warranty??
May 18, 2008 | Proview PL926WBi 19" LCD Monitor
Mag lcd monitor
probably capacytor problem in the mainboard, take it to the lab it will be cheaper then buying new one
May 06, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? Monitor will go on for a split second, then screen will go...
they normally turn off like this when they aren't receiving a video signal from the pc (same as when you turn off the pc). make sure that it is connected properly, and that the video output is activated. try disconnecting from the other monitor while its on and connect the problem monitor...if it still isn't working then there may be a problem with the cable or the monitor itself. Try another VGA or DVI cable. Hope this helps
Mar 29, 2008 | Computers & Internet
Samsung 204T 20" LCD Monitor Logo
53 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
