When I print out the printer does not work,even though its connected to wall outlet and computer. It is also not in pause mode. signed discussed
  • 526 Answers
You will need to give a better description of your problem. Saying it does not work even though its connected to the wall outlet, does not mean anything
Posted on Aug 27, 2010
Why when I try to print off an e-mail it says printer is 'paused'
It seems that the printer is set to pause mode...
Download the print and scan doctor tool from the HP Website and run the same .. it will fix the issue
Download Link: www.hp.com/go/tools
Oct 12, 2014 | HP Deskjet F2180 All-In-One InkJet Printer
False paper out message
An 'Out of Paper ' error message displays on the product control panel display, and the product does not pick up or feed paper from the photo tray.
Try to reset the printer:
  • Disconnect the power cord from the electrical outlet.
  • Disconnect the USB or Ethernet cable from the back of the product.
  • Disconnect the power cord from the back of the product.
  • After 30 seconds, connect the power cord to the back of the product.
  • Connect the power cord directly to an electrical wall outlet.
  • Connect the USB or Ethernet cable to the back of the product.
  • Try the print job again.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Nov 16, 2012 | Xante ScreenWriter 4 Laser Printer
My printer wont turn on even though it's connected to direct power supply. Why wont it turn on?
Generally the troubleshooting steps are:
  1. disconnect the printer from the data cable to the computer and plug directly into a wall outlet bypassing any power strips/battery backup and then see if it will power on. If it does, run a self test and see if it prints.
  2. If still in a no power state, unplug the power adapter from the wall and the printer, wait 5 minutes, then plug into wall, then in to printer and try to power on again.
  3. If still no power and under warranty, contact manufacturer for repairs/replacement.
  4. If not under warranty and an Inkjet, almost assured it will be less expensive to replace than to repair:
My current favorite: http://www.walmart.com/ip/HP-Deskjet-3050-All-In-One-Printer/15075186
Jul 10, 2011 | Lexmark Office Equipment & Supplies
My dell p703w printer is not printing black even though i cleaned printer head and reset setting tried several new cartridges what do i do now
Printer Problems Ensure that the printer power cable is firmly connected to the printer and the electrical outlet.
Determine if the printer has been held or paused.
  1. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
In Windows Vista®:
  1. Click windoa14.jpg ® Control Panel.
  2. Click Hardware and Sound.
  3. Click Printers.
  1. Right-click the printer icon.
  2. Ensure that Pause Printing is not selected. If Pause Printing is selected, click Resume Printing.
Ensure that you installed the ink cartridges correctly and removed the orange caps from each cartridge.
For more information, see Replacing Ink Cartridges.
Ensure that you loaded the paper correctly.
For more information, see Loading Paper.
Ensure that the printer is not connected to a PictBridge-enabled camera.
For more information, see Printing Photos From a PictBridge-Enabled Camera.
for more detail see this page
http://support.dell.com/support/edocs/systems/p703w/en/UG/troubles.htm
i hope this helpful
thank you for using fixya
Feb 08, 2011 | Dell P703w Printer
Won't power on
hi,
check your cable wire that connect from the wall outlet to your computer.
unless your printer is totally dead.
best regards,
kaybicks
Feb 23, 2010 | Dell A940 All-In-One InkJet Printer
Printer always says its offline even though its on and connected
If you are Windows XP Operating System, perform the steps below:
1. Click Start --> Printers and Fax.
2. Right click the printer icon and check the following:
a. Check whether the All-in-One is set as default printer.
b. Ensure that the there is a check mark on the "Use printer online". If you have the Use printer offline, make it online by selecting the option.
c. Ensure that there is no check mark on the Pause printing.
Check for the default printer and USe printer Online in the printers and faxes folder.
Click Start -->> Control panel -->> Hardware and sound-->> Printers-->>Change default printer. ---> Please Right Click on the printer icon which has tick mark and Select the options Use printer Online and Set as Default and also Select the option Resume printing.
Sep 30, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Screen shows ready but can't print
ese follow these procedures carefully and i hope it will solve your problem.
● Check that all trays are correctly
loaded, adjusted, and installed in
the device.
● Using the computer, check the print
queue or print spooler to see if the
device has been paused. If there
are problems with the current print
job, or if the device is paused, a
configuration page will not print.
Also check the IP address associated with it if it is not connected directly. Make sure it corresponds with the one on the printer.
May 19, 2009 | HP LaserJet P3005n Printer
Won't print
The printer needs to be connected to the wall outlet, and to the computer. That means you need two cords: a power adapter (to wall outlet), and a USB cable (to computer). You also need printer drivers installed. Those come with the printer, on a CD. The printer generally needs to be powered ON for the computer to recognize it.
Feb 02, 2009 | HP Officejet 5610 All-In-One InkJet...
It started, then stopped!
Seem to be a power problem. Leave your printer unplugged a while. Connect it again and see if the power comes up. Check the power strip outlet, change it for a different one or connect the printer to another outlet on the wall. If still not working your printer needs to be serviced or replaced
Oct 08, 2008 | HP PSC 1210 All-In-One InkJet Printer
Not able to print from computer I have an lexmark 4270
Is your printer connected to your PC? Is it plugged in and turned on? Is paper and ink properly loaded? If all is ok, try this: Shut down your PC and printer. UNPLUG PRINTER FROM pc and wall outlet. Turn on PC and wait until it is fully initialized. Plug the printer into wall outlet and turn it on. Connect printer to PC via USB cable. The PC should display a NEW HARDWARE FOUND messsage. Next, your PC will try to install the printer by searching for the proper driver for it. If no driver is found, you can download it from http://support.lexmark.com If you have the printer installed, try the following: On your windows screen, left click START. Left click on CONTROL PANEL, and left click on PRINTERS. Find your printer icon in the PRINTERS window and RIGHT CLICK on the printer icon. From the drop-down window, make sure that PAUSE PRINTING is NOT checked off. Next, left click on PROPERTIES at the botom of menu. In the PROPERTIES WINDOW, GENERAL tab, left click on the PRINT TEST PAGE button. If it does not print, try following the on-screen troubleshooting instructions.
Aug 09, 2008 | Lexmark Office Equipment & Supplies
jasbo
jasbo
