Question about Vizio Televison & Video
It cut off before and gave a message across the screen saying the RGB is off and the television will cut off. What do this mean. The television is in the on mode. How can I get it to work. Model Number: VP322HDTV10A Serial Number: PSLCHAJ3664386
  • 70 Answers
The television selected to PC input so change to TV or AV using external input selector
Posted on Aug 27, 2010
What is a RGB signal
RGB means Red,Green,Blue it is an old system for supplying video signal to a screen..
Feb 01, 2016 | Televison & Video
I have a 61 inch samsung TV. A message flashed across the screen saying "check fan # 1 " then a few minutes later it shut down.
Hello
Not much to do by web, this message mean you most likely need a new fan, tv shuts down due to overheating. Contact service.
Aug 21, 2011 | Samsung Televison & Video
I have an Emerson Plasma TV (PL-P42W-10A) and it cuts off the top and bottom of the screen. It just started doing this. The only sizes that are available are 16:0 Zoom1, Zoom2, and 4:3. The Wide Fit and...
Our prolem is no matter how we adjust the screen when ever there message at the bottom of the screen this don't show up or is cut off. I get upset when I pay the amount for this 42" Plasma TV and watching the news there extra messages across the bottom of the screen espically when school closing due to weather. I've try to figure out using the instruction booklet with no results. Any ideas where the screen to where extra messages in lower screen can be seen to be read?
kimandtomaleexander@gmail.com
Oct 26, 2010 | Emerson EWL3706 37 in. LCD Television
No signal when connecting PC to TV
This happens to almost every laptop I know. Here are several solutions:
1. You need to manually enable video on tv by pressing two buttons on your laptop keyboard. The first is "Fn" (at the left bottom). The second depends on your laptop manufacturer. Look at the function keys. F1....F12 for the LCD/CRT or the corresponding sign. Press and hold Fn and press second button. Sometimes you need to press second button several times. This means you need to cycle through all available options to enable Laptop's screen and TV screen at the same time (clone).
2. Intel Extreme Graphics video cards sometimes doesn't support a procedure described above. You need to find intel video card options manager running at the sys-tray (right bottom of your screen near the clock). Right click on it. Select Graphic Options -> Output to -> Laptop + ... clone (or something similar)
Note that not all video cards are capable of showing the movie on media player at the same time. You need to choose Laptop or TV
Feb 07, 2009 | Vizio L32 32 in. LCD HDTV
3 year old rca rear projection just started going blurry. green blue and red line across the top of screen. objects have shadow.
Focus and screen control box / remove front bottom panel there you will find it / it has 3 controls on top 3 on bottom top are focus for RGB tubes bottom controls adjust screen drives for RGB.
Jan 25, 2009 | RCA D52W23 52" HDTV CRT TV
Hello, My color isn't right on my computer. The box that pops up says "RGB no input signal". How can I fix this problem? Thanks Debbie
REMOVED THE 15 PIN PLUG - I GET A SCREEN MESSAGE - SYSTEM CABLE DISCONNECT! WHEN I PLUG IT BACK IN THE MESSAGE RGB NO INPUT SIGNAL APPEARS FOR A FEW SECONDS THEN THE MONITOR GOES INTO STANDBY AND THE SCREEN STAYS BLANK,
I ALSO PLUGGED THE MONITOR INTO MY LAPTOP AND THE SAME MESSAGE APPEARED
Nov 18, 2008 | Computers & Internet
To repair a tv set
If it has white out with screen retrace lines it means that the 130-200 volt line is missing from the flyback transformer to the neck crt board. begin by checking if the .68ohm to 1ohm fusible resistor is open circuit.if it is then you either have a defective rgb drive chip, or in most sets a shorted drive transistor. a defective gun in the tube can also take out the fusible but unlikely.
Jul 09, 2008 | Televison & Video
Red and green lines across the screen
classy cuban,
Probable convergence issue....replace convergence IC's
Guest,
In front of set behind access panel,locate RGB focus and screen
adjust block.....turn red screen control ccw a bit........
m888, Your monitor has a bad CRT.........................T.
Nov 09, 2007 | Sony KP-51HW40 51" Rear Projection...
Connecting to pc
in the menu screen you will see RGB DTV Highlight that setting and use the right arrow on the remote and you will come across RGB PC. Make sure that is selected and " back out " of the menus. Enjoy
Aug 30, 2006 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
75 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
