Question about Friedrich Heating & Cooling
I HAVE NEW AIR CONDITION IT WON,T BLOW COLD WS10B10A
  • Friedrich Master
  • 43,501 Answers
If you have a brand new unit and it don't work... pack it up and take it back for an exchange...it happens...
heatman101
Posted on Aug 27, 2010
My air condition only blows out cold air not hot
Turn your air conditioner OFF and turn your heater ON. Air conditioners were designed to blow out one temperature of air... COLD.
Nov 13, 2014 | 2004 Mercury Grand Marquis
MY AIR CONDITION WILL NOT BLOW COLD AIR BUT FULL OF FREON
check for compressor clutch operation, if the clutch is engageing you could have a bad compressor or a blockage in expansion valve
Apr 13, 2014 | 2007 Chevrolet HHR Fall
Blower fan for a/c won't blow, air is cold
Have you checked the blower motor for power and ground ?
May 17, 2013 | 2002 Dodge Durango
My heater won't blow warm air if i am parked only when the car is moving
If your engine temp reads warm then your heater core is clogged. Try flushing the system. If it reads cold then u need a new thermostat
Mar 04, 2013 | Cars & Trucks
2002 gmc safari van defrost blow cold, a/c blow out of defrost
open the hood and check for leak on any plastic vacuum lines.
Oct 19, 2012 | 2002 GMC Safari
Air conditioner starts out blowing cold air,apparently actuator sticks causing the system to blow very hot air. Hours later a/c blows very cold air again, only to blow wry hot air again after about 30...
1.)If your System is OVERCHARGED this Will Occure due to the EVAPERATOR FREEZING UP
2.) Also if your HVAC Control Modual is Malfunctioning this will Aslo Cause this Condition, It Controls the BLEND DOORS that OPEN for COLD or HOT AIR Look Into these Items and Also Look Into wethrt the A/C Compressor Cycles OFF when it GETS OFF this Will POINT at the HVAC CONTROLER if it Cycles Off When Set For A/C or COLD Air
Aug 19, 2010 | Chevrolet C1500 Cars & Trucks
Air condition won't blow cold
Clogged ORFICE TUBE and or Low Freon Level.
Jun 04, 2010 | 1998 Plymouth Breeze
I have a 1992 mercedes 200 E WDB 021 Saloon, it has 8 button air condition and I dont know how to use it. Control wheel on blue position but When I push the button (leftmost)which has a glass figure on it,...
The pulley on the air condition has to turn it has a belt on it. The Compressor engages to pre cool the evaporator. Most likely you have a blend door pod leak or leak in the hose or the sampler valve is bad. I would replace the sampling valve behind the glove box/air bag. As that reads the cabin temp and if it thinks the car is cold the heat will stay on because everything is automatic. All vents will blow cold when it thinks its hot and in addition to floor and corner dash center vents will blow cold when it works. If the direction of air is correct then the A/C system may have a leak or need a charge of freon.
May 05, 2010 | 1992 Mercedes-Benz E-Class
My air condition want' blow out cold air i try
If your car is more than a few years old, it probably has a leak or a worn compressor. You can add too much freon for the system. It needs to be vacuumed down to a negative pressure before adding freon, and then checked for compressor function and leaks. You may need to take it in to a reputable shop.
Apr 08, 2010 | 2002 Chevrolet Monte Carlo
Heater won,t blow warm . core ok. fan runs .will only blow cold
EITHER VALVE STUCK TO ALLOW WATER IN MATRIX OR YOU HAVE AIR BLOCK IN IT. TAKE OFF TOP HOSE AND RUN MOTOR, TOP UP RAD AT SAME TIME, USED A DESCALANT IF WATER MUDDY /RUSTY LOOKING
Feb 02, 2009 | 1997 Dodge Neon
Heating & Cooling Logo
Top Friedrich Heating & Cooling Experts
Bill Long
Michael Vincent Cruz
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
